Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Thread Tools Display Modes
Old 03-02-2003, 01:56 PM   #1
Need some experienced help.
Hi all, been fine tuning the turbo project and all has been going rather well with the exception of a few items which aren't directly related to the swap.
I have in issue with my car with which I am at a total loss. I can't get it to start, for the second time. The first time was when I had to take the upper intake manifold off (no brainer) and do some stuff, nothing major. When I zipped it all back up, the car wouldn't start. I farted around with it for two days finally just walking away. I went back out the fourth day after leaving everything sit for a day, and walla, it started. Huh?
Well, I don't know what the deal was and my computer wasn't giving me any codes either. All was well, but then I noticed my fuel injectors we weeping. I ran a check and the car I got them off of had not been taken in for the recall. I tracked down a set of injectors off of a turbo 300zx which has been serviced in the recall, heck these babies still looked new!!! I tested them (resistance, open/close, etc.) and was well. Again I took my upper intake off to install these 'new' injectors, zipped up the engine and CRAP! It wouldn't start again. Same as last time, as the days went by, it would get better and better, meaning it would at least sound like it wanted to start, but to no avail.
I have tested and checked everything (coil, different distributor, different FPR, checked for good spark, check the fuel PSI and flow, checked all the sensor for proper resistance, checked parts of the wiring harness for continuity, etc.) So far, you name it, I have checked it. BUT, everything is becoming such a blur I feel like I am missing something, I must be missing something cause I can't find the problem.
Here's another interesting note, when I turn the car on, my fuel pressure gauge reads 38 or so PSI, right to spec. So I ran a test where you pull the fuse for the fuel pump (same as you would do to depressurized the system) and as I crank the car over, the fuel pressure drops, incrementally down to zero, like it should. So that tells me that my injectors are not only holding pressure but they are also operating and releasing the fuel. Here's the kicker, when I get down to 10 psi and under, the car actually runs, very rough though and then stalls when it runs out of fuel.
I have tried different air flow meters, a different computer, blah, blah, blah. Someone make a suggestion please, I am ready to loose my freakin mind here! ;-)
PS - The blow valve I had shown you before is working great! When the car was running. LOL! Rest asssured, my troubles right now aren't related to the turbo swap directly, there is some other gremlin giving me grief right now.
KALSC is offline   Reply With Quote
Old 03-02-2003, 02:47 PM   #2
Send a message via ICQ to Nismo87SE Send a message via AIM to Nismo87SE
This maybe a something stupid but check and see if your fuel lines are reversed. Also I guess check and make sure all the injectors are plugged into the right connectors. That is if nissan did the injector recall. If you know the engine has spark and compression then there is a fuel problem. The only possibitily is that the fuel lines were reversed if the injectors are good and there is fuel flow after the fuel filter.
__________________
87 Nissan maxima SE auto: RIP
91 SE-R:
Best ET: 14.57 at 90.4 with 1.90 60ft.
Quote:
BMW gets girls. MB gets women. Maxima gets dirty - Daniel B. Martin
Nismo87SE is offline   Reply With Quote
Old 03-02-2003, 07:21 PM   #3
Any suggestions help.
Thanks for the suggestions. I am seriously getting my a$$ kicked by Maximus, he's proving his worth in truly being The Great in this case.
The fuel lines are on correctly, I wish it were that easy. If the lines were reversed, then why the last time this happened would it all of a sudden start the next day with no apparent change in anything? Welcome to my screwed up world.
I am totally convined it is a fuel problem. As I descrived in the original post, it seems like there is too much fuel or that the air/fuel mixture isn't being metered or delivered correctly. As the psi drops when the fuel pump is disconnected, under 10 psi to 0 psi, the car actually runs a little until it runs out of fuel (due to pump not acitve).
I checked my chts at it reads 3.4 k-ohms, bang on to what three others I have kicking around here read.
Here's a question, in the injector recall people mention that not only were the injectors replaced but part of the harness as well? What part? Just the injector plugs or what?
Come to think of it, I have had problems with this car ever since I got it, meaning that I just couldn't get it to run right. Maybe I do have a harness issue.
