Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Thread Tools Display Modes
Old 08-27-2004, 06:04 PM   #1
Urgent question: Fuel cutoff in case of accident? Override?
Is there anything that would automatically cut off fuel in case of an accident? I got nailed from behind and smashed my front a bit, but no leaks or anything. It turns over alright, electrical is fine, but it doesn't catch. Help! It's at my mechanic's, but he doesn't have time to look, and it's locked up for the weekend in 1 hour...
If it runs I'll take it home and nurse it to health.
electricsheep is offline   Reply With Quote
Old 08-27-2004, 06:17 PM   #2
If you got smashed from behind you may want to leave it at the mechanics. I haven't heard of an auto fuel cut. Check the fuel pump fuse, maybe its been dislogded. Don't start your car until its been thuroughly checked man. I know Its a huge inconvience but if there is something wrong it could mean your life.
Stay safe
P.S Ill double check the FSM When I get home. What year is your car?
Drjmaxx88 is offline   Reply With Quote
Old 08-27-2004, 06:29 PM   #3
Quote:
Stay safe
Thanks for the quick reply. 1985, Nissan Maxima SE. The story:
=>_=>_/_/_=>
=>_=>_=>_=>
=>_=>_=>|=>
=>_=>*=>|=>
Of course, I got sandwiched between a Ford F250 and a Jeep up front. Ford didn't hurt the car much (just punched a hole in the bumper), but the Jeep totally killed my hood and radiator. Jeep: Thanks for putting the bumper so high!
Old 08-27-2004, 08:33 PM   #4
The Man is watching.
Send a message via MSN to maximase86
Check to see if you popped a fuse for the fuel circuit. It not, I'm not entirely sure if the 85's even had an override switch or not.
S
__________________
-Sarin
02 GLE - Majestic Blue/Frost Leather
6k D2R HID - AE/Clear Headlights - 3k HID fogs w/Lexus Capsules - Exterior LED's - AE Tails
Smoked Sidemarkers - 15% tint - G35 Coupe 18's - Short Ram Intake
Past:
86 SE - MOTM
97 GXE SC'er - RIP 10/12/08
http://www.nwmaxima.com
maximase86 is offline   Reply With Quote
Old 08-27-2004, 10:59 PM   #5
Send a message via AIM to arsonist63086 Send a message via Yahoo to arsonist63086
no 85 max. didnt have an override swich.
what u shoul do is tell your "mecanic'' to take the pump out and do a bench test on it.
if it works then tell him chek continuiti on the fule pump curcuit, and if thes kool thel hime to chek the fule line for ristrictions. the fule pump from my knowing has 2 relays 1 in the engine bay by the battary (or is it in the fuse blok) and another in the trunk area. check all that
but since im telling u this y dont u do it your self, if u got the tools
arsonist63086 is offline   Reply With Quote
Old 08-28-2004, 12:09 AM   #6
Well, the car is currently behind a gate at my mechanic's shop, guarded by a mean motherf*cker of a Rottweiler named Otis. Otis does not like people. Now even if I could get past Otis, I might have some trouble getting the car through the closed gate, so yeah, I'll need to wait until my mechanic looks at it on Monday. I was hoping that if it's a quick fix, I could have backed it out before 6pm.
Ah, well...at least there's some consolation in knowing that there are potential quick fixes.
Old 08-28-2004, 10:10 PM   #7
Send a message via AIM to blackmaxima88
fuel cutoff switch.... that's mainly a ford thing... yuck.
anyway, from looking at numerous wiring diagrams for numerous projects, I think I can safely say these cars (or at least my 88) don't have a fuel cutoff. however, the fuel pump relay is in the trunk, in the very back, near the tail lights. if it's not there, it's near the stop/tail warning light sensor. it's very possible that this relay (brown, I think) got smashed or jarred or unplugged. this relay controls the fuel pump, so it won't work without it.
Dan
blackmaxima88 is offline   Reply With Quote
Old 08-29-2004, 11:50 AM   #8
Send a message via AIM to Niku-Sama
mabe the shock broke the pump it self some how
Niku-Sama is offline   Reply With Quote
Old 09-04-2004, 11:42 PM   #9
It was just the ignition coil. The plug at the bottom got disconnected. Now I need to find a right headlight assembly. Anyone got a spare?
Old 09-05-2004, 12:27 AM   #10
lol......
that should have been the 1st thing the ''mechanic'' cheked.(for spark at the plugs)
lol
Old 09-05-2004, 12:33 AM   #11
tell the mechanic to replace your alternator gasket, water pump solenoid, and radiator bearings. then sit back and wait for a month while he tries to find them.
Well I'm glad you got it fixed. good luck with everything else.
Dan
Not a Ford fan? Neither is Newberry Township.
Old 09-05-2004, 01:10 AM   #12
Quote:
you and me both, a dog broke mine
try this place:i just havent gotten arround to ordering yet....and yes this is the cheapist place because the dealership will want $208 for just the glass front and the peice right behind it. no mounting brackets, adjustment screwes, nothing
http://www.discountcarlights.com/dc7...sanmaxima.html
Old 09-05-2004, 09:38 AM   #13
Send a message via AIM to turboast4 Send a message via Yahoo to turboast4
Dan
Yea and make sure he tops off the headlight fluid when the new ones are put in. He might also need to bleed the trans filter after a crash like that.
turboast4 is offline   Reply With Quote
Old 09-05-2004, 02:01 PM   #14
I have a spare passenger side headlight for 85-86 style cars, without the bracket.
S
__________________
-Sarin
Past:
86 SE - MOTM
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
