Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Thread Tools Display Modes
Old 01-03-2005, 12:23 PM   #1
Very Strange Steering Problem
I lucked out! I managed to get my hands on a 1985 Maxima that has been in storage forever. This car is literally out of the box new! It only has one little problem. The steering on this car is "STRANGE" and I'm not sure what's going on with it.
When you steer into a turn the car will suddenly over-steers just a little then back off. It does this over and over again where the car kind of rocks in and out of the turn. The steering wheel will also move turning in and out like the car has set up some kind of harmonic movement. If you grab it with you knees and hold it the car will stabilize a little but the minute you let the wheel go the car will start this rocking motion again.
To try and explain this a different way when I go into a turn at any speed above 55mph and the turn is fairly sharp the car seems to want to segment its way around the turn, its not smooth but jumpy in that the car oscillates as its turning. The steering wheel oscillates while I turn too. The front end is aligned! Nothing seems to be loose at all! The original owner says its always been like that! Since the original owner is my dad I can believe him.
In a very sharp turn the car turns OK. Its like there is this SPOT where the car is having this problem! Anyone ever heard of such a thing? Anyone know what the problem might be?
Thanks for your help!
Gfreed is offline   Reply With Quote
Old 01-03-2005, 03:27 PM   #2
Send a message via AIM to turboast4 Send a message via Yahoo to turboast4
Just wondering, what do you mean by "This car is literally out of the box new!" ??? How many miles are on it? How often was it started, etc. ?
__________________
-Jon
Now SHIFT_ing DIY style
turboast4 is offline   Reply With Quote
Old 01-03-2005, 04:29 PM   #3
The Man is watching.
Send a message via MSN to maximase86
Your in Seattle? I live up in Lynnwood. Maybe if I have some free time, I can meet up with you and see what is going on.
S
__________________
-Sarin
02 GLE - Majestic Blue/Frost Leather
6k D2R HID - AE/Clear Headlights - 3k HID fogs w/Lexus Capsules - Exterior LED's - AE Tails
Smoked Sidemarkers - 15% tint - G35 Coupe 18's - Short Ram Intake
Past:
86 SE - MOTM
97 GXE SC'er - RIP 10/12/08
http://www.nwmaxima.com
maximase86 is offline   Reply With Quote
Old 01-03-2005, 05:14 PM   #4
jos
Quote:
Sounds like tires. Out of shape from sitting forever in one poisition?
jos is offline   Reply With Quote
Old 01-03-2005, 06:20 PM   #5
Send a message via AIM to Niku-Sama
^what he sayas^
Niku-Sama is offline   Reply With Quote
Old 01-03-2005, 07:07 PM   #6
Quote:
I should have been more discriptive! The car has been well taken care of. It looks new. It has about 76K on it. My dad says the the steering has always been the way I discibed it.
The tires are new and are in good shape. They don't make any strange noises or anything. I thought the tires might be messed up but the car did this with the first set too. My dad thought this was just the way the car steers. He mostly used it on the freeway all the time. Being 80 something he doesn't drive too fast! So when he's driving you can't tell there is a problem. The car is old enough where its worth nothing but is in such good shape he couldn't see just giving it away. Since my car gets 400 miles to the quart of oil he gave it to me. I will give my car away.
Where I'm at I'm on country roads and so this turning problem is a real pain. I'm also wondering if this can cause some real problems in the snow! I've parked it until I can get some idea what's going on.
As I've said there is this one spot where the car oscillates around the turns. Its really the most strange thing I've ever felt in a car before. I've had cars with oversteer and understeer but never both at the same time. The steering wheel actually oscillates in the turn. And it only does this at a curtain point, turn more sharply or less and it doesn't oscillate. Its really strange.
Old 01-03-2005, 09:44 PM   #7
check the power steering, odds are its black or atleast not red so i would get it changed out, it may be low too
Old 01-03-2005, 11:19 PM   #8
Steering issue..
I experienced the exact situation with my 87'. I have trusted my beauty to the skilled gentlemen at Z-sport in Everett. They had discovered a small leak in the power steering return line. It made a significant difference yet it still slightly reacts as you have discribed. I don't mind because this car has far too many great qualities. Cruise on!
Christian is offline   Reply With Quote
Old 05-20-2005, 11:50 PM   #9
Mine is doing the same thing!!
