Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Thread Tools Display Modes
Old 03-07-2003, 03:27 PM   #1
Send a message via AIM to spacey64 Send a message via Yahoo to spacey64
car died
well my car died the other nite, all of a sudden it jus started putterin and if i gave it gas it died, then jus died and i havent been able to start it since, i turns over but wont fire, ive checked everything all i kno is its not gettin spark to the cylinders, got from the coil but none to plugs jus changed distributer caps...nuthin
so idk. its gettin fuel. im kinda lost the only thing i can think of is the transistor to the coil is shot any ideas or advice?
~mike
__________________
90' 240sx coupe RED
Dual DTM style 2.5in catback(3in hole)
custom CAI w/AEM cone filter
sony Xplode HU and 2 Xplode 6 3/4 3ways
2 poineer 4x10 2ways under the seats
(Maxine/Maximus 1985 Maxima's R.I.P)
spacey64 is offline   Reply With Quote
Old 03-07-2003, 03:41 PM   #2
Super Moderator
Re: car died
~mike
Could be Maf Sensor gone bad.
__________________
Shift_PRND21
1995 BLK/BLK SE:
Warpspeed superflo y-pipe, Tokico Illumina Suspension Kit,
5th gen Strut bar, ADDCO RSB,
17x7 ADR SZ1 rims, red laquered calibers, Nexen N3000 tires,
Smoked Diamond clear turn signal lens,
AE Headlights/clearance lights/foglights, rewired fogs
max95q is offline   Reply With Quote
Old 03-07-2003, 04:09 PM   #3
Nah, my MAF sensor died and the car still started up and ran, albeit very horribly. The ECU has preprogrammed fuel/air mixture ratios that will allow the engine to run up to 2000 rpm so you can limp home or to the garage. If you try revving the engine past 2000 rpm, it'll act like it's going to stall out.
Check your distributor, spark plugs, and wires.
-C-
Charles Bisel is offline   Reply With Quote
Old 03-07-2003, 04:44 PM   #4
Super Moderator
youre right, I know. It was a long shot guess.
__________________
Shift_PRND21
1995 BLK/BLK SE:
Old 03-07-2003, 05:19 PM   #5
-C-
i doubt its wires or plugs cause they are les then 1 month old
i think its the ditributer and rotor, possible even the trasnsistor on the coil cause thats wut regulaters the powerful spark boost, ive been shocked by spark plugs before and that barely shocked me to the point of dropin the wire if the coil had full power it would have thrown me like it did with my old max and a lawn mower...hehe
so i think my problem lies there but only time will tell or im gettin rid of the car i dont have the $$ or the time to be with out a car
~mike
__________________
90' 240sx coupe RED
Old 03-07-2003, 05:45 PM   #6
if you know its spark trace it down to the problem area. got spark at coil but not distributor then check your dist sensor/modules. I keep spare parts of all kinds including a high output coil, if I think the coil is bad I use the high output to double check. volt meters are handy as well. another good idea is to use a spare plug and plug wire if needed, ground the plug and have someone crank the engine over. no spark makes it real clear. if you have a spark then the problem is elsewhere.
IROC Z is offline   Reply With Quote
Old 03-07-2003, 08:23 PM   #7
Quote:
yea i agree, but which sensors should i check? are u talking about the actual points in the distributer? if so i did file a new surface on then but i think the problem lies in a few places, the power regulator/ transistor or the actual distrubuter rotor itself, cause if the distrubuter rotor isnt making contact with the points because they have filed down far enough which i think is the problem, there is no connection close enough to the points which means no transfer of spark, so thats an easy only like 7 bucks for the rotor, but we'll see
~mike
__________________
90' 240sx coupe RED
Old 03-08-2003, 04:22 AM   #8
if you think its possible then try it like you said 7 bucks. but i personally doubt it, the spark can jump 1 in. as long as the ground is within 1 in. it will jump. i dont see the gap being over an 1 in. apart.
if you are getting spark from the coil to the cap then there could be a grounding in the dist. it could also be an ignition module issue (havent worked on allot of maxima's) but the workings should be basicly the same. typically a bad ignition module means no spark at all though.
Old 03-08-2003, 07:34 AM   #9
1. Your car information says you have an 85 Maxima, is this correct?
2. There are no points.
3. Have you verified that your distributor turns? You do this by taking off the cap and watching while it cranks. If it does not turn, you lost your timing belt.
