Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Thread Tools Display Modes
Old 09-12-2004, 10:40 AM   #1
Send a message via AIM to Dayle97SE
tranny fluid change...
I would like to do a drain and refill of the auto tranny fluid in my '86, but I can't find the drain plug, also I have a 97 Max and I know if you really wanted you can drop the pan and clean the magnets on the pan for the tranny fluid(a real thorough job i guess!), can this be done on the '86 as well? thanks.
Dayle97SE is offline   Reply With Quote
Old 09-12-2004, 12:24 PM   #2
The Man is watching.
Send a message via MSN to maximase86
There should be a drain plug towards the back center of the car....or at least that is where the one is for my 5-speed. You could drop the pan, but there should be a drain plug.
S
maximase86 is offline   Reply With Quote
Old 09-13-2004, 01:50 AM   #3
Quote:
The drain plug on your RL4F02A Automatic transmission is on the front right behind the bellhousing (facing the grill). It is super easy to get to. The plug takes a 1/2 inch ratchet to remove. Make sure the car is level or facing a downslope to maximize the drain. On mine, I was able to only get about 2-3 quarts out through removal of this plug. I do know the refill capacity is 7.5 quarts, I think.
ukfan4sure! is offline   Reply With Quote
Old 09-13-2004, 11:25 AM   #4
hey thanks, found the drain plug(before i was looking for more of a hex bolt, probably why i didn't find it, lol) but now i have another question regarding the fluid: FSM says to use type Dexron, all i seem to see in stores is DexronIIE and Dexron III, are they all the same? also the bottles of Dexron IIE and III don't say any viscosity number and FSM recommends 80W-90, can someone help clear this up for me?
Old 09-13-2004, 11:49 AM   #5
Dexron III is okay. They don't make II anymore we have to use three. Its just the updated version of II and it works a little better.
Drjmaxx88 is offline   Reply With Quote
Old 09-13-2004, 01:10 PM   #6
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