Mine has been doing the same thing since I bought it. I noticed the lady that had it before me (1 owner) had had the steering rack changed less than a year ago. What gives? The way you describe the cyclical, notchiness of the wheel is exactly what mine is doing. The thing on mine is that it only does it in one direction from center (to the left, I believe). It does it with pressure on the wheel even when stopped. This is stealing all of the joy of ownership of this car, believe me.....
ukfan4sure! is offline   Reply With Quote
Old 06-03-2005, 02:27 AM   #10
still brewin'
Yayomax's Avatar
Send a message via Yahoo to Yayomax
I have an 88 se 5speed and my car scared the hell out of me the first time it happened to me. 45mph or above in a turn, the car would lean a bit as normal, then out of nowhere in the middle of the turn, snap into a secondary lean. During the process of lowering my car, I discovered that my lower control/A-arm bushings were shot. The smaller metal ring, surrounded by rubber and another metal ring came right out when I removed the arm which is connected to the bottom of the rotor by a ball joint. It was easier for me buy two arms for 24$ from salvage than pay 35$ for two bushings, then find a machine press to change them out. Tested them and found my
PROBLEM COMPLETELY SOLVED. Went on to lower my ride, put back on my lead foot, and happily take those 35mph curves at 60+!!! But thats just me.
Yayomax is offline   Reply With Quote
Old 06-03-2005, 06:54 AM   #11
Lower control arm bushings eh? I'll have to have a look when I rotate my tires this weekend.
wylie-c is offline   Reply With Quote
Old 06-03-2005, 07:39 AM   #12
Super Moderator
Mine did that for awhile. Then I added fluid to my power steering and it was fine. I later found it it was my tires which is what it sounds just like on yours. The inner part of one of the front wheels is starting to wear out. It may not be so visible but you could be getting down to the woven steel they have in them.
__________________
Shift_PRND21
1995 BLK/BLK SE:
Warpspeed superflo y-pipe, Tokico Illumina Suspension Kit,
5th gen Strut bar, ADDCO RSB,
17x7 ADR SZ1 rims, red laquered calibers, Nexen N3000 tires,
Smoked Diamond clear turn signal lens,
AE Headlights/clearance lights/foglights, rewired fogs
max95q is offline   Reply With Quote
Old 06-03-2005, 03:24 PM   #13
hmm....i know my lower control arm bushings are missing and i dont have that problem....but it does lean bad but then again i need those bushings ontop of other bushings and slocks/struts (theyre BLEEDING....CALL AN EXORCIST!)
Old 06-04-2005, 02:04 AM   #14
still brewin'
Yayomax's Avatar
Just wondering, does your car exhibit those symptoms during general steering/turning or do they surface while attacking curves at higher speeds? Under hard acceleration? My power steering fluid was really dark until a leak occured and it all drained out resulting in a large set of forearms. Fixed the leak and added fresh fluid, but snap handling problem persisted. Changed tie-rod ends, had tires rotated/balanced, alignment, checked tightness of rack & pinion bushings to firewall, to no avail. Having intact control arm bushings killed two birds with one stone. Really bad inside tire wear(two sets of tires a year with shredded wires and bald patches and practically brand new middle/outside meat!), and strange handling as you described to where it would hit a "spot" during the curve like something gave way and it would pull my steering wheel in the opposide direction until I slowed or exited the curve.
Old 06-04-2005, 12:38 PM   #15
Mine will do it just sitting still. If you turn the steering and put pressure on the pump, it will reach a certain point where it will start the rocking feeling. Like it has assist, and then doesn't. You can feel it helping, and then not. It rocks the steering wheel back and forth. I can definately rule out any front end problem on mine.....it isn't moving!
Old 06-04-2005, 10:05 PM   #16
that kinda sounds like air to me
Old 06-05-2005, 07:09 AM   #17
my car has similar problems when the ps fluid is low. it feels like the car is fighting me when i turn the wheel it keeps wanting to go back to straight. im going to try some lucas ps stop leak, and see if it helps keep the fluid in my ps system.
downey180 is offline   Reply With Quote
Old 06-14-2005, 11:35 PM   #18
One of my power steering hoses broke back when the car was my Grandmas. Power steering fluid shot all over the manifold I could have sworn that the car was on fire. Since I got the car and started driveing it on a regular basis I have also noticed a point at which the car starts to turn in segments. My power steering pump also makes a lot of noise.
UberZogster is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
