Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Thread Tools Display Modes
Old 12-18-2002, 12:12 PM   #1
Removing alternator on 85 Max
Hi,
I need help in replacing the alternator on my 85 Maxima. Consider me a novice. Simple question. How do you take out the alternator. I have taken out 2 screws (top and bottom) that I visibly saw. Obviously, there's another screw that's holding it that I can't see. Any advice? I have a/c. Do I have to remove the a/c to get access to the alternator? Can I do it all from under the car?
I pre-search through most of the posting but didn't find one to this simple query. Any help is appreciated.
Thanks in advance.
juba_max_85 is offline   Reply With Quote
Old 12-18-2002, 04:47 PM   #2
Re: Removing alternator on 85 Max
Quote:
Originally posted by juba_max_85
Hi,
Thanks in advance.
Make sure you remove the negative terminal on the battery first.
The alternator has 2 bolts that holds it in place , 12mm socket/wrench will get them loose and off. It's hard to see both of them but it's there on top. Also there is the 1 bolt holding it to the adjustment bracket. 10mm bolt that you turn to loosen and adjust the alternator drive belt. Screws and nuts for the electrical connections. Yeah and the connector.
Everything is done from the under the car. You don't have to do anything with the ac, but you would have to loosen and remove it's drive belt if your going to replace the alternator's belt.
It really helps to have a manual and see the layout.
First timer should take you less than 2 hours. I have replaced mine alternator 4 times now and can do it in 15 minutes, takes more time to go out and get the alternator.
Good Luck,
Al
alllw86 is offline   Reply With Quote
Old 12-25-2002, 06:18 AM   #3
Send a message via AIM to 350z2theMAXima
Im kinda a novice too at cars. If when you turn the key the car chugs only once and dies out and you hear the clickin from the starter, that would mean the alternator is shot right?? Thanx
350z2theMAXima is offline   Reply With Quote
Old 12-25-2002, 10:18 AM   #4
[b]Im kinda a novice too at cars. If when you turn the key the car chugs only once and dies out and you hear the clickin from the starter, that would mean the alternator is shot right?? Thanx
Well that clicking sound could mean the alternator is bad, but more than likely it's the battery. Winter is here and weak batteries will show their age by not holding their charge. I just comfirmed that on my friend's car. Then she went to a gas station and paid $100 for a new battery, but they also checked her charging system out.
To do a quick check on your Max, jump start the car and let it warm up, read the charging voltage on the voltmeter gauge on your dash. It should read about 14.5 volts. If so, good, the alternator is charging. The battery is on its last leg. Also make sure the battery terminals are clean and not loose. And don't overtighten them, easy to break.
Now if the voltmeter reads closer to 12volts, the alternator is not 100%. My alternator did that, read 12-14.5, I waited till it finally died then replaced it, they're about $130 rebuild with a lifetime warranty.
Your a novice alright, now's the time to change that, hope you get some tools and a multimeter for xmas.
Merry Xmas
Al
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
