Who is diesel Maxima folk?
Re: Who is diesel Maxima folk?
Originally posted by coachgeo
Hi,
I'm new here (obviously) and I have a 82 maxima diesel.
Just was wondering who was diesel folk in here.
Hi,
Uh, oh........moderaterators, I think its time to add another forum!
Re: Re: Who is diesel Maxima folk?
S
Re: Re: Re: Re: Who is diesel Maxima folk?
Isnt the Maxima a LD28 not LD24? They are 6cyl
Thanks John thats a what Iza came here for. Widdle help with my new used Ratsun. I've owned a few 510's, and Roadsters in my days. Im happy to be back with a ratsun again. This will be my daily driver.
Right now I need some drivere side rear suspension parts and alll new filters etc. Any sugestions?
Re: Diesel Maxi
Originally posted by dslsmoke
Well I have two of them , '82 sedan with about 86k and '83 wagon with about 124k, I believe we have posted and replyed to other threads on the BB board.
Hope some others pop in to this thread so all us dieselers have a thread of cohorts.
Are any of you running Vegetable oil fuels (Biodiesel, or WVO)?
PS. My spelling has allways sucked so I'll applogize from the get go. Sometimes I play with spellings too in jest.
Die..Max 82
George
Datsun roadsters!?!?
I had stock 2 liter Roadsters. both a solex version (twin mikuni Solex and different cam) and the other verson with SU's and a slightly milder cam. I really miss them. Steering was sweetttttttt. and I sware the rear was a posie. sure acted like it on dirt roads
X cross member frame. Kickn 5 speed. My solex version did 30,60,90,110mph in gears in 1 thru 4 and fith gear was still there.
Many other projects first, though. Thanks for the info.
The Maxima Diesel is a 2.8L engine but it is stroked. It has a longer stroke than even the Z's 2.8L
So I'm not sure on the piston bore; it might be the same bore as the 2.4L as engine but stroked so much that it is a 2.8L capacity. They run very high compression of course.
The stroke is longer on the diesel to increase compression which like you suggested is typically higher on diesels. This is cause high compression is part what makes a diesel work.
Yes, the L28 does have a larger bore. The Z folks will typically find a Diesel Maxima crank (if one can be found) and use them in their L28 blocks. With little modifications they end up with a stroked Z-car engine running on normal gas. They must use different pistons and connecting rods but the procedures are all spelled out from people who have done this before. With a 3mm overbore they end up with a 3.1 liter straight six that has a lot more torque and potential horsepower than the 280Z's 2.8L
I got that brown maxima picture a while back from a maxima that was sold on eBay. I think it was in Idaho or Montana. My maxima is brown, but not quite that color, or in good condition. I'll get a little icon of my own car later...
Taking my Maxima to the Max!
OK, so where is the real Maxima Diesel info? I am looking to buy one for my Mom who wants to be able to run biodiesel in it.
What is the actual MPG of these cars? What other issues are there I should know about? The one I'm looking at is a 1982 sedan with 153k miles. Thanks.
You'll get anywhere between 20 - 25 mpg with the 3 speed automatic. The 5-speed can get upwards of 30+mpg.
You'll also need to replace every rubber fuel line. The factory lines are not resistant to the corrosive properties of biodiesel. I'm planning the same conversion on mine as well as installing a turbo & exhaust manifold from a 280ZX.
A fully installed single tank kit can be had for around $1000. Here's an example: http://www.goodguysbiodiesel.com/pro...system-899-99/
Good luck!
MaximaDrvr
08-19-2015 08:20 PM
