engine support?
Quick question from thoes who may have done it in the past...
I am currently in the process of replacing my rack & pinion assembly, as well as installing a new oil pan gasket. For the gasket, it is essenssial to remove the crossmember, and hence, in essence, remove the support of the engine. I do not have a hoist to use to support it from above, and you cannot support it from below, when you have to remove the pan.
On the radiator side of the engine, toards the battery, is one lift mount, when the battery grounds to the block. Where can I SAFELY attach another achor point of the firewall side of the engine, preferably at the front of the engine, so I can support it, via a chain, from a heavy pipe layed across the fender wells? It needs to be easy to access, as well.
Any assistance is much appreciated. I didnt get a good chance to study it much, as I was more consumed with the removal of my P/S pump this weekend. I'd just rather save a little time, and see if anyone knows of an easy way...
__________________
-------------------MaxWgn--------------------
1991 Mazda 626 LX - 2.2l, 5sp, 114k miles
1987 Nissan Maxima GXE Station Wagon - 247k miles - R.I.P. March `05
"Never argue with an idiot. They drag you down to their level, then beat you with experience."
