Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Thread Tools Display Modes
Old 03-25-2003, 11:44 PM   #1
Q: How do you remove the instrument panel?
Hello!
I've got an 2/88 Maxima SE with 177000 miles in it. (no major overhaul yet)
(manual 5 speed transmission with mechanical speedometer)
Recently I noticed that the speedometer needle in the morning doesn't work at all, but as the car warms up it starts climbing and it keeps shaking way below the actual speed value.
I decided to replace the speedometer cable but I got stuck at the last phase of removing the instrument panel.
Question:
Do I have to disconnect the speedocable from underneath the dashboard before trying to remove the instrument panel(it looks like a major pain), or I can pull the instrument panel out enough so that I can reach the end of the cable and disconnect it that way?
What else can hold the instrument panel back?
- I already have the black faceplate with the blower grills removed,
- the panel with all the switches and the cutout for the stereo,
- the lower panel above your legs and the fuse assy.
- I've also disconnected the cable harness of the instrument panel behind the fuse box.
BUT, when I am tring to lift the instrument panel out I can feel a strong resistance from behind. I am assuming that the speedocable is the one that prevents it from sliding out but how the heck I can disconnect it from it?
(Btw., I have already checked the other end of the speedocable on the top of the transmission, it was a bit loose, but tightening it didn't make any difference.
But I noticed, that when I separated the cable from the head, I was able to pull the cable out of the houseing about an inch. (I didn't try it more, probably I should've.)
The new cable that I already purchased won't allow any longitudinal movement of the cable inside the cablehousing.)
Geza
__________________
2/88' Maxima SE (white, 5 sp M/T)
[230000 miles, original engine]
Reseda, San Fernando Valley, CA
Geza is offline   Reply With Quote
Old 03-26-2003, 12:27 AM   #2
The Man is watching.
Send a message via MSN to maximase86
Re: Q: How do you remove the instrument panel?
You'll have to disconnect the speedometer cable from the transmission. Then you have to loosen the screws on the bracket on the firewall and feed the speedometer some slack. There is also a little rubber piece just below the bracket that needs to loosened. When you pull out the instrument cluster, you need to pull it from the left side, and disconnect the wire harness. If your harness is like mine, it will be a PITA to take off. Once you get that off, then you can move the instrument cluster out more to remove the speedo. After you get that, if should come out. While you have it out, I suggest you replace all the bulbs for the cluster....the big bulbs will be easy to find...the smaller bulbs will be harder to find.
S
__________________
-Sarin
02 GLE - Majestic Blue/Frost Leather
6k D2R HID - AE/Clear Headlights - 3k HID fogs w/Lexus Capsules - Exterior LED's - AE Tails
Smoked Sidemarkers - 15% tint - G35 Coupe 18's - Short Ram Intake
Past:
86 SE - MOTM
97 GXE SC'er - RIP 10/12/08
http://www.nwmaxima.com
maximase86 is offline   Reply With Quote
Old 03-26-2003, 01:09 AM   #3
Hello maximase86,
Thank you very much for the quick and detailed reply! I will finish working on my speedocable problem on the weekend.
Oh, and thanks for the extra tipp on the bulbs too!
(Although I am not sure if I should replace them because I have the instrument lights brightness dimmed, (set to approx. 30% of its total capacity) just because at night I prefer to have my instrument lights not to stand out from the city lights that enter through the windshield.) (not mentioning the total darkness on I-15 between Corona and San Diego.)
Thanks again for the solution!
Geza
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
