Ok, our "new to us" 87 Max GXE Sedan has a couple of intermitent problems.
1) The digital speedometer occasionally drops to 0 and the odometer and trip meters stop incrementing. The display is still on, but reads zero as if the car is parked. It may be working when the car is parked and when we take off later it reads zero... or it may work for a long time and then stop while we are moving. No real pattern.
2) Passenger side automatic seatbelt sometimes does not move. It may stay at either end of it's travel, but it has never stopped in mid-travel. As in, we park and open the passenger door to get out and it stays in the rearmost position, or we get in and start the car and it does not move to the rear.
3) The drivers door window. Works fine and as fast as the rest of the windows... most of the time. Sometimes it will not go down. I can hear a relay in the door but no window movement. Again, no pattern.
Not all symptoms occur at the same time. The window may not work even though everything else works and visa-versa.
Ideas? Suggestions? I was thinking maybe one of the main harness connectors but I don't know where to begin.
