Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Thread Tools Display Modes
Old 02-24-2003, 05:28 PM   #1
The Man is watching.
Send a message via MSN to maximase86
Im ****ed
Alright, I've done a few things over the weekend. Clean the car, installed a cone filter. Also over the past 2 weeks, I have been stepping my car down from 92 octane fuel. So the first week I ran 89 fuel. Car ran fine, just dandy. Saturday I stepped down to 87 octane. Well everything seemed fine. So I today, I'm driving, and since its warm out, I have the heater off, and all the windows down. The engine tends to run hotter...usually in the second half of the gauge, but it will never pass the tick mark before H. Well, get to the college, and have the car in second, the engine rpm's are about 1200-1500 and the engine starts knocking like a diesel. It clears at about 2k, but if I give it more gas, you can faintly hear it. I haven't notice knocking when the engine is cold though, but I will test it to make sure. Here are my guesses. 1. My car doesn't want to run 87 octane at all. 2. I need a tune up (I highly doubt, since its only been about a year since my last tune up, and I don't have any hesitation. 3. My timing is off just a tad, 4. When the engine is hot, the intake is sucking up a lot of hot air and causing detonation. Anyway, for those who have done the intake, what have you guys done to fix this issue? I'm think of going back up to 89 or 92 octane to see what I get...probably starting with 89 first. Then I'm probably gonna have to get cracking on making a CAI, since I don't want to but the stock airbox back on or even making a heatshield with sheet metal.
S
__________________
-Sarin
02 GLE - Majestic Blue/Frost Leather
6k D2R HID - AE/Clear Headlights - 3k HID fogs w/Lexus Capsules - Exterior LED's - AE Tails
Smoked Sidemarkers - 15% tint - G35 Coupe 18's - Short Ram Intake
Past:
86 SE - MOTM
97 GXE SC'er - RIP 10/12/08
http://www.nwmaxima.com
maximase86 is offline   Reply With Quote
Old 02-24-2003, 07:15 PM   #2
I responded to your problem at the club.
-C-
Charles Bisel is offline   Reply With Quote
Old 02-25-2003, 12:07 AM   #3
Quote:
-C-
Running excessive octane builds up carbon deposits in the combustion chamber, especially on top of the pistons. When you run lower octane afterwards, the carbon heats up excessively and is still glowing hot and causes predetonation before the spark plug fires.
You also said you have the timing off. That is something to look at for sure. Set it to spec.
Chevron makes a carbon deposit cleaner, which is in dilute form in their fuel injector cleaner, but which can be bought in higher concentration to clean up engines. It is called Techron. It is pretty good stuff.
What plugs are you running? I could use 87 octane with NGKs (which Nissan recommends) but not with other plugs I tried. I run NGK plugs, Nissan wires, Nissan cap and rotor, and stock timing without problem on 87 octane. I have trouble when I depart from this line up of ignition parts.
__________________
Don't feed or tease the straight people.
dr.disc is offline   Reply With Quote
Old 02-25-2003, 09:24 AM   #4
Super Moderator
This is what Im thinking of doing if I install my cone filter. Im going to get a heater duct and run it from the front of the car to the cone filter so it gets more cold air in than hot. About the engine thing try to atleast stick with 89 if knocking with 87. I never use 87 the lowest is 89 if the mid is 90 or 91 Ill use that. Especially since prices are so high now I had to stop with the more expensive stuff.
__________________
Shift_PRND21
1995 BLK/BLK SE:
Warpspeed superflo y-pipe, Tokico Illumina Suspension Kit,
5th gen Strut bar, ADDCO RSB,
17x7 ADR SZ1 rims, red laquered calibers, Nexen N3000 tires,
Smoked Diamond clear turn signal lens,
AE Headlights/clearance lights/foglights, rewired fogs
max95q is offline   Reply With Quote
Old 02-25-2003, 09:27 AM   #5
Super Moderator
Had to change your subject try to refrain from the foul language even though you feel it.
__________________
Shift_PRND21
1995 BLK/BLK SE:
Old 02-25-2003, 10:12 AM   #6
Super Moderator
-C-
Is the club working? I got something saying the archives arent avail.
__________________
Shift_PRND21
1995 BLK/BLK SE:
Old 02-25-2003, 11:08 AM   #7
I run NGK Resistor plugs. I'm not running NGK cap rotor, or wires though :\. I'm going to step up to 89 or go back to 92. I had an engine vac done back in August to remove carbon buildup. Probably need to run some techron though anyway.
S
__________________
-Sarin
Past:
86 SE - MOTM
Old 02-25-2003, 02:30 PM   #8
Quote:
S
Unless you want to run a dremel tool or other wire brush on those pistons and valves, Techron is the only way to get at it I know of.
__________________
Old 02-25-2003, 02:37 PM   #9
Its a nice little system they have. They hook your motor up to motor vac machine and the pump heavy concentrated solvent through the motor for about an hour. I think they actually use techron, but I'd have to check with them. After that, they flush out the solvent and ba'am your set. Gets everything nice and clean.
S
__________________
-Sarin
Past:
86 SE - MOTM
Old 02-25-2003, 02:41 PM   #10
Yeah, the club is working perfectly well. I'm surprised you had trouble accessing the archives, I can't remember the last time I had a problem with the Yahoo club, or any club on Yahoo for that matter. Now maxima.org, that's a whole other story. I usually have trouble reading the posts everyday.
-C-
Old 02-25-2003, 03:00 PM   #11
S
Very, very cool. I had no idea anyone did that. What does it cost?
__________________
Old 02-25-2003, 03:32 PM   #12
About $120. It cleans everything including the fuel injectors. My car was running really nice after that was done. I think its worth the money.
S
__________________
-Sarin
Past:
86 SE - MOTM
Old 02-25-2003, 11:24 PM   #13
Super Moderator
-C-
Yeah maxima.org is known for the probs, Hopefully once things get situated here it might run better. The admin and some of the moderators are debating the server issues to make it to where we wont have any problems at all, and if so then a specific person can just fix it right then and there instead of having to call to get the server back up.
__________________
Shift_PRND21
1995 BLK/BLK SE:
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
