Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Thread Tools Display Modes
Old 04-25-2004, 02:34 PM   #1
bypass hose replacement
Has anyone replaced the small coolant bypass hose next to the thermostat housing? Mine started leaking the other day so I'm in the process of trying to replace it this weekend. The two pipes that the hose connects together are about 1/4 inch apart so I can't get the old hose off without cutting it (not a problem) but then I won't be able to slide a new hose on. I tried to remove the pipe by the thermostat housing but can't get anything but a cresent wrench on the fitting. I went out and bought a set of crowfoot wrenches but the largest size was a 22 mm and that is too small. The crescent wrench is rounding off the nut that screws into the block and it hasn't moved at all. I've removed the belts and the thermostat housing and I'm hoping that I don't have to remove the timing belt covers and timing belt to get a better grip on it. Does anyone know what size the nut is because maybe the proper size crowfoot wrench might be the answer. I realize that the pipe has been screwed in for 18 years and is probably a little reluctant to come loose. Any positive suggestions would be appreciated (so Deacon, if you're out there don't bother to reply.) Thanks for your help.
my86max is offline   Reply With Quote
Old 04-25-2004, 08:48 PM   #2
The Man is watching.
Send a message via MSN to maximase86
Are you refering for the coolant lines the run to the passenger cabin? I'm actually not familiar with which one your talking about.
S
__________________
-Sarin
02 GLE - Majestic Blue/Frost Leather
6k D2R HID - AE/Clear Headlights - 3k HID fogs w/Lexus Capsules - Exterior LED's - AE Tails
Smoked Sidemarkers - 15% tint - G35 Coupe 18's - Short Ram Intake
Past:
86 SE - MOTM
97 GXE SC'er - RIP 10/12/08
http://www.nwmaxima.com
maximase86 is offline   Reply With Quote
Old 04-26-2004, 09:34 PM   #3
S
No, there is a 2 1/2 inch hose that connects to the bypass from the thermostat to another pipe that connects to the block. It's mounted under the fuel pressure valve. I stopped by the local Nissan dealer and spoke with one of the mechanics today. He couldn't remember the exact layout so we looked at the FSM. The options are to (1) use silicone on the hose and try to slide it on - doesn't work as the gap between the two pipes is about 1/4 inch and the hose doesn't bend that much (2) remove the fitting under the fuel pressure valve and slide the hose on then reconnect the fitting (3) remove the thermostat housing mounted to the block and then reconnect. There is absolutely no room to get at anything. I've got the belts, thermostat, water pump pulley, and overflow container removed as well as plug wires, vacuum lines, etc. It looks like I'll have to remove the cruise control vacuum container to get at the bolts that hold in the fittting that mounts to the block. There's an O-ring that mounts on the back of the fitting that the dealer didn't have in stock. There is also an O-ring that mounts to the pipe in the back of the thermostat housing and it bolts from the back as well. I don't even know how to get at that. This tiny hose is taking longer to replace than the timing belt did and is much more frustrating . So, I'll keep plugging away at it and hopefully get it done before the end of the week.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
