Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Thread Tools Display Modes
Old 04-24-2004, 10:44 AM   #1
Send a message via AIM to RegulatorJP Send a message via Yahoo to RegulatorJP
Idling problem
It's not that the car idles too low, it idles too high. Like about 5000 rpm high. I've checked the throttle position sensor and that works fine. It's not the cable, so pretty much I'm totally lost. Anyone know what could be wrong?
JP
RegulatorJP is offline   Reply With Quote
Old 04-24-2004, 12:05 PM   #2
The Man is watching.
Send a message via MSN to maximase86
Bad spring on the TB? Sounds like it's getting stuck at close to WOT.
S
maximase86 is offline   Reply With Quote
Old 04-26-2004, 05:26 AM   #3
Blown
Send a message via AIM to cardana24
I had a similar problem, but I dont think mine ever got to 5,000...it happened when I was trying to get to the oil filter from the passenger side of the engine bay.....I was leaning on some of the throttle cables that were going into that thing (thing with black cover on firewall where throttle cables go?), and I had pulled one of them out a little causing it to idle high.....I fixed this by pushing the cable back into the 'thing'....sorry for the lack of a better word but I dont know what it is called.
cardana24 is offline   Reply With Quote
Old 04-26-2004, 09:50 AM   #4
whoa!
Maybe it's the FICD:Fast Idle control device
Run your car and unplug the harness for the Idle.
It's left of the air regulator and the PCV valve. Use a screw driver to adjust the FICD I think its the top one but I could be wrong,Check the chilton or haynes manual first so you get the right one.
Drjmaxx88 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
