Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-01-2008, 10:24 PM   #81
yer it a second gen it goes really good but i think it could go better a...could go with computer nd injectors but after that what else...o yer its a pillarless modle not very many around new zealand
matt for maxima is offline   Reply With Quote
Old 10-01-2008, 10:34 PM   #82
yer its a second gen pillarliss model...could do injectors and computer but i was woundering if a 300 zx motor will bolt in weith out any hassles....my wife reconds it goes really good now and she told me not to do any more to it but i just like speed and the nissan is really good to start with and the sub is all electric to
Old 10-02-2008, 03:59 AM   #83
2nd Gen Boostinator
Big_E-Dog's Avatar
if your legrand is turboed already then it should drop right in your lucky if you have the 2.0l turbo motor because youll have all the mounts worked out all youll have to do now is to alter the downpipe.
__________________
CUSTOM HEADLAMPS/CARBON FIBER/FT&RTSB/OIL COOLER/LED'S/VG30ETT/PATHFINDER INTAKE MANIFIOLD/2.5" EXHAUST/NISMO MUFFLER/HKS TT, BOV, BOOST GUAGE/Q45 BBK/K&N/2x GARRETT T-25/NISTUNE/......
Big_E-Dog is offline   Reply With Quote
Old 10-08-2008, 12:23 AM   #84
yer it is 2l..so 3l would fit straight in then...i brought this car off my best mate but had a lot of work to do to it....hot the car for $3000 then the gear box blow...then the motor...so i repainted it and dropped in a new motor now doesnt go to bad...got front mount intercooler boost tap and blow off valve should i up grade of just keep it like this
Old 11-25-2008, 09:34 PM   #85
My 81 Turbo Max
Hello guys, just joined this awesome site because while surfing the net. I ran across this site that had my car posted on this site So I just want to introduce myself and show my old school maxima with a L28 turbo smog legal with a california smog certificate sticker on it. So everything is legal on this maxima. And I just want to apologize to the tread starter for hi jacking your post. I just can't start a new thread, the site won't let me. Thanks again and hope you like this old school maxima. Here are some pictures, check the link below. Thanks again
http://s459.photobucket.com/albums/q...maximus003.jpg
clazcar is offline   Reply With Quote
Old 11-25-2008, 11:00 PM   #86
your maxima is mindblowin!!! 10stars!!!
__________________
http://WWW.JASSICS.COM ...Defending 70s,80s and early 90s Japanese cars from the junkyard and extinction!!!
DIASISS OF JASSICS.COM is offline   Reply With Quote
Old 01-20-2009, 09:10 PM   #87
That white one looks good but those wheels rub like a *****.....been there with those exact same rims. Maybe if he used 280zx offset front and rear brake setup and front struts with the 280zx offset he wouldn't have the rubbing.
Might be selling my first generation turbo l24e 5 speed car with r200 rear.
It's high mileage with worn control arms that allow the ball joints to move a bit, has noisy brakes, chattering and worn 4 puck clutch, worn turbo that still works but it has reliably driven me to and from work 25 miles each way every day for the last 2.5 years.
It sports 15x6 300zx 4 lug wheels with worn 215/50s (225/50 would have been better).
Body has dings but no accident dents and I have tons of replacement parts and the unibody floor has no rust holes.
Price will be sub-$500 but I will take it to moroso this weekend and see what kind of offers I get after smoking a few s13s before releasing it here.
Oh and one more thing.......when converting a L28 from rear to front sump, don't drill the dipstick boss that looks like it would be the proper place.
The L28 block has two oil pickup tube bosses with the front one being blank since the engine was always used as a rear sump application.
When converting it to front sump, sure...you can drill out the front boss but you have to remember the oil galley still continues to the back boss which must be blocked off and.....................it passes right through the dipstick boss where one would drill the hole for a front sump.
The front dipstick boss is for use in an engine that was only drilled to the front pick-up boss.
If you drill the front dipstick boss and the front oil pick-up boss in the L28, you must shove a plug into the galley just after the front boss or your car will gulp air through the now drilled dipstick boss.
I just cut the pickup and turned it as well as extended the one inch necessary to reach the front sump and drilled a front dipstick hole where there are no oil galleys present.
For fun, the engine will be sporting the very racy twin dipstick look.
It goes in my M30.
