Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 03-15-2006, 06:20 PM   #41
I love lamp.
maximase86's Avatar
Send a message via MSN to maximase86
There are 3 bolts that hold that in after you removed the axle nut and cotter pin. Its kinda of a PITA to get to.
S
maximase86 is offline   Reply With Quote
Old 04-23-2006, 10:54 PM   #42
that link doesnt work
joe85max is offline   Reply With Quote
Old 03-23-2007, 12:22 PM   #43
isn't there a weird thing about the reverse lights too and vacuum lines?
barneyboy01 is offline   Reply With Quote
Old 11-17-2007, 01:30 AM   #44
4.5 Gen & 3rd Gen
93altima's Avatar
lol
__________________
1993 Maxima GXE 1995 Maxima GXE
As A De-K: 11/28/08 14.8 @ 93.8mph
As A 3.5: 03/13/09 14.1 @100mph
HPaddictionz
Team all out Nissan
93altima is offline   Reply With Quote
Old 12-19-2007, 09:09 PM   #45
2nd Gen Boostinator
Big_E-Dog's Avatar
i think that my tranny is dieing so what all do i need
obviously:
tranny
pedals (brake and clutch)
clutch fluid cyllinder
clutch
flywheel
shifter
shifter rods
thinking about getting a short throw, is it true that we can use one from an altima, if so ima get it
prolly gonna get a 2nd stage clutch
anything else ima need??
__________________
CUSTOM HEADLAMPS/CARBON FIBER/FT&RTSB/OIL COOLER/LED'S/VG30ETT/PATHFINDER INTAKE MANIFIOLD/2.5" EXHAUST/NISMO MUFFLER/HKS TT, BOV, BOOST GUAGE/Q45 BBK/K&N/2x GARRETT T-25/NISTUNE/......
Big_E-Dog is offline   Reply With Quote
Old 03-02-2008, 10:53 PM   #46
2nd Gen Boostinator
Big_E-Dog's Avatar
ok im gonna do th e5 speed swap, went to the jy aand can get everything needed to do the swap for 250. i took off the pedals was time consuming, had to drop the steering column take out the lower dash which consists of taking part of the upper dash off as well, the pedals come out as a somplete assy brake and clutch 8 bolts hold it in, the i removed the clutch cylinder(2 bolts a pin and a r clip) un fixed the brake pedal from the master cylinder (1 pin and a r clip) then i took off the shifter(4 bolts under the car past the heat sheild 5-6 10mm bolts) past the exaust (4 17mm bolts) pretty much everything on the 5 speed the auto has mounting holes for didnt kno it was this easy. got all the motormounts. clutch cylinder lines, cylinder, cylinder cooler, flywheel, clutch, pressure plate. going tomorrow to pick up everything but the transmission and start installing the pedals.
got a few questions tho for the ppl that kno more than me
is the wiring harness base like the car is (meaning does it have all plugs like the car has all mounting holes)
whats my lsd options for the 5 speed
going to do this in the up coming week so ill have pics for all as always in this thread thanks in advance!
__________________
Old 03-04-2008, 09:03 AM   #47
2nd Gen Boostinator
Big_E-Dog's Avatar
went and got the gear tranny as well (ebay has been good to me) cleaned everything but the tranny thats next today, will open and inspect gears and crap. engine i got it from was seized and had 299xxx miles oin it but the tranny has silicone in the grooves so i guess it was rebuilt at one time(hopefilly to my benifit) the clutch thingy that the clutch mstr cylinder thingy makes work is new as well SCORE!! hope the reanny is as well.(cant remember the name of it right now).
in the pic is:
tranny (on the lift)
clutch, flywheel,, clutch cover
shifter w/linkages
pedals
clutch mstr clndr w/ clutch thingy
dust sheilds
clutch thingy cooler
and both motor mounts
__________________
Old 03-04-2008, 07:11 PM   #48
2nd Gen Boostinator
Big_E-Dog's Avatar
ok went in the tranny to inspect the gears, and lemme tell ya i dont think that god is taking prayers for a set of gears like these in a 299XXX mile maxima. check em'!
the new slave and cylinder (off of the donor carfrom the junkyard!)
gonna see if i can find a lsd from a stanza and throw it in if not then ill finish it up next week with my carbon fiber pedals and shift knob. more install pics to come.
