Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Thread Tools Display Modes
Old 01-18-2005, 08:32 PM   #1
Stalling on highway
Here's another question about my 1985 Maxima. For the last couple of days, it has been acting very strange. It is basically stalling at any speed (even in park). I can be cruising along on the highway, and watch my tach go from 2000 to 0 and back to 2000 again in a second. The car jerks violently when it does this. It is stalling, and running again. When it does this at slower speeds, it will just die. I originally assumed it must be a lack of spark, so I checked the plugs, wires, coil, and distributor. All seems fine. I did find a bad connection at the battery, but have since fixed that (I think).
Any suggestions?
nate239 is offline   Reply With Quote
Old 01-18-2005, 08:44 PM   #2
The Man is watching.
Send a message via MSN to maximase86
I had this problem.....you'll need to check a few things. First check the codes on the ECU and see if your pulling a code for the CAS. If it shows code 44, check the fusible link for the ECU/EFI Relay. It's located on the positive battery cable along with the Aux Fan fusible link. Make sure the wire isn't just plain falling apart. If it looks like it is, replace the link.
S
__________________
-Sarin
02 GLE - Majestic Blue/Frost Leather
6k D2R HID - AE/Clear Headlights - 3k HID fogs w/Lexus Capsules - Exterior LED's - AE Tails
Smoked Sidemarkers - 15% tint - G35 Coupe 18's - Short Ram Intake
Past:
86 SE - MOTM
97 GXE SC'er - RIP 10/12/08
http://www.nwmaxima.com
maximase86 is offline   Reply With Quote
Old 01-18-2005, 08:48 PM   #3
Pardon my stupidity, but what is the CAS?
Old 01-18-2005, 08:58 PM   #4
Crank Angle Sensor. Basically its in the distributor that consists of a metal disc with a lot of slits in it. On the top of it is an LED, and below it is an optical pickup. Basically this provides the timing pulse used to fire the injectors as well as igntion timing.
S
__________________
-Sarin
Past:
86 SE - MOTM
Old 01-18-2005, 09:10 PM   #5
Ahh yes. I did not check that yet. Is this EFI relay located close to the possitive battery cable? Sorry if I sound like an idiot, but I have been playing around with that possitive battery connection for a couple of days, thinking there may be a break in the wires somewhere near there. If this relay is located close by, that may be my culprit. It makes a clicking sound when it stalls during an idle. Every time it clicks, it starts to die. I thought it sounded like a relay, and started to check the manual for some sort of relay that controls power to the coil.
Old 01-18-2005, 09:17 PM   #6
If you look between the headlight and battery, you'll see a relay box. Just pop it off and use reference to see which relay is what. I'd check codes on the ECU, as well as fusible links. I thought mine was bad, but it tested fine...and it turned out to be the fusible link.
S
__________________
-Sarin
Past:
86 SE - MOTM
Old 01-18-2005, 09:23 PM   #7
Will do... thanks.
Old 01-18-2005, 10:09 PM   #8
No prob. Let us know how things go.
S
__________________
-Sarin
Past:
86 SE - MOTM
Old 01-19-2005, 09:20 AM   #9
Send a message via AIM to turboast4 Send a message via Yahoo to turboast4
Sounds like his timing belt is breaking and then instantly repairing itself. I'd look into that.
__________________
-Jon
Now SHIFT_ing DIY style
turboast4 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
