Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Thread Tools Display Modes
Old 12-24-2002, 07:42 PM   #1
Bright and Effective bulbs.
What type of bulbs can I use on my 87 Maxima that have effective brigtness especially at night and in all weather conditions? I would prefer some with a blue color to them but are also bright. I was looking at some of the bulbs on the JC Whitney website for around 13-20 dollars. Should I just get those or are there better ones?
Also I need to replace the front headlamp cover on the drivers side. I don't need the whole unit just the plastic cover part for the front.
Sorry if this was posted before but I did a search and couldn't find anything.
Implicit is offline   Reply With Quote
Old 12-24-2002, 08:13 PM   #2
The Man is watching.
Send a message via MSN to maximase86
Re: Bright and Effective bulbs.
The cover I wouldn't know where to find. As for brighter bulbs, if you only want to spend $20, you might look into the new Sylvania light they have out...I forget what they are called. Philips also make a cool blue for that end. Anyway, it's really preference. I went on the high end for my car, and I tend to pay a premium for the really good stuff, which for some reason seems to be why I'm broke.... Anyway, what I did was go the PIAA route. I am running PIAA Xtreme Whites 9004 for headlights, PIAA 2100XT Xtreme White Fog Lamps, Polarg M25 parking light, and PIAA super whites for the turn signals and cornering light. I must say the lighting quality is great. Of course this cost much much more than what you can probably get, but I had a preference for PIAA. Good luck.
Sarin
__________________
-Sarin
02 GLE - Majestic Blue/Frost Leather
6k D2R HID - AE/Clear Headlights - 3k HID fogs w/Lexus Capsules - Exterior LED's - AE Tails
Smoked Sidemarkers - 15% tint - G35 Coupe 18's - Short Ram Intake
Past:
86 SE - MOTM
97 GXE SC'er - RIP 10/12/08
http://www.nwmaxima.com
maximase86 is offline   Reply With Quote
Old 12-24-2002, 10:30 PM   #3
I'd have to go with Sarin's recommendation and stick with PIAA's if you want really bright lights. The cheaper bulbs that say they are blue actually use some kind of filter to make the light come out blue. Unfortunately, this absorbs a lot of wavelengths of light, so the light output is actually less. PIAA's don't have a blue light to them, but they do have a really bright white light that still looks cool. They run at a higher temperature which makes them bright white and output more light.
The only way to get true blue light is to get a really high temperature bulb. That is why the color is blue, because the bulb is hotter. It's the same way that stars work, cool stars are red, then they get orange and yellow as they get hotter and finally blue when they're really hot.
The hotter bulbs also put out more light. You'd probably have to go with a HID conversion kit, which costs a lot of money, and some people don't recommend them because of the poor quality of the stock headlight housings.
I don't know what your talking about when you say 'headlight cover'. I'm assuming your talking about the entire headlight housing. Those can be a bit pricey brand new, usually around $100-120. You should replace them when you get a good set of bulbs, as older ones tend to discolor and eventually leak water into them, which can further hamper the light output.
-C-
Charles Bisel is offline   Reply With Quote
Old 12-24-2002, 11:38 PM   #4
One thing I want to point out about the PIAA extreme white bulbs, they have a blue tip, when your headlights are on, they are a high temp white, but the blue tip glows and reflects off the reflectors, and when your looking at a certain angles, you can see nice blue. The PIAA super whites don't do that because the tip is gray, Though the bulbs are coated purple.
S
__________________
-Sarin
Past:
86 SE - MOTM
Old 12-25-2002, 04:03 AM   #5
Send a message via MSN to GundamWZero Send a message via Yahoo to GundamWZero
I got some hyperwhites in my car, but I want them in my parking lights too...........
__________________
SHIFT_period.
1986 Nissan Maxima 5 spd. R.I.P
2006 Nissan Altima
18" Niche Rhine Rims/ ZR-rated tires
Kenwood DDX6019
Kenwood GNA510 Navigation System
Kenwood LZ-702IR Headrest Monitors x2
Alpine MRP-M850 800w Mono Amplifier
Alpine MRP-F250 360w 4/3/2 Channel Power Amplifier
Boston Acoustics Speaker System
Boston Acoustics Subwoofer
2007 Nissan Armada Fully Loaded.....
GundamWZero is offline   Reply With Quote
Old 12-25-2002, 12:18 PM   #6
How much would the PIAA extreme white bulbs cost for a pair? Would I need the same bulbs for the corner lights too?
maximase86
I think I can see the blue tip on your car! Very nice!
Charles Bisel
My sister got in an accident and scratched the front driver side bumper and cracked the headlamp too. The lights worked and every thing but the outer cover that protects the bulbs was damage. It is the glass shell that protects the bulbs on newer cars.
It is sort of like the one on the civic below but it's stock of course.
Old 12-25-2002, 07:41 PM   #7
maximase86
Charles Bisel
Expect the bulbs to go from $65 a pair to $90 a pair. The cornering light isn't neccessary, but I did it to keep a consistent look. Yup, those be it in the pic I have in my signature, its a really cool look on and off. As for the headlamp, we have composite lamps like the newer cars. The cracked part is also made out of glass. You will have to replace the entire housing. You can get one from a salvage yard, but the reflectors tend to be in questionable condition. I'm running into this issue with the passenger side headlamp on my car that I replaced. I tell you one thing, the assembly isn't cheap new so be prepared.
Sarin
__________________
-Sarin
Past:
86 SE - MOTM
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