4. The next suspects are the crank angle sensor and the ignition power transistor.
5. Take off the distributor cap and rotor. Remove the dust cover in the distributor. Blow out the distributor with compressed air, if a bunch of dust comes out, reassemble and try it now. If no dust comes out, replace the crank angle sensor, which is under the dust cover and the slotted disc. Get a distributor from a boneyard Maxima, 300ZX, 200SX SE V6, V6 pickup, or Pathfinder. Make sure it is one that looks like yours. Don't remove your distributor, you can change the crank angle sensor without removing it. I have done it. At Nissan, the CAS only comes in a whole distributor. $$$$.
6. From that same boneyard vehicle, get the power transistor, change it too.
7. Report back, how it went, or if you have any questions.
8. Enjoy your Maxima. They have activities that do not involve driving down roads. This is one of them.
__________________
Don't feed or tease the straight people.
dr.disc is offline   Reply With Quote
Old 03-08-2003, 08:45 AM   #10
well basically if t costs moe than 100 then im not gonna even bother,
i drive alot for work and this can get to be a pain, but i will try a few more simple things if they dont work car will junked because i will not hand this car to anyone knowing the problems it has, im sad to say it but if it has to be done it will be
~mike
__________________
90' 240sx coupe RED
Old 03-08-2003, 10:21 AM   #11
The things I suggested are the simple things. If you are restricting yourself to simple things, fixing a motor that had a bad timing belt is out. It involves cylinder head replacement, and some other parts, or engine replacement.
But you have to rule it out to go on. It is simple to take off the cap and see if the rotor turns when you switch on the starter. If you don't do this, there is no need to do anything else.
A boneyard distributor and power transistor should not cost $100. $40 should cover it.
I advise not removing your distributor, because re-installing it is technical, not difficult, but technical. I posted re-installation directions for when the distributor was removed without getting number one cylinder at TDC of its firing stroke, but it was removed. It was correct, but it was removed. It was in response to someone wondering how to do it, but it was removed. Hard to understand that.
Putting in a crank angle sensor and a power transistor from a wrecked car is simple, and a wreck was probably running before it crashed, so the parts will probably work.
I am looking for Maximas that owners give up on, if the body is not rusty and the glass is good. Location is very important though, because hauling them can cost more than they are worth after a given distance.
__________________
Old 03-08-2003, 11:49 AM   #12
well i live in north new jersy, idk how far in relation to u is but this goes for everyone this could probly be a quick fix or it probly not idk all i kno the car wants to run and is not gettin spark to cylinders, yes rotor does turn it was one of the first things i checked, quite possibly be the transistor could possibly be the CAS but idk, im gonna try another coil/ transistor if that doesnt work well im givin up on it, as for rust there is minor rust on all fenders, slight dent in trunk lid, rusted out frame damage to the rear rite side under the trunk, any one needs a parts car its yours for $150 has 176k on it and jus got an oil chage 2 weeks ago, any other questions feel free to ask, as for parting it out i cant because i have no where to store it, so offer is out there
~mike
__________________
90' 240sx coupe RED
Old 03-08-2003, 04:58 PM   #13
not knowing you full problem or length there of, i can sympthies with your problem. I have another car, the former work car that has similar issues as well. The difference is its had its issues sorted out and it just needs an engine (bad rings), but the car isnt worth the cost so donation time.
my new (to me) 84 max is the new work car. 110K and 1 owner is a great deal for a work car, little rust but nothing i cannot handle.
Old 03-08-2003, 05:00 PM   #14
yea i agree, i work for an dealers only auto auction, so im gonna try to go about gettin a car thru that. if no luck jus go about it the conventional way...car of choice is a 89-94 240sx....i want a SR20DET enngine swap...hehe
~mike
__________________
90' 240sx coupe RED
Old 03-09-2003, 08:45 PM   #15
~mike
well its final, i tried a new coil and nothing at all still will not start, ive been lookin for cars and im stuck between a 84 VW scirocco low miles immaculate 5-spd, or 86 firebird with worked chevy 350, i personally kno the owner all it needs is valve cover gasket and seals,
and rear drivers side rotor needs new studs. suggestions? opinions?
thanx
~mike
__________________
90' 240sx coupe RED
Old 03-09-2003, 09:09 PM   #16
Send a message via MSN to GundamWZero Send a message via Yahoo to GundamWZero
Quote:
86 firebird with worked chevy 350......
I smell a paradox........... the world is comming to an end when you put a chevy in a GM.
which reminds me......
__________________
SHIFT_period.
