Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Thread Tools Display Modes
Old 04-25-2004, 05:11 PM   #1
Send a message via AIM to trinitykt133
computer question???
how long do i unhook the battery to do a full reset on the computer.
i heard there was 2 different resets one which takes about 15 minutes and a full reset takes 12 hours. is this true?
-matt
trinitykt133 is offline   Reply With Quote
Old 04-25-2004, 08:52 PM   #2
The Man is watching.
Send a message via MSN to maximase86
Interesting, I would assume the 12 hour reset would be the better of the two. I've never honestly had a need to reset my ECU like that, but I would assume the longer the better.
S
__________________
-Sarin
02 GLE - Majestic Blue/Frost Leather
6k D2R HID - AE/Clear Headlights - 3k HID fogs w/Lexus Capsules - Exterior LED's - AE Tails
Smoked Sidemarkers - 15% tint - G35 Coupe 18's - Short Ram Intake
Past:
86 SE - MOTM
97 GXE SC'er - RIP 10/12/08
http://www.nwmaxima.com
maximase86 is offline   Reply With Quote
Old 04-26-2004, 01:45 PM   #3
After about 15min your radio gets reset. If you unplug the battery for five min the radio retains all the settings. I had to reset my old ECU a couple of time my teacher said the majority of cars take about 30 mins at the most. My max usually only takes 15min then its reset.
I could be wrong, but for mine it works.
Drjmaxx88 is offline   Reply With Quote
Old 06-29-2004, 04:26 PM   #4
what are the bennifits of complete reset, and how do you know you should do it??
6re99 is offline   Reply With Quote
Old 06-29-2004, 10:51 PM   #5
Send a message via AIM to blackmaxima88
I dunno, my guess is it forces the ECU to "forget" its settings and trouble codes, which are stored on a PROM (programmable read-only memory) type chip. I would also assume that there are capacitors on the computer to save this information during a momentary loss of battery voltage. so leaving the battery disconnected for a good bit of time is necessary.
Then once all is cleared, the car is started and the computer resorts to its factory default settings, instead of compensating for a problem. from what I hear, the car will run rough for the first few miles until the system re-learns, so to speak, all of the sensors.
I've heard this works wonders on cars on a previously posted thread in this forum. I did this on my accord one time, left the battery disconnected overnight, and I actually did notice an increase in performance. (for a honda.) but I guess it's different with each car and each scenario. if you have a bad O2 sensor or EGR valve, this won't fix it. problem is, these 1st and 2nd gen maximas don't have a "check engine" light to let you know the ECU has detected a problem. you'd have to go by instinct, then read the diagnostic code from the computer when you suspect a problem.
Dan
blackmaxima88 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
