Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Thread Tools Display Modes
Old 09-16-2004, 09:50 AM   #1
Checked ECU today and got 'ignition signal' code
So, I removed the screws holding the ECU and checked codes. I got code 2,1 or ignition signal. What does this mean and how do I fix it?
-Joe
(_8*(l)Homer is offline   Reply With Quote
Old 09-19-2004, 12:18 AM   #2
Someone must know what the code means.
Old 09-19-2004, 12:33 AM   #3
The Man is watching.
Send a message via MSN to maximase86
When you we're check this was the car running? You might want to try turning on the car during the check and see if it still shows that code.
S
__________________
-Sarin
02 GLE - Majestic Blue/Frost Leather
6k D2R HID - AE/Clear Headlights - 3k HID fogs w/Lexus Capsules - Exterior LED's - AE Tails
Smoked Sidemarkers - 15% tint - G35 Coupe 18's - Short Ram Intake
Past:
86 SE - MOTM
97 GXE SC'er - RIP 10/12/08
http://www.nwmaxima.com
maximase86 is offline   Reply With Quote
Old 09-19-2004, 10:50 AM   #4
I'll try that.
Old 09-19-2004, 11:32 AM   #5
21 is Ignition signal missing in primary coil. I have the FSM for an 88 maybe it can help. Whats the car doing?
Drjmaxx88 is offline   Reply With Quote
Old 09-19-2004, 03:48 PM   #6
The car really isn't doing anything wrong that I can tell. Rough idle and hard starts from sitting 6hrs or more. I have the 87 FSM, but I have found nothing regarding ECU codes.
The car surges when just the tranny is moving the car... You know, when my foot is not on the gas or the break. It kinda jerks forward.
-Joe
Old 09-20-2004, 09:03 AM   #7
Sounds like an air intake leak. Mine use to do that.
Old 09-20-2004, 03:12 PM   #8
From where was the intake leaking?
-Joe
Old 09-20-2004, 03:38 PM   #9
The part thats black with vulcanized rubber, it has a hole for the crankcase ventilation. It connects the TB to the AIV. I just bought two couplers and a tube from autozone and replaced it.
Old 09-20-2004, 07:54 PM   #10
Send a message via AIM to arsonist63086 Send a message via Yahoo to arsonist63086
from my experiance, i had the same problem with my car i checked it out and it ended up being the timeing was off. and adjusted it and it whent away. it came up cuz because of the igniton signal coming from the distrebuter isnt right. the leds and the disk holes arnt lined up right.
but u dont have to take my word for it.
arsonist63086 is offline   Reply With Quote
Old 09-20-2004, 10:23 PM   #11
I'll check the intake thing Tuesday.
How do I check/adjust the timing. I can probably borrow a timing gun from Napa or something.
__________________
-Joe
Used to have:
'97 SE -Blue LED interior lights, full bra, converted PIAA XTreme 9007, PIAA 1100x driving lights, rain guards, sunroof deflector
Now have:
1987 GXE - Blue LED Auto Climate, Clear bumper lenses, Pioneer Premier HU, Kenwood Excelon Amp, Phillips Hi-Vis bulbs, Modified 9007 headlamp housings. Re-wired corner lights.
Old 09-21-2004, 12:00 AM   #12
Send a message via AIM to Niku-Sama
good luck with the timing, its hard to get the gun down right on top of the marks if you have cruse controll
Niku-Sama is offline   Reply With Quote
Old 09-21-2004, 01:07 PM   #13
damn i know how to do it but i kinda suck on explaning things. but i try my best.
1/ get a timing light (ther r 2 typs base timeing and advance timing light. the dff. is that the advance timeing light has a numbers on it and a bite harder to use and more expensive) so just stick with the base timing ligh in other words the rageler 1.
2/ hook up the timeing light (red clap to + of battery and black - of battery the lasy clamp hook up the the #1 spark plug, cabe just clamp it over the cabel)
3/when u open you hood look at the bottem of it the should be a yello sticker that will show u your timing and vacume diagram
4/ look at were it says timeing. the timing will be 15* btdc on a manual and auto it will be 20*btdc.
5/ look for the crank pully (the 1 wich drives all the belts)
6/ once u have lokated it turn the car on and point the gun on it u will see a arowe like ting right on top of the crank pully and littel marks or scars on the pully(tos r your timeing mark.
0 10 15 20 25 30
ll ll ll ll ll ll
engine spins -->(clock wise)
7/ the littel arow like thing should be pointing right over the 20* mark and when u give it gass it should go to the 0* mark automaticly.(that good timeing)
8/ if not right timeing lossen distributer bolt,(size 10mm) and rotat the distributer clock wies or counter clook wise till the pointer is right on top of the 20* mark.
ther i did my best
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