I think what I am going to do is pull the injectors and connect them to test for leakage (AGAIN!!!!!) and for pulse (AGAIN!!!!!) It wants to start, it wants to run, but the air-fuel ratio is just not where it should be. ACK!!!!!
Old 03-02-2003, 08:42 PM   #4
Silly question, but . . .
In everyones opinion, when you see a spark plug fire on our Max's, what do you see? A white or blueish white zap? Cause all I get is an orange zap, which makes me think of a weak ignition system. If the spark is too weak then it may not be able to ignite the richened fuel mixture due to a cold start. Thoughts?
Old 03-02-2003, 09:04 PM   #5
The Man is watching.
Send a message via MSN to maximase86
Re: Silly question, but . . .
Quote:
I usually see a bluish white zap...as for orange zap, that's different. It could be possible that it could be that...to you have another ignition coil sitting around? Give that a try and see what happens...
S
__________________
-Sarin
02 GLE - Majestic Blue/Frost Leather
6k D2R HID - AE/Clear Headlights - 3k HID fogs w/Lexus Capsules - Exterior LED's - AE Tails
Smoked Sidemarkers - 15% tint - G35 Coupe 18's - Short Ram Intake
Past:
86 SE - MOTM
97 GXE SC'er - RIP 10/12/08
http://www.nwmaxima.com
maximase86 is offline   Reply With Quote
Old 03-05-2003, 12:26 AM   #6
Ha!
Found the problem, well . . . problems.
First off when I had to rework the rocker pedestals and zipped up the top end, the O2 sensor failed momentarily then. But it decided to kick in again and that's why the car started that time.
This time, after I changed my injectors, the O2 sensor decided to fail again and stay gone. In my ignorance, I took it for granted that on the Max's the O2 circuit would be bypassed for the first minute or two at start up allowing it to heat up in order read right. Hence, I never thought to check it. Well, I found out that the O2 circuit on our cars is active right away, hence the three wire lead, the system preheats it so it starts to reference the mixture ratio right away.
Not knowing this happened, I never thought to check the O2 sensor as I thought it was being bypassed. Once I found this out, I pulled it and checked it and sure enough I was getting intermittent readings. Aha!!! Or so I thought. I put in a new O2 sensor, but to no avail.
Talk about frustration. Then I found out that due to the failing O2 sensor, the car is but into an over rich condition, which I knew, but that over rich condition (extremely over rich) fouled my plugs, its called fuel fowling. Basically, the plugs get so drenched in raw fuel that it seeps into the plugs and kind of shorts them out. Sometimes they are recoverable, but mostly not.
Sure enough, I put in a new set of plugs and the baby fired right up.
So, long story short, the failed O2 sensor sent my car into an extreme over rich condition, so rich it couldn't ignite and the raw fuel fowled my newer plugs (1200 kms now). The new plugs combined with the new O2 sensor were the ticket in my case.
I learned two things, three and four wire O2 sensors are active right away and an extreme over rich, non-igniting situation can totally ruin even a new set of plugs.
Maximus lives!!! Time to finish testing the new blow off valve and crank this baby up to 12 psi. Buuuuuuahahahahaha!!!
Old 03-05-2003, 05:30 PM   #7
Re: Ha!
Don't forget to check the ECU's A/F ratio alpha in diagnostic mode II. If both LEDs aren't on then you need to recalibrate it.
__________________
91 SE-R:
Old 03-05-2003, 06:35 PM   #8
Super Moderator
Re: Re: Ha!
Quote:
Recalibrating the maf? Like on the 2nd gen forum at Yahoo, right?
__________________
Shift_PRND21
1995 BLK/BLK SE:
Warpspeed superflo y-pipe, Tokico Illumina Suspension Kit,
5th gen Strut bar, ADDCO RSB,
17x7 ADR SZ1 rims, red laquered calibers, Nexen N3000 tires,
Smoked Diamond clear turn signal lens,
AE Headlights/clearance lights/foglights, rewired fogs
max95q is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
