Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Thread Tools Display Modes
Old 09-10-2004, 12:48 AM   #1
Auto Tranny Swap---Remove Engine?
Hey everyone;
I am about to do a transmission swap on my 87. It has had catastophic failure and I found a "used" one for $150. Considering the $12-1500 "best" quotes I got for replacement, I guess this will have to do....I was going to try my hand at rebuilding the old one, but I would still be $200-500 into it for parts (allowing for "hard" parts). And then.....if all isn't OK with the rebuild after installing; well, I don't want to go there. Now my question is, is it easier (or mandatory) to remove the engine to do this swap? I seem to read conflicting info on this BB.. Also, if anyone has any "lifesaving" tips about how to best accomplish the swap (save the "take it to a shop" comments...ha), would you let me know? Any help or tips is appreciated. I need info specific to the Maxima, not the "make sure you mark all of the hoses and wires" stuff. I already know all of that jazz. Thanks!
ukfan4sure! is offline   Reply With Quote
Old 09-10-2004, 01:02 AM   #2
I'm needing a caw
Jeff92se's Avatar
Nope. You can easily drop the tranny from below w/o removing the engine. I wish you alot of luck rebuilding an auto tranny. It's like another planet in there!
__________________
2003 G35 Sedan. Mods comin'
3-gen parts for sale
Sold Jan 14, 2006'
Mod list:
Eibach/Konis - ST front sway bar/Addco rear bar - Blemco rstb - Otto fstb
350Z 18" touring wheels.
Modified Cattman Y, Custom flex, 4-gen Carsound cat, Custom cat-back, Y2K muffler
Custom CAI, custom ground kit, JWT ecu, Fidanza flywheel, ACT clutch, Jeff92se Cobra 13" bbk with 300zx 30mm polished alum calipers.
Jeff92se is offline   Reply With Quote
Old 09-10-2004, 09:52 AM   #3
The Man is watching.
Send a message via MSN to maximase86
Yup, you can drop the tranny no problem from the bottom. However, I'd be sure you have another jack supporting the motor crossmember just in case...because if I remember right, you'll have to unbolt it to help get the tranny out. Also, be sure you have a couple other people help you out, it's a ***** to do yourself....especially with a tranny that is so heavy.
S
__________________
-Sarin
02 GLE - Majestic Blue/Frost Leather
6k D2R HID - AE/Clear Headlights - 3k HID fogs w/Lexus Capsules - Exterior LED's - AE Tails
Smoked Sidemarkers - 15% tint - G35 Coupe 18's - Short Ram Intake
Past:
86 SE - MOTM
97 GXE SC'er - RIP 10/12/08
http://www.nwmaxima.com
maximase86 is offline   Reply With Quote
Old 09-21-2004, 10:09 PM   #4
I got it out......BARELY!!
This past weekend I was able to get the tranny out of the Max. It can be taken out without removing the engine/trans as an assembly, but it is quite like a Chinese puzzle. I really wonder what it will be like on re-installation...Whew! I opened up the case on the old trans and found that a needle bearing assy had chewed up the face of the planet assy. where the one-way clutch is. Little baby needle bearings and chunks of race in everything imaginable, including the gear meshings. This is supposedly a NEW (and yes, it does look it by the virgin aluminum of the case) trans from Nissan. Everything inside was pristine except what was destroyed. What a shame. The previous original owner said she replaced it March 03 at the Nissan dealer. Considering the car has had only 10K miles since 2000, it might have had 2 or 3K on it since replacement, if that much. So much for "Nissan Quality". I have also done the "slide-bump" 1-2 shift fix on the used transmission I am putting in (I got it for $150 from a local yard).
http://www.sonnax.com/bulletins/tech/T3-EL-599-TS.pdf
Hopefully, I can get some longevity out of it as I really don't have $1000 to put into a rebuilt unit at this time. Of course, who really has 1000 "extra" dollars if you are driving a 17 year old Japanese car to begin with? Then again, maybe the millionaires became millionaires BECAUSE they drive 17 year old cars..... But I digress...
Old 09-26-2004, 09:52 PM   #5
Well, I got the tranny in this weekend. From a donor car as mentioned above. I don't care what the Chilton's, Nissan, or Haynes manuals say, it is entirely possible (thanks to all who responded!) to remove this beast and replace it without removing the engine. I actually think R and R of the entire engine/trans as a unit would be much more difficult! By the way, I believe Chilton and Haynes simply "stole" all of their information from the Nissan Service Manual as most of the pictures you see in those are directly from the FSM. The hardest part would probably be getting the bolts back in the side for the air intake system. Man, what a bugger! Tips? Take the entire shift cable loose from the shifter and carry out the entire cable, don't try to disconnect it from the tranny. Much too hard to get to. Get a transmission jack, sissors type with four swivel wheels. I got mine at Harbor Freight for $49. I could not have done it without this! On my car, I did not have to disconnect the steering knuckles, the half shafts came out without having to do that. The rear (near firewall) trans mount will have to be taken completely out, so remember that. You will need to remove the lower exhaust shield over the top of the bell housing to get to the top bell housing bolts.....I think that is all I can remember right now.....Oh yeah, the shift mod??? The verdict is still out. It goes 1-2 almost too quick.
Old 10-04-2004, 09:12 AM   #6
When you took out the cotter pins in the wheel assy were they reusable? Or should I just bust them out. I don't have a lot of cash on hand and don't feel like getting nickeled and dimed.
Drjmaxx88 is offline   Reply With Quote
Old 10-04-2004, 10:16 AM   #7
They usually are.....but I'd put fresh ones in....they aren't that expensive. Maybe
$3-5 for a box.
S
__________________
-Sarin
Past:
86 SE - MOTM
Old 10-04-2004, 10:35 AM   #8
Cool thanx.
Old 10-07-2004, 04:37 AM   #9
Quote:
I removed this mod due to it shifting too quick in my opinion. I like it much better now.....
Old 10-07-2004, 09:13 AM   #10
Speaking of tranys. Im thinking about getting a rebuild kit from this place.
http://www.bulkpart.com
Has anyone ever heard of,or used this place before?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
