Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Thread Tools Display Modes
Old 03-18-2003, 02:39 PM   #1
rcy
Washer pump..
A few days ago I notice the pump was squirting the washer fluid lower and lower. Today, there is no pump at all. I'm assuming I need a new pump (checked fuses , fluid level etc.). Unfortunately, my Haynes manual doesn't show squat in regards to the pump. Anyone know where it is and how easy it is to replace? BTW, it's an '88.
Thanks.
rcy is offline   Reply With Quote
Old 03-18-2003, 03:42 PM   #2
I don't have my Chiltons on hand, but if I remember correctly it is bolted onto the back of the engine compartment, on the firewall. If that's it, then it should be a snap to replace. Open up the hood and see if you can trace the washer lines to it. I'll give you a definitive answer once I get access to my manual.
-C-
Charles Bisel is offline   Reply With Quote
Old 03-19-2003, 02:18 PM   #3
rcy
Quote:
-C-
Thanks, I'd appreciate it. I traced the lines, but didn't see any pump (I'll go check again), so I was assuming the pump was integral to the reservoir, or mounted near it. This is a pain, because it looks like the reservoir is somewhere in the wheel well (hard to get at). If you could check your Chilton's and let me know where the pump is, it would help a lot.
Old 03-19-2003, 04:08 PM   #4
rcy
Quote:
Disregard...I found it. It's mounted on the washer reservoir in the wheel well. The connection was so rusted that when I touched the connector, it just fell off the pump. Still, I suppose that can be expected after 15 years. I'm going to install a universal pump - $17.99 at Canadian Tire.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
