Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Thread Tools Display Modes
Old 04-02-2001, 09:49 PM   #1
spiros
Where would I find the codes for my Maxima to use the keypad on the doors ?
UPDATE ** Thanks for your replies. I found the code in the trunk and have since reprogrammed my door locks. One final question, is it possible that on the 1987 models you were unable to roll down the windows with the key codes ? There is no "WD 5/6" as per the tutorial. There is a "TRK 1/2" ... don't know what that one does !?
Thanks again !
Spiros
Old 04-07-2001, 06:21 PM   #2
akakaren
Go to
http://www.kalebonline.com/maxima/
look in the tutorials, it tells you exactly what to do, except for as a 2nd generation maxima your "box" that your master code is on is in your trunk, under where the speakers are, so climb in and look up.
good luck
if this doesn't help, email me at akakaren@sprint.ca
Old 04-08-2001, 06:58 AM   #3
Send a message via AIM to maxima561
you have to get that 7 digit number off of the box in the trunk. it will start with an S i think.
__________________
1988 Silver, Silver tint, custom RSB,CAI,Dynomax Exhaust,Shift kit, High Stall Converter, ST springs, 2 solobaric 15's,800.2, 250.2, 149.2db at last comp.17x7 205/40/zr17
maxima561 is offline   Reply With Quote
Old 04-11-2001, 04:48 PM   #4
robbie
door pad #
yes, theere is a seven digit code that begins with S then number. it is located on the keyless entry control box which should be located in in rear of maxima. in the wagon its found just behind the seat by pulling out the hard foam casing for tools. then once you get the number just shut all doors, press the ST button then the seven digits. at this time a constant beep will sound. this is when you press in your desired personal code.
okay i hope this helps.
Quote:
Old 09-22-2003, 06:58 PM   #5
That is really weird!
Why in the heck does the drivers door not work on its own? I take it from all of the post that the drivers door does not have a "power" door lock motor on it?
Thanks,
Duffy
duffy is offline   Reply With Quote
Old 09-22-2003, 09:23 PM   #6
The Man is watching.
Send a message via MSN to maximase86
Ummm, that's only true for the 85-86 SE's if I remember right since it doesn't have an lock actuator nor that ability to unlock all doors with the key (you have to use the switch instead). The GL's and GXE's with keyless entry should work for all doors including drivers, and the 87-88 SE's have the ability to unlock all the doors with the key.
maximase86 is offline   Reply With Quote
Old 09-23-2003, 08:54 AM   #7
Send a message via ICQ to MaxWgn Send a message via AIM to MaxWgn Send a message via Yahoo to MaxWgn
My 87 GXE wagon unlocks all doors, including the hatch, with the key, in either dr. or pass. door, but will only lock all doors from the drivers key...
MaxWgn is offline   Reply With Quote
Old 09-24-2003, 06:14 PM   #8
TRK will pop your trunk. And on my 88 GXE the drivers door would open if i entered the code without the key, and if i press the unlock button on the keypad then all the other doors would open. And if you opened the drivers door with the key all the doors would unlock, which was a stupid feature IMO. Would've been better if it only opened the drivers and if you turned it again it would open the rest.
Slider is offline   Reply With Quote
Old 09-24-2003, 06:49 PM   #9
Another question!
First, I want to thank everyone for their responses.
I tried to get the door panel off today to check out the locking mech. on the drivers door and could not get the inside handle loose? Any ideas? It doesnt look or work like the one that is in my Chilton's manual for a 85 Max! I tried six ways from Sunday to get the handle or the plastic surround off but to no avail! Help!!
I got the key pad working and it will unlock all the door EXCEPT the drivers. Using the key ONLY unlocks the drivers door. Puzzling!
Last question, how do I know what model I have? No where on the car does it say SE or anything like that, only Maxima and of course Nissan. I don't have the owners manual, it was lost about 50,000 miles ago!
Thanks again for all the help!!
Old 09-24-2003, 08:15 PM   #10
What color is the trim? Is it chrome or black, also since you have an 85....is it an auto or stick? SE's have black trim, and in 85-86 all SE's were sticks, and GL's were autos.
S
Old 09-25-2003, 05:56 AM   #11
Trim Level
I must have the GL trim level. I have mostly black trim with just a little chrome only on the outside. And its an auto. I have never owned an Nissan, but really like this car. In it time, this car was a sharp one, now at 135,000 miles, it run like new, and shows the wear of maybe 50,000. You guys are good to help and all, Ford Truck World Forum could take a lesson or two from this Forum!!
Duffy
Old 10-06-2003, 10:36 AM   #12
how about for 85 wagon?
where do I find the cod for wagon?