HowlerMonkey is offline   Reply With Quote
Old 01-28-2009, 10:09 PM   #88
Hello HowlerMonkey, I don't have any rubing issue on my maxima, never rub ones. My car is not lowered and I'm running 195/60/15. Also, I have another maxima, an 83 with the same turbo wheels but this car is lowered and no rubbing issues at all. I'm still runing the stock brakes set on both my cars, 81max and 83max. Take care guys
Old 02-02-2009, 12:03 PM   #89
Strange........those exact wheels with the same size tires rubbed in my maxima.
I gave away 8 of them recently because I no longer had a car they would fit.
Now the early 300zx wheels will fit 225/50s and not rub.
Old 02-10-2009, 01:40 PM   #90
I just bought an 82 maxima.. i really want to lower it and start doing some work on it but i dont know where to start
sweetnesschild is offline   Reply With Quote
Old 02-10-2009, 05:50 PM   #91
Just fill it up with gas and it will lower itself.
Old 02-12-2009, 01:27 PM   #92
is there any coilovers or spring sets i could buy?
Old 03-05-2009, 08:00 PM   #93
Send a message via Yahoo to tremaine87
Guy whats up, Namez Tre, Im about to pick up an 87 Maxima (man trans) for free in Cali, jus want to get on these forums & meet 1st Gen Maxima drivers. I actually want to mod it w a turbo, intake, body kit rims, the works.
So ill posts picks of it the friday frm today!
Hit me up if u have any insight 4 me, Thx Every1
tremaine87 is offline   Reply With Quote
Old 03-27-2009, 07:20 PM   #94
nice
mahanddeem is offline   Reply With Quote
Old 05-22-2009, 10:28 PM   #95
Pretty sure 87 max is a 2nd gen
__________________
-1987 300zx na>t, 5spd. 89 CLSD, Nistune, 324cc injectors, t5, Cobra R wheels.
-1976 280z na>t, 4spd, z31 maf and ecu.
-1990 Maxima N/A, Autotragic, at>m Traded for 82 maxima
-1982 Datsun Maxima l24e auto
comrade_Charlie is offline   Reply With Quote
Old 06-17-2009, 03:04 AM   #96
Send a message via AIM to awdrftr
well it looka like i will be adding to this, 5-22-2009 was the last post. Does anyone go in here anymore? My name is Mykol, from Socal Orange County. I was searching for a place to introduce, but i had no luck. Since i have a 1st gen Maxima, i thought that this may be suitable. So far i have been playing with sportscars for years, well since i was a kid. I was super stoked when I found my first RWD nissan Maxima. Datsun 810 is what i believe what others may call it. Recently I have accumulated a lot of networking and got this moving slowely but cheaply. Got sideskirts, fender flares, spoiler, Kaaz LSD for the r180 diff. , and recently picked up a 2JZgte motor to swap into it. im mainly concerning myself with the looks for now, since i have both an s13 and fc3s to play with while i work on the Maxima. im going for the VIP Drift style. in that scene looks mean a lot, and my buddies drift their 82 Cressida 2jz swap, Infinity M30 LS1 swap, and Cefiro rb20 swap, and i know no one that tunes or drifts maximas. mainly cuz most of them are FWD. no offense, i just like to drive RWD.nice to meet your forum, i'll post pics asap. peace Mykol
awdrftr is offline   Reply With Quote
Old 08-05-2009, 09:18 PM   #97
If you have a 2jgte, then you will need to fit the R200 diff. to the car.
The S12 200sx turbo R200 diff. mount and late 280zx C/V type axles will much better handle that engine without breaking.
Old 09-02-2009, 02:54 AM   #98
Send a message via AIM to Te72Rob Send a message via Yahoo to Te72Rob
I just picked up a first gen. Stripping the interior, dropping in a 280zx L28 and 5speed. 86 300zx suspension/5lug swap. hopefully be done in less than a month
Te72Rob is offline   Reply With Quote
Old 09-14-2009, 11:02 AM   #99
Just got a 1982 datsun maxima with a diesel in it. don't know anything about them, I'm learning. i need a alt. for it anyone have or know where i can find one?
5genflaboy is offline   Reply With Quote
Old 09-14-2009, 05:14 PM   #100
Send a message via Yahoo to arsonist63086
Quote:
autozone my freind...
arsonist63086 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
