Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Thread Tools Display Modes
Old 03-13-2003, 09:44 AM   #1
Out of time? or something else? Help
Well,
My car died while driving as some of you all read a few weeks ago.
Turned out to be the crank angle went bad. I got a used distributor from a junkyard(dude, the car has 245K, hehe, no need for a new one) and took it to a local shop to have them install it cause of lack of time.
Well, when I go up a hill or put and kind of load on the engine, it sounds like multiple misfires, definately loses power like a timing thing, what do you all think? Could they have it off a tooth, anyone got a distributor off a tooth and had these symptoms?
I had them repair and reinstall the starter too cause it was eating up the flywheel, but thats all I had them do, and I didnt have this problem before on this car. I had it do that on my eclipse, but I have an accel DFI on that car and it was just loading up on fuel.
edit: the car seemed to drive fine for a day or 2, but last night when i was banging on it it started the timing/misfire stuff like it jumped a tooth, or the distibutor slid a little sideways...
Any help is much appreciated,
__________________
Brad
Super20G is offline   Reply With Quote
Old 03-13-2003, 10:21 AM   #2
The Man is watching.
Send a message via MSN to maximase86
Re: Out of time? or something else? Help
Quote:
Originally posted by Super20G
Well,
Is your car knocking at all? The problem could be the timing is set to advanced, or to retarded. You might want to play with the timing a little to see what it does.
S
__________________
-Sarin
02 GLE - Majestic Blue/Frost Leather
6k D2R HID - AE/Clear Headlights - 3k HID fogs w/Lexus Capsules - Exterior LED's - AE Tails
Smoked Sidemarkers - 15% tint - G35 Coupe 18's - Short Ram Intake
Past:
86 SE - MOTM
97 GXE SC'er - RIP 10/12/08
http://www.nwmaxima.com
maximase86 is offline   Reply With Quote
Old 03-13-2003, 10:29 AM   #3
it was doing ok for a few days, and now when i start it, the idle bounces up and down, then dies... then repeats that till i start it and give it gas and keep it going for a few seconds, then its mellows out some and only acts up under mid load or more,,, then it just sputters and there is a big loss of power until i back off the pedal till it doesnt do it, then i keep my foot there and let it very slowly build up speed.... its either do that, or have it sputtering and falling on its ***...
Can I play with the timing by just loostening that bolt that holds the distributor in place and sliding the distributor from side to side? maby that came loose or something, i dont know but traffic behind me tends not to like me...
__________________
Brad
Old 03-13-2003, 01:43 PM   #4
Send a message via ICQ to MaxWgn Send a message via AIM to MaxWgn Send a message via Yahoo to MaxWgn
Yes, timing can do all of these things. With the engine running, try loosening the hold down bolt, and twisting the distrib SLOWLY, either direction, and see if it seems to smooth out. If so, get your timing properly set, using a timing light, and following either FSM or the procedure in the Chiltons manual...do not use the Haynes for setting your timing.
__________________
-------------------MaxWgn--------------------
1991 Mazda 626 LX - 2.2l, 5sp, 114k miles
1987 Nissan Maxima GXE Station Wagon - 247k miles - R.I.P. March `05
"Never argue with an idiot. They drag you down to their level, then beat you with experience."
MaxWgn is offline   Reply With Quote
Old 03-13-2003, 01:46 PM   #5
What you should do, get a hold of these, haynes, chilton, or factory service manual, and look up the procedure to adjusting the timing. Try to get it the factory setting for that, and work from there. Basically what you said will work, you have loosen the screws and rotate the distributor, but because careful and make small adjustments.
Next thing you want to check is the condition of the AIV valve. If that goes bad, you would get some of the symptoms your having. Basically what happens is when the valve goes bad, it dumps water into the airbox. This water goes through your MAF sensor and essentially kills it. Basically a good way to check is to pop your air filter cover off, and look at the bottom of the airbox. If you see water, that is bad news. Immediately disconnect the air hose on the airbox that goes to the valve, it'd be the hose right next to the strut tower. Also get water out.
Let us know what you did/find.
S
__________________
-Sarin
Past:
86 SE - MOTM
Old 03-13-2003, 02:19 PM   #6
Send a message via Yahoo to Bleach
Sounds like the vaccume advance is not working right.
That could definatly be the problem considering you got the distributor used. Take off the cap and see if the rotor turns smoothly with your hand a few degrees.
__________________
Bleach is offline   Reply With Quote
Old 03-13-2003, 02:28 PM   #7
Well, I guess since I paid a shop to do this, I might as well take it back to them, they can get me in on monday they said, will it hurt me to drive on it until then? I plan to take it easy, not try to make it misfire repeadidly, just didnt know if it would mess anything up:-)
__________________
Brad
Old 03-13-2003, 02:51 PM   #8
As long as she isn't knocking, you should be okay, don't try to demand to much though. :P
S
__________________
-Sarin
Past:
86 SE - MOTM
Old 03-13-2003, 03:14 PM   #9
No, it drives pretty smoothly under normal driving most of the time, i just get into trouble going up steep hills and trying to pass cars or speed up quick... So I'll just stay in the slow lanes and relax till Monday, hehe. It seems to be if the car is cold, it drives fine all the time, but after its warmed up nicely, then the misfires come on more frequently..
__________________
Brad
Old 03-19-2003, 07:43 PM   #10
well, the shop said i needed a new distributor cap. I replaced it and drove around the block and it drove fine, i'll drive to school tomorrow and know if the problems fixed or not. the cap looked good inside, not too worn down, so i dunno. I'll update this and let you all know. thanks again
__________________
Brad
Old 03-19-2003, 11:43 PM   #11
You'd be real suprised how much of a difference a cap and rotor can make. Either way, have you touched the timing at all?
S
__________________
-Sarin
Past:
86 SE - MOTM
Old 03-20-2003, 11:05 AM   #12
No, i didnt touch the timing... the guy at the shop that did the work acted kinda mad i questioned his work. But then after he told me it was the distributor cap I asked him why he didnt check that while the distributor was apart? or why he didnt use my distributor cap off the other distributor and he said he just didnt check, that he was payed to install the distributor and he did so.. hehe, i know where i'm not going again.
__________________
Brad
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