__________________
Old 03-07-2008, 09:55 AM   #49
2nd Gen Boostinator
Big_E-Dog's Avatar
update pics
dont have the tranny in as of yet but i do have in the pedals, was a pain in tha a$$ because of these lil dagnabbit clips and the fat wiring harness took off the 7 bolts (4 nits and 3 bolts) and had to work and giggle it out. the other one slid right into place and bolted up like a champ. connected the slave cylinder, and the brakes mstr cylinder. painted the motor mounts, connected the clutch slave, got the replacement boots to the clutch fork and yoke coming in at nissan on saturday (26 bones for both) so now im just waiting.......
the pics
clips of eternal damnation!
location of clips (holes by the big a$$ wiring harness)
__________________
Old 03-07-2008, 09:59 AM   #50
2nd Gen Boostinator
Big_E-Dog's Avatar
update pics
had to remove some ducting right on top of the steering wheel..
my dash..
your dash dosent have to look like this but since i had a lot of stuff off i had some lights to replace(still dont work)
__________________
Old 03-07-2008, 09:59 AM   #51
2nd Gen Boostinator
Big_E-Dog's Avatar
pedals installed
just wondering if this counts as rice now since i have 3 pedals and only two of them work?!?!
__________________
Old 03-07-2008, 10:02 AM   #52
2nd Gen Boostinator
Big_E-Dog's Avatar
forms from nissan and others just incase any body needs part numbers
__________________
Old 03-07-2008, 12:19 PM   #53
well at least the input shaft bearing is still in one piece. if you still have it apart could you measure the differential or see if it's marked as to which one it is (R180 or R200 or?) please
vernk is offline   Reply With Quote
Old 03-07-2008, 03:16 PM   #54
2nd Gen Boostinator
Big_E-Dog's Avatar
sorry bro its put back together now maybee someone here knows or you could call your nissan dealer to see, pu tit back together because i deciced not to go with the lsd for now.
__________________
Old 03-30-2008, 12:01 PM   #55
2nd Gen Boostinator
Big_E-Dog's Avatar
updates...
had to seap out the motormounts..
with the ones from the 5psd tranny...
you really have to replace the front one because tha rear is the same but i swapped it out cuse i painted it.
installed the clutch line bracket
__________________
Old 03-30-2008, 12:05 PM   #56
2nd Gen Boostinator
Big_E-Dog's Avatar
custom tool time...
had to fab this up because i had no way to really hold the flexplate for removal. its a 2 way device i made out of a spare flexplate i had lying around. cut it, welded a wheel stud bolt to hold the bounting bolt into place, screw it into the block and your good to go. great for the torque sequence for the flywheel as well.
put in the flywheel, cover and tranny.
__________________
Old 03-30-2008, 12:12 PM   #57
2nd Gen Boostinator
Big_E-Dog's Avatar
also while im here i also had to do this to the steering rack for the 300zx oil cooler setup. moved it over like 2 inches and welded it to the rack.
also when you get the 5 spd tranny ge tthe 5 spd flywheel bolts there is a major difference...
finished shots of inside...
cut and rewelded the shifter to shorten it w/ carbon fiber knob, waiting for my shift pattern to come from nismo theyre on back order i have 2 bought up, there was a lotta energy drink in that cup to keeep me goin lol.
__________________
Old 08-31-2008, 06:02 PM   #58
Send a message via MSN to jeff litchfield
Anyone done it on a 1st gen diesel. I dont know what flywheel to use and I feel pretty stupid having to ask
__________________
jeff litchfield is offline   Reply With Quote
Old 10-09-2008, 05:05 PM   #59
maximagtrkid is offline   Reply With Quote
Old 10-09-2008, 05:06 PM   #60
yep
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
