Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Thread Tools Display Modes
Old 04-11-2001, 10:10 PM   #1
I have a '88 Max with adjustable shocks and (4)their in need of replacing. Can i replace them with standard or non-adjustable shocks, and if so what brand?
damax is offline   Reply With Quote
Old 04-12-2001, 03:41 AM   #2
youll need to get an adapter, check you local napa store.
I got mine replaced because at Pepboys, they wanted $500.00 each rear, and $600.00 each front.
KYB I believe are the name of the struts, they shouldnt cost over 70.00 each.
A nissan junk yard put them on for me here in Atlanta GA
good luck!
MrSmith is offline   Reply With Quote
Old 04-12-2001, 06:55 AM   #3
Send a message via AIM to maxima561
I got my kyb gr2 shocks for $45.oo each from a wholesale supplier. It takes a few hours to install them cause you gotta do an alignment and take out the rear seat
__________________
1988 Silver, Silver tint, custom RSB,CAI,Dynomax Exhaust,Shift kit, High Stall Converter, ST springs, 2 solobaric 15's,800.2, 250.2, 149.2db at last comp.17x7 205/40/zr17
maxima561 is offline   Reply With Quote
Old 04-12-2001, 09:04 AM   #4
Send a message via AIM to whtacc949
You can use KYB struts but then you can no longer use the suspension switch inside the car. I think the struts from Nissan aren't that expensive anymore. they might be more affordable now.
Quote:
whtacc949 is offline   Reply With Quote
Old 05-06-2001, 12:31 AM   #5
nixhex
question about shocks
i'm having this problem with my maxima and someone i know told me it is the suspension and that i need shocks. during accelleration my maxima will start shaking violently untill i let go of accellerator? also i do have the electronic suspension control and pepboys wants 700 bux each. if i can just get a standard shock at 50 dollars each (their quote for standards) then i'd much rather that, i don't understand why the electronic shock system would be 650 dollars more for each, i never even use the switch anyway. so will i be able to use standard shocks with my maxima?
Old 05-27-2001, 07:08 PM   #6
See "electronic shock switch" posted by Lane for my comment on the change over.
konan is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
