08-29-2004, 09:09 PM
Intake pictures
Ok, I know it is not the prettiest thing, believe me I know. But I finally got around to doing the complete intake system.
I absolutely love the deep sound it makes when accelerating.
08-30-2004, 06:52 AM
Blown
looks good...what year is your Maxima? what is your small vacuum hose hooked to (where does it go from the mid pipe)?
08-30-2004, 07:52 AM
Is the pipe that goes into the fender part of the kit that Jeff made?
If not, where did you pick that up at?
Scott
08-30-2004, 08:35 AM
Blown
the one I have is the one jeff made
08-30-2004, 12:18 PM
I'm needing a caw
I use mandral bent pipe. Not home depot HVAC pipe. hehe
__________________
2003 G35 Sedan. Mods comin'
3-gen parts for sale
Sold Jan 14, 2006'
Mod list:
Eibach/Konis - ST front sway bar/Addco rear bar - Blemco rstb - Otto fstb
350Z 18" touring wheels.
Modified Cattman Y, Custom flex, 4-gen Carsound cat, Custom cat-back, Y2K muffler
Custom CAI, custom ground kit, JWT ecu, Fidanza flywheel, ACT clutch, Jeff92se Cobra 13" bbk with 300zx 30mm polished alum calipers.
08-30-2004, 04:17 PM
Yep, that is just heater piping from HomeDepot  I am Mr. Cheapo. I still have a little work to do actually, as I am not 100% statisfied that it is airtight. Just want to make sure it is.
Oh and my car is an 87. I did not trace where that tiny hose went but it was connected to the neck on the resonator box.
08-30-2004, 06:23 PM
the littel hose gos to the charcol canister. under the battery
08-31-2004, 06:35 AM
Blown
ok I know that is where sarin has his hooked up but when I was taking the stock intake apart the line going to the bottom of the charcole canister was not hooked to the factory mid pipe....it was hooked to the bottom of some contraption behind the intake close to the EGR. Thats why I am wondering if the 87 and 86 hook ups would be different. Unless I am mistaken what the charcole canister is, its under the battery right?
08-31-2004, 08:05 AM
Zellix, holy crap! What did you use to cut through the fender?? It looks like burning rock from space crashed through it! lol Good job man.
With all these posts on intakes, has anyone actually made a writeup on how do to it?
08-31-2004, 09:07 AM
The Man is watching.
Here is my writeup:
1. Remove motor...........
I'm getting behind on the write ups. I can do one for the install, as for the building of the CAI....well....Jeff might be able to do that.....maybe.
S
__________________
-Sarin
02 GLE - Majestic Blue/Frost Leather
6k D2R HID - AE/Clear Headlights - 3k HID fogs w/Lexus Capsules - Exterior LED's - AE Tails
Smoked Sidemarkers - 15% tint - G35 Coupe 18's - Short Ram Intake
Past:
86 SE - MOTM
97 GXE SC'er - RIP 10/12/08
http://www.nwmaxima.com
08-31-2004, 10:45 AM
Well, kinda like drjmax, I'm more interested in reading about it than actually doing it. Don't worry about it, I'm more curious. That and I've been assigned to the write-up patrol, nothing personal.
08-31-2004, 11:36 AM
hahaha! That's so true!
S
__________________
-Sarin
Past:
86 SE - MOTM
08-31-2004, 11:39 AM
I'm needing a caw
Dude is famous. Maybe he should buy a new car with 130hp also.
I could do a write up. The market for these things is about nil anyway. haha
All it is is getting some 3" mandral bent pipe and cut/weld to size. If look at the pics, it's pretty self explainatory.
__________________
Sold Jan 14, 2006'
Mod list:
08-31-2004, 11:56 AM
Blown
how much of a write up could you really do on installing an intake anyway....all I did was pull the stock stuff and then line the CAI up and went to town with a cutting wheel....the pushed and bent some stuff and put it back together.....their is my write up
08-31-2004, 01:59 PM
I dunno, it just seemed like from reading about all your exploits there were some questions as to what holes to put, what lines go where, and what type of filter to use. But, again, I just bought a $500 mountain bike so any mods have been indefinitely postoned, including an intake. Thanks anyway.
08-31-2004, 03:32 PM
I'm needing a caw
__________________
Sold Jan 14, 2006'
Mod list:
08-31-2004, 04:51 PM
I have some pics of the original design. http://www.cardomain.com/id/86maximase
S
__________________
-Sarin
Past:
86 SE - MOTM
BTW Sarin, you forgot a "w" in your www for your link :P
Well price-wise for my ugly but doesthejob setup, let me see.
Filter: $50 (Bet you can find cheaper on Ebay or such)
5 sheets of 9x11 foam with a sticky side: 50cents each ($2.50)
3" Heater pipe: $5
3" 45degree Heater pipe: $3
4 3" Hose Clamps: $2
Epoxy: $3
Drill, I already had, don't know price wise.
Piece of sheet metal for custom adapters: $4
Approx Total: $70
08-31-2004, 05:05 PM
3" Heater pipe: $5
Epoxy: $3
Approx Total: $70
Hearing a growl on acceleration: Priceless
sorry couldn't help it
08-31-2004, 05:15 PM
I'm needing a caw
What did you use for couplers?? Looks like a black T-shirt! hehe
__________________
Sold Jan 14, 2006'
Mod list:
08-31-2004, 05:19 PM
That is where the Foam sheets come into play
I went to good ol Wal-Mart and went to the craft section. Found these thin foam sheets with a sticky side. So I bought 10, (only used 5) and basically, took off the sticky protective sheet, then wrapped it around a 3" pipe (sticky side out for the first sheet), then stuck another sheet on with its sticky side facing in, then added one more sheet the same way. In the end it came to by a nice semi-strong cupling
A close-up.
08-31-2004, 05:24 PM
I'm needing a caw
LOL! That's just a little too  for me but it's all good.
08-31-2004, 05:45 PM
Well as long as it doesn't have the high-pitched riced honda sound, it is alllll good
08-31-2004, 07:39 PM
Fixed the link!
I can't believe you used foam! Are you having any issues with air leaks with that? My first worry is the unmeter air can get in through the foam after the MAF. I would rather use radiator hose or silicon breast implants....I mean couplers!  Either way, mad props for the custom work! Doesn't have to be pretty, it just has to function and make the car go!
S
__________________
-Sarin
Past:
86 SE - MOTM
08-31-2004, 07:58 PM
I think if you saw the foam in real life you would see it works good. And since I did use 3 layers of it, it should be pretty air tight. The part I am still not satisfied with about being airtight is the actual midpipe. But that will be an easy fix.
09-01-2004, 06:18 AM
Blown
Jeff,
What paint did you use to paint my intake? The reason I ask is because I painted the charge piping on my SC and it came out looking kinda black but not that nice glossy black like the ones you painted for me. Thanks for you help.
-Carson
Quote:
Originally Posted by Jeff92se
09-01-2004, 10:34 AM
I'm needing a caw
You don't have my sKiLlZ man! haha.
I used engine paint. Glossly black version. It's pretty tough and should stand up to any engine heat very well. Your CAI came out really nice too.
Quote:
Originally Posted by cardana24
Jeff,
-Carson
09-01-2004, 08:13 PM
just a suggestion for the cold air intake system to puta byepass air filter befor the MAF so the moret whont suck up water.
09-01-2004, 08:15 PM
or so when the cone air filter get dirty and cloged up. it will suck air from the byepass
09-02-2004, 10:56 AM
I'm needing a caw
Waste of time. If you submerge the front end high enough to hit the filter, you got bigger problems. ie.. drowning
Quote:
