Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Thread Tools Display Modes
Old 03-11-2003, 10:47 AM   #1
Car wont rev past 2000 rpm
When i give it gas it just bogs out past 2000grand ..but when i unplug thye maf it revs past 2000rpm fine it justs run rich as ****....So me and my friend thought it was a head gasket because there was oil in the water which one head indid up being craked ...so I went ahead and ordered all new gaskets and seals for the whole car...We rebuilt the heads did Porting and polishing on the heads .. Ported the exhaust manifold polished the throttle body...slap new gaskets on put a whole complete exhaust finally got my lowering springs...slaped everything on it and its still doing the same damn thing.. Ive tryed 4 mafs from a Junk yard ...Tps sensors...Iac..whole Dist..and even borowed my friend ecu from his car to see if itll work...all of this still made no diffrence..oh ive also did a fuel psi check it came out to 50 psi
if you can please help me out it will be much needed...
thanks
__________________
1987 Nissan Maxima Se
Parting Out. Located In Bay Area Ca
VG30E Fully Ported And Polished Heads
$120 For Both
85-88 Maxima Polished Throttle Body.$25
300zx Maf Sensor $10
Pm Me for more Info
2ndGen@10psi is offline   Reply With Quote
Old 03-11-2003, 01:34 PM   #2
rcy
Re: Car wont rev past 2000 rpm
thanks
Maybe you need a NEW MAF, not one from a junkyard??
rcy is offline   Reply With Quote
Old 03-11-2003, 02:52 PM   #3
Send a message via ICQ to MaxWgn Send a message via AIM to MaxWgn Send a message via Yahoo to MaxWgn
Re: Re: Car wont rev past 2000 rpm
Quote:
Yes, this is the most likely cause. You ECU is dumping you into 'Limp Home Mode', due to incorrect information from the MAF. Try a new MAF, or even a MAF from a known good running car.
If all else fails, pull the ECU from under the seat, and run the diags on it...see what comes up...
__________________
-------------------MaxWgn--------------------
1991 Mazda 626 LX - 2.2l, 5sp, 114k miles
1987 Nissan Maxima GXE Station Wagon - 247k miles - R.I.P. March `05
"Never argue with an idiot. They drag you down to their level, then beat you with experience."
MaxWgn is offline   Reply With Quote
Old 03-11-2003, 05:00 PM   #4
That is defintely a MAF issue, I know because I had that problem myself. I got my MAF sensor from a junkyard and it's been working great for over a year now, so don't rule out used parts yet, especially considering a new MAF costs $400.
My guess is that there is something destroying your MAF sensor. The reason my original MAF sensor broke is because the Air Injection Valve (AIV) was destroyed from the emissions testing. Anyway, it started leaking water into the airbox, which in turn got on to the MAF sensor and destroyed it. Check the airbox and see if you have any water sitting at the bottom, if you do, disconnect the AIV hose from the airbox before you put another MAF sensor on. Other than that, maybe there's a problem with the wiring from the MAF sensor to the ECU. I don't think there's any thing else that would cause the engine not to rev past 2000 rpm besides a faulty MAF sensor or the ECU.
-C-
Charles Bisel is offline   Reply With Quote
Old 03-11-2003, 06:09 PM   #5
Thanks for the feed back guys ....I just spent over 2000 for gaskets and machine work...and need my car to work
Also Do you think runing the 300zx maf would work since the have the same # of Pins
also if it is the wirng for the maf Do i have to replace the whole engine harness?
__________________
$120 For Both
Pm Me for more Info
Old 03-11-2003, 08:42 PM   #6
Super Moderator
-C-
__________________
Shift_PRND21
1995 BLK/BLK SE:
Warpspeed superflo y-pipe, Tokico Illumina Suspension Kit,
5th gen Strut bar, ADDCO RSB,
17x7 ADR SZ1 rims, red laquered calibers, Nexen N3000 tires,
Smoked Diamond clear turn signal lens,
AE Headlights/clearance lights/foglights, rewired fogs
max95q is offline   Reply With Quote
Old 03-11-2003, 09:21 PM   #7
A 300ZX MAF from a naturally aspirated Z31 engine should work, though it may be oriented differently and may not work with the stock airbox. I'm not sure, as I've never seen one from a Z, so that's just a guess, you'd have to check it out yourself. It's not going to give you any added benefits, so I'd just stick with one from a Maxima if at all possible.
As far as the wiring, check the connection first. Maybe the contacts just need cleaned off. If it is the wiring, you should be able to trace it back to where it's cut, and then just splice new wire into it.
-C-
Old 03-11-2003, 09:30 PM   #8
-C-
Technically speaking, you should be able to run the MAF from the turbo z31 should you have an actual z31 ECU.
=A=
avalon42 is offline   Reply With Quote
Old 03-11-2003, 09:47 PM   #9
Send a message via AIM to spacey64 Send a message via Yahoo to spacey64
Quote:
=A=
actually ive tried it, yes it does work but its convenient if u wanna put a cone filter because its a double male piping not half then screw on flats side, as for ecu u will notice few dif's slight more power in an auto, it revs a bit higher like the tranny stick, thats under WOT tho gas mileage isnt that bad unless ur constantly hammering the gas
~mike
__________________
90' 240sx coupe RED
Dual DTM style 2.5in catback(3in hole)
custom CAI w/AEM cone filter
sony Xplode HU and 2 Xplode 6 3/4 3ways
2 poineer 4x10 2ways under the seats
(Maxine/Maximus 1985 Maxima's R.I.P)
spacey64 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