1986 Nissan Maxima 5 spd. R.I.P
2006 Nissan Altima
18" Niche Rhine Rims/ ZR-rated tires
Kenwood DDX6019
Kenwood GNA510 Navigation System
Kenwood LZ-702IR Headrest Monitors x2
Alpine MRP-M850 800w Mono Amplifier
Alpine MRP-F250 360w 4/3/2 Channel Power Amplifier
Boston Acoustics Speaker System
Boston Acoustics Subwoofer
2007 Nissan Armada Fully Loaded.....
GundamWZero is offline   Reply With Quote
Old 03-09-2003, 10:48 PM   #17
The Man is watching.
Send a message via MSN to maximase86
Hmmm....a chevy engine in a GM...a chevy engine is a GM motor.
Captain Obvious has stuck again!
Why don't you look for a 2nd gen SE, or a 92 or newer 3rd gen?
S
__________________
-Sarin
02 GLE - Majestic Blue/Frost Leather
6k D2R HID - AE/Clear Headlights - 3k HID fogs w/Lexus Capsules - Exterior LED's - AE Tails
Smoked Sidemarkers - 15% tint - G35 Coupe 18's - Short Ram Intake
Past:
86 SE - MOTM
97 GXE SC'er - RIP 10/12/08
http://www.nwmaxima.com
maximase86 is offline   Reply With Quote
Old 03-10-2003, 10:32 AM   #18
I personally would go with the firebird of course seeing as I already have an 89 IROC 350/auto with TPI but thats me.
do you want speed or mpg's though? I drove my IROC daily until recently when I moved further away from work and the cost of gas really started hurting me. I averaged 18mpg in the ROC, but now that its a weekend car its more like 5mpg.
Old 03-10-2003, 11:26 AM   #19
Jesus the rating for the max during city use, 2nd gen, is 18!
JayDubs is offline   Reply With Quote
Old 03-10-2003, 04:29 PM   #20
now you know why i have a work car and a fun car
some 3rd and 4th gen camaro/firebirds get better mpgs then this, mid 20's, some even high 20's. but speed costs not just in cash but miles per gallon as well.
Old 03-10-2003, 04:33 PM   #21
well the good thing is its stick...a rare find. but im undecided i have about 1 month to decide but if a 89-94 240sx comes my way before hand then im takin it..same witha 90-95 300zx, but we will see how things go
~mike
__________________
90' 240sx coupe RED
Old 03-10-2003, 06:29 PM   #22
You gotta keep in mind, a camaro/firebird is a totally different class of car, it would be trying to compare apples against oranges. If you were to compare our cars to lets say...a toyota cressida, or a acura legend, then you can make a good comparison.
S
__________________
-Sarin
Past:
86 SE - MOTM
Old 03-10-2003, 06:41 PM   #23
what are you talking about? camaros and firebirds from the 3rd gens on have the same engines and drivetrains with similar drag coefficent so the mpgs have been very similar for both. this same mpg comparo comes up on the 3rd and 4th gen boards. 1 camaro may get much better mileage then a similar camaro, same for firebirds. I've seen guys post 10mpg higher numbers average than my car got stock for no real apparent reason. then again I have seen people with lower mpgs on basicly stock engines, 15's and what not.
as strange as it sounds not every car gets the same mpg even a similar or even same model will vary a bit. but the 3rd generation camaro's/firebird's seem to be a bit extreme to me.
Old 03-11-2003, 01:23 AM   #24
Mine wouldnt start for 2 years even trying every thing these folks said, after all the trying it turned out to be something simple. the distributor ground was oily and wouldnt allow the distributor to give a spark, after I cleaned the ground it began to start.
MrSmith is offline   Reply With Quote
Old 03-11-2003, 09:38 AM   #25
Sorry, I though you were making comparison of a camaro/firebird to a maxima. :P I was going to say....umm what the hell? LOL!
S
__________________
-Sarin
Past:
86 SE - MOTM
Old 03-11-2003, 10:28 AM   #26
Ah I gotcha!!! no that would be like comparing my geo metro to a school bus, its not going to work. but maxima to maxima or camaro to firebird when they are similar in yrs and options its fair. I dont consider comparing a 305 to a 350 camparable, the same goes for mods of course. a hot cam will throw the mileage right off completely.
Old 03-11-2003, 01:14 PM   #27
Quote:
call me dumb but where is the ground?
~mike
__________________
90' 240sx coupe RED
spacey64 is offline
