Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Thread Tools Display Modes
Old 04-30-2004, 08:54 PM   #1
Please help w/87 maxima problem
I have a problem: When I start my car it starts right up, then the rpms dive for a minute and there is alot of putting from the exhaust for lack of a better term. As the car warms up it goes back up to normal idle but the exhaust continues to put intermitently at idle. When I give it gas it runs great but when it returns to idle, more rough putting from the exhaust. I have a new coil, all injectors have been cleaned and checked at the shop, new plugs, wires, timing belt cap, rotor and the distributor has been cleaned and checked.
Can anyone help me get to the bottom of this problem?
Thanks so much
87maxdr is offline   Reply With Quote
Old 05-01-2004, 04:59 AM   #2
Send a message via AIM to trinitykt133
you may want to run over vacuum lines and see if you have a leak. if its a small hole they may be sealing up when they get hot. also if they are fine then when is the last time the o2 sensor was replaced? they say they only last until 30,000 or so but if its been more then 60,000 it may be due. a quiet ping every once in a while from the exhaust when warm is normal. also if you can try to take a look at the cylander head temperature sensor. its located between the timing belt covers on the right side of the water pump. its hard to get to without removing the top timing belt covers but you may be able to get a long rod and poke at it to see if its lost contact. if you look down beside the distributer cap you may be able to see it. its common for the connection to corrode and lose contact.
-matt
trinitykt133 is offline   Reply With Quote
Old 05-01-2004, 07:11 AM   #3
Thanks. I'll check those.
Old 05-03-2004, 05:14 AM   #4
Blown
Send a message via AIM to cardana24
I had a similiar problem when I first got my 87....I replaced the AAV/air bypass valve and it fixed the problem....also its a good idea to go ahead and replace your vacuum lines.
cardana24 is offline   Reply With Quote
Old 05-07-2004, 05:45 AM   #5
I have the exact same problem... there is a person on cardomain that has a way to fix it with just screwing a screw into the aiv or avv vavle i forget which one it is... but the vavle is on the back of the intake collecter and its shaped kind of like a tordado laying sideways with a plug at the end of it.. lol.. The valve is there to let extra air in past the throttle to keep the rpms up a little bit until warm.. but once it warms up the springs relax and close the valve back off. Does it only do it when its cold?
Kman87240 is offline   Reply With Quote
Old 05-07-2004, 07:01 AM   #6
Blown
the fix that you are refering to is in a sticky at the top of our forum...I looked at that and decided to buy a new one....I got it at importedcarparts.com for $65
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
