Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Thread Tools Display Modes
Old 12-21-2002, 10:58 PM   #1
What is wrong with my brakes?
I have a serious problem here. I think there is something wrong with he hydruallics on my 87 Maxima. I took my Maxima out today after coming from school and when I pressed on the brake pedal it did not give resistance. I took out for a spin to see what was wrong and unfortunately I had to push the pedal all the way down to stop the car and the stopping distance was a little longer then usual. At first when I checked the brake fluid I found it empty. I then added some but that still did not solve the problem. The pedal gave resistance when I turnred off the car but when it was on the pedal just went all the way down again. i asked my mom what happened and she told me it was using up all the fluid way too much and she had to add some frequently like in the past three weeks.
Does anybody know where I can get the parts cheap? Can anybody give me an esitmate of how much it would cost to fix? Is there a good place to get it fixed in the Washington, D.C. area?
Implicit is offline   Reply With Quote
Old 12-21-2002, 11:33 PM   #2
The Man is watching.
Send a message via MSN to maximase86
One of a couple of things. First I would check the master brake cylinder, (you add fluid here). Look for fresh brake fluid, make sure all your lines are connected securely and properly. Try to inspect all the brake lines for cracks and leaks. Second, get the car in the air with some jackstands, remove the wheels and check all the flexible brake lines and calipers. My first guess is that you got a bad master brake cylinder, if that isn't the problem, then you got a bad caliper, or a break in the line somewhere. It may help to have someone pumping the brake while your inspecting everything. Also when your filling the resevoir, you want someone pump the brake pedal, it allows pressure to build up in the brake system. Oh one last thing. Inspect the vacuum line going into the brake booster. Start from there and keep up posted.
Sarin
__________________
-Sarin
02 GLE - Majestic Blue/Frost Leather
6k D2R HID - AE/Clear Headlights - 3k HID fogs w/Lexus Capsules - Exterior LED's - AE Tails
Smoked Sidemarkers - 15% tint - G35 Coupe 18's - Short Ram Intake
Past:
86 SE - MOTM
97 GXE SC'er - RIP 10/12/08
http://www.nwmaxima.com
maximase86 is offline   Reply With Quote
Old 12-21-2002, 11:59 PM   #3
Quote:
Sarin
Thanks alot! Will do! If the lines are damaged do you know how much it would cost to fix?
Old 12-22-2002, 03:34 AM   #4
Send a message via MSN to GundamWZero Send a message via Yahoo to GundamWZero
Quote:
That is the good thing about older cars....... parts are cheaper.
__________________
SHIFT_period.
1986 Nissan Maxima 5 spd. R.I.P
2006 Nissan Altima
18" Niche Rhine Rims/ ZR-rated tires
Kenwood DDX6019
Kenwood GNA510 Navigation System
Kenwood LZ-702IR Headrest Monitors x2
Alpine MRP-M850 800w Mono Amplifier
Alpine MRP-F250 360w 4/3/2 Channel Power Amplifier
Boston Acoustics Speaker System
Boston Acoustics Subwoofer
2007 Nissan Armada Fully Loaded.....
GundamWZero is offline   Reply With Quote
Old 12-23-2002, 01:58 AM   #5
yeh me too, same issues
mechanic said it was the master cylinder was leaking, that needs to be replaced around $200 total, shoud be.
__________________
2000 GLE Sterling Mist, K&N DropIN, H4 Stock, H3 PIAA SuperWhites, 30% Tint All
1987 GXE Max, stock for now (Best Max Ever)
Philly is My Home.
mphilips is offline   Reply With Quote
Old 12-23-2002, 11:04 AM   #6
Yes. I found out it the problem is with brake booster/master cylinder area. I poured some breake fluid in and Icould see it leaing underneath the car.
Where are you getting your car fixed and does that include the part?
Also should I order the part online?
P.S.: like your sig this truely is thebest Maxima ever they do't build em lie this anymore. Just imagine the features it had for i's day. Even the 3rd gen didn't have as many features.
Old 12-23-2002, 05:27 PM   #7
I got the master cyclinder online, http://www.thepartsbin.com/import-auto-parts.html
I am going to the dealer to put it in, cause, my local mechanic, isnt so good..
Yes Indeed Thanks, 87-88 MAX, were the best and still is.
__________________
Philly is My Home.
Old 12-23-2002, 05:44 PM   #8
just rememberd, I went to the local parts store, rs straus, and they had it for $70 bucks, $30 core, so like $40 net.
__________________
Philly is My Home.
Old 12-23-2002, 08:52 PM   #9
What make you think the dealer is better? They are ripping you off if your paying $200 and supplying the part. I bet ya you can find another mechinic that can do that for you for half that price. On top of that, 85-88 is the best, not just 87-88.
Sarin
__________________
-Sarin
Past:
86 SE - MOTM
Old 12-24-2002, 12:05 PM   #10
Does that website send you new parts or refurbished? What parts are you talking about that is $40 online?
Thanks again!
Old 12-26-2002, 06:06 PM   #11
sorry that website was just one of the many you can find online.
the $70 master cyclinder (by cardone) was found at rs straus auto parts stores, check your local store first.
__________________
Philly is My Home.
Old 01-04-2003, 01:30 PM   #12
The lowest MC I found was for $45 rebuilt and thats if I turn in my old core. Do you think I should buy new or get a rebuilt one?
Old 01-04-2003, 02:02 PM   #13
As long as it's got a decent warranty, it shouldn't really matter. You don't want to by a rebuilt one if its not warrantied.
S
__________________
-Sarin
Past:
86 SE - MOTM
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
