Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Thread Tools Display Modes
Old 03-25-2003, 01:04 AM   #1
Send a message via AIM to claytonc
81 wag. brake upgrade
I have an '81 5spd wagon, mostly stock. I'm experiencing some pretty bad braking problems consisting of the fronts locking up with the rear not really working. Does anyone have any input swapping the drums for discs on the rear or possibly any other alteration that would increase braking ability? The e-brake is pretty useless as well.
Clayton
claytonc is offline   Reply With Quote
Old 03-25-2003, 10:01 AM   #2
Send a message via Yahoo to Bleach
Are the rear drums self-adjusting? Maybe all you need is to adjust your brakes?
Make sure the shoes are adjusted out so they rub just a little bit. That'll make sure there is no slack. With the rear brakes slowing the car you should get 100% better braking power.
On the inside of the hub, just under the axel there might be a little hole sometimes plugged with a rubber piece. Remove that and you can see a little gear. A narrow screwdriver (bent at a slight angle) is what I used to spin that gear. turning it up or down adjusts the shoes in and out. I forgot which way, but you should be able to figure it out. Turn the drum by hand after a few turns to see if you can feel it getting tight.
Putting new seals in your rear brake cylinders is really cheap and also you might want to check to see that the rear brake lines are bled properly. If the hand brake doesnt' hold good though, that tells me the shoes aren't adjusted out far enough. Maybe you just need new brake shoes too.
__________________
Bleach is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
