Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Thread Tools Display Modes
Old 02-25-2003, 08:47 PM   #1
Send a message via AIM to k87max
Auto - 5 spd swap?
I have an 87 auto and I have heard from many people that a manual tranny in these cars have closer ratios and shorter gears so... Is it possible to do an auto tranny to manual tranny swap. And if so how much would it cost if I already had a manual tranny?
__________________
Sure I'll race ya but my money's on youhttp://www.cardomain.com/id/kman87
k87max is offline   Reply With Quote
Old 02-25-2003, 11:36 PM   #2
The Man is watching.
Send a message via MSN to maximase86
Re: Auto - 5 spd swap?
Quote:
Well, it really depends. You can definately do the swap, but you would have to add components, you may have to switch ECU's because I believe the autos have an AT controller to help with the electronic overdrive. Other than that, you may have to do some drilling and cutting for a clutch pedal. As far as a price, its really up in the air since I dunno of anyone that has done it on our cars yet.
S
__________________
-Sarin
02 GLE - Majestic Blue/Frost Leather
6k D2R HID - AE/Clear Headlights - 3k HID fogs w/Lexus Capsules - Exterior LED's - AE Tails
Smoked Sidemarkers - 15% tint - G35 Coupe 18's - Short Ram Intake
Past:
86 SE - MOTM
97 GXE SC'er - RIP 10/12/08
http://www.nwmaxima.com
maximase86 is offline   Reply With Quote
Old 02-26-2003, 07:45 AM   #3
Send a message via ICQ to MaxWgn Send a message via AIM to MaxWgn Send a message via Yahoo to MaxWgn
The swap itself is easy, but you will need more than just the tranny. The front crossmember is different, and the tranny mount is different as well. The flywheel will need to be swapped in to replace the flexplate inplace now. The clutch and brake pedals and clutch master cylinder are all practically bolt in. The ECU should be changed, but it will run without. The timing curves, etc., are a little different. You will need the interior console finishing pawl, shift lever etc... Also, the CV Shafts are different, as they have slightly different splines than the auto.
The ideal situation would be to have an entire parts car, as this will save you tons. While you're pulling the crossmember out, etc, you should replace the motor and tranny mounts, the rear main seal in the engine, and take the op to install new CV shafts and a new clutch and pressure plate, and either replace or rebuild the master and slave cylinder. This should help ensure the swap goes as smooth as possible, and prevents you from having to tear it all down again, later...
With the parts car, you can get everything except the clutch, pressure plate, CV Shafts, and mounts...the flywheel should be resurfaced, though.
__________________
-------------------MaxWgn--------------------
1991 Mazda 626 LX - 2.2l, 5sp, 114k miles
1987 Nissan Maxima GXE Station Wagon - 247k miles - R.I.P. March `05
"Never argue with an idiot. They drag you down to their level, then beat you with experience."
MaxWgn is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