Quote:
Originally Posted by akakaren
Go to
good luck
cykh55 is offline   Reply With Quote
Old 10-10-2003, 02:03 PM   #13
Send a message via Yahoo to keith_u
Quote:
It is in the back under a panle of some sort on the floor it looks like, I will scan in a shot from this book I have so you can see.
keith_u is offline   Reply With Quote
Old 10-10-2003, 02:12 PM   #14
Quote:
Ok maybe I won't put in a pic for you can do that in here lol sorry
Old 10-26-2003, 04:34 PM   #15
I have just bought a 1985 wagon.. I cant seem to find the code anywhere in the back.. I took out that metal piece right behind the back seats, and it just had a bunch of electrical fuses/wires.. i couldnt find a code inscribed on anything..
tahnks for any help you provide...
btw.. im LOVING this car.. i had a 89 accord before i was run off the road into a utillity pole.. this car I stole for 1200$ (he was asking 1550$) .. ALL the electric 'goodies' work, the engine is CLEANCLEANCLEAN only has 158k on it, is powerfull as all hell and has the smoothest, steadyest<-? ride i have been in.. (ownd a 92 celly, 90gts celly, 86 mustang, 89 accord)
without a doubt, this car even tho it's the OLDEST i've ownd, it is the best running.. top end hasnt been touched yet (i wnat to change the oil first) but i know it will hit 110/120 .. so much power and pedal left @ 80mph it's not even funny!
anyway.. great board and ill be comming back ..
6re99 is offline   Reply With Quote
Old 10-26-2003, 07:07 PM   #16
You are in the right area it is under that panel and to the far right side if you still cant find it sned me an e-mail and I will send you a pic from this book I have that will show you. keith_u@yahoo.com
Keith
Old 05-25-2008, 11:17 PM   #17
i only get a 6 digit #
i got an S followed by 030185 can some one tell me how to do it.. i got an 87 maxima in mint azz condition
slacker4_1 is offline   Reply With Quote
Old 05-25-2008, 11:25 PM   #18
Quote:
If memory serves me right it is a 9 digit code. but once you get the right code you hit the start button on the keypad and then punch in the 9 digit code after that it will beep for a few seconds and while it is beeping you need to put in your code but it can't be in order IE 1234 i don't think you can use the same key 2 times in a row. Once you get that done then hit the start key again and try your 4 digit code and if it worked the drivers door should unlock if it is locked (make sure you have your keys out with you lol) then you will have a few seconds to hit the button to unlock all doors and even pop the trunk.
Hope that helps ya
Keith
Oh and man do I miss my old MAx she was a great car, motor gave up at 300,000 miles so i can't complain lol
Old 05-25-2008, 11:28 PM   #19
Thanx alot
so the # i got it wrong?? it's in the trunk right and starts with an S right
Old 05-25-2008, 11:31 PM   #20
yeah it is in the trunk. there should be 3 boxes the one in the middle should be the security box ,on that box there is like 3 or 4 sets of numbers and the 9 didgit set is the one you need
Old 05-25-2008, 11:33 PM   #21
Thanx again
i'll check it when i get home and tell you how it goes thanx man
Old 05-25-2008, 11:33 PM   #22
no problem good luck with it.will check in tomorrow to see if ya got it
Old 05-26-2008, 07:05 PM   #23
2nd Gen Boostinator
Big_E-Dog's Avatar
im coming to your house and im gonna sit in your maxima since i have the code to get into it, and ima change your code again as well to something youll never think of...LOL!
__________________
Xenon projector headlamps/carbon fiber/ NGK plugs&wires/60mm TB/FTSB&RTSB/BMW oil cooler/LED tails and turnsignals/300zx turbo motor w/intercooler/2.5 in exaust/HKS turbo timer&bov/300zx calipers slotted&drilled rotors/K&N filter/2x T25 garrett turbochargers
Big_E-Dog is online now   Reply With Quote
Old 05-26-2008, 10:21 PM   #24
Holy old thread...
__________________
-Sarin
02 GLE - Majestic Blue/Frost Leather
6k D2R HID - AE/Clear Headlights - 3k HID fogs w/Lexus Capsules - Exterior LED's - AE Tails
Smoked Sidemarkers - 15% tint - G35 Coupe 18's - Short Ram Intake
Past:
86 SE - MOTM
97 GXE SC'er - RIP 10/12/08
http://www.nwmaxima.com
Old 06-02-2008, 08:09 AM   #25
Sweet............locked the keys inside a maxima and it had a dead battery.
Did you guys know about the driver's side signal light in the bumper has a provision for you to power up the systems from there so you can type in the code?.........and that it actually works?
sweet.
HowlerMonkey is offline   Reply With Quote
Old 06-18-2008, 09:46 AM   #26
Sticker in the trunk
Mr3Putt is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
