Turbo a 2nd gen.
Old 06-11-2007, 02:59 PM
  #161
208max's Avatar
Originally Posted by Big_E-Dog
btw how do you know that your not getting electricity from the distributor?
dats beacuz i put a screw driver in one of the lead wire and i put it near da body of da car and there is no sparks if current were coming from the distrubutor it would spark right ??
208max is offline
Old 06-11-2007, 08:32 PM
  #162
2nd Gen Boostinator
Big_E-Dog's Avatar
awwwh man that night of been bad for the car the while car body is a ground and if you sent a spark to it you could of blown a fuse or 2 or three check those as well
but you might of not seen a spark if the screw driver has a plastic or rubber handle it would of have needed to be an all metal one
Big_E-Dog is offline
Old 06-12-2007, 07:38 AM
  #163
I love lamp.
maximase86's Avatar
Crank position sensor.
maximase86 is offline
Old 06-15-2007, 06:15 AM
  #164
208max's Avatar
where is the crank position sensor located ??
208max is offline
Old 06-15-2007, 07:44 AM
  #165
208max's Avatar
i would also like to know how to time dis engine da crank pully has 7 marks on it which one to use for tdc
208max is offline
Old 06-15-2007, 10:36 AM
  #166
I love lamp.
maximase86's Avatar
It's located inside the distributor.
S
Old 06-15-2007, 06:48 PM
  #167
2nd Gen Boostinator
Big_E-Dog's Avatar
strat on the left every ling moving to the right is 5 deg strating with zero
dont kno what degree you should be on should be on your hood
Old 06-18-2007, 10:53 AM
  #168
208max's Avatar
so if the crank position sensor is not good no power would be sent to the distributor
208max is offline
Old 06-18-2007, 04:15 PM
  #169
I love lamp.
maximase86's Avatar
No heartbeat, no spark.
S
Old 06-18-2007, 07:23 PM
  #170
2nd Gen Boostinator
Big_E-Dog's Avatar
yep, thats is waht that lil 4 wire plug is for
Old 06-18-2007, 10:01 PM
  #171
mooze's Avatar
Originally Posted by max95q
Actually the 3rd gens had the lsd's 4th gens in other countries had the lsd's but not the U.S.. If you did find one it was a Canadian model. The Fifth gens I believe have the LSD's gens. But the 3rd gens for sure had them on the Later models I believe.
92-94 se lsd
mooze is offline
Old 06-19-2007, 11:43 AM
  #172
208max's Avatar
i changed the distributor cuz the one i got with da engine was busted up and i still aint gettin spark and plus my coil is not gettin warm i suppose dat it is the coil which is responsible for this oh and when i changed the distributor i jus observed where the rotor was pointin and jus put in da new one the same way
208max is offline
Old 06-19-2007, 12:25 PM
  #173
I love lamp.
maximase86's Avatar
test the crank angle sensor. Pull the distributor, but leave the CAS sensor harness plugged in, turn the ignition on. Spin the distributor shaft. You should hear the fuel injectors operate while the distributor is spinning. If that is the case, the CAS is fine, something is happening between the ECU and the ignition coil, or you have a bad coil...OR the method for testing spark is flawed.
To test spark, I personally use a new or known good plug...hook one of the coil wires to it and hold the tip against a grounded surface (be sure you don't hold the plug itself, but rather the boot or wire). Crank the car over. Spark should be bright almost white for a strong spark. If the spark is dim, you could potentially have a problem. If you get spark, chances are you aren't getting fuel.
Always check the basics...air, fuel, and spark.
S
Old 07-02-2007, 07:29 AM
  #174
208max's Avatar
well for now i know dat my crank angle sensor is working and i know dat i am not getting any power from my coil da coil isn't sendin any kind of power what so ever to da distributor
208max is offline
Old 07-02-2007, 07:30 AM
  #175
208max's Avatar
oh and how do u check if ur mass air flow sensor is good
208max is offline
Old 05-08-2008, 09:20 PM
  #176
irishkid4evr's Avatar
nice
irishkid4evr is offline
Old 05-08-2008, 09:21 PM
  #177
nice i am thinkin bout supercharging my 03
Old 05-26-2008, 01:51 AM
  #178
last one's Avatar
looking for some help
not afraid to ask for it i need some help finding performance parts for my 90 max and was wondering if anyone could help cause i cant find **** except for andys autosport and the barely have anything so lend a helping hand to a guy who needs it
last one is offline
Old 05-26-2008, 10:38 AM
  #179
I love lamp.
maximase86's Avatar
Wow...so you post in a sticky thread in an older generation forum. Wow...that did you lots of good.
Old 05-26-2008, 05:57 PM
  #180
2nd Gen Boostinator
Big_E-Dog's Avatar
if you want a big performance then come over to the boosted side....
and check ebay
put in 90 maxima and see want you get.
Old 11-20-2008, 07:27 AM
  #181
adl90's Avatar
Originally Posted by KALSC
Well, here is the link to the site where I will be documenting the VG30ET swap. I haven't posted anything yet, there is an explanation at the site. You would do good to visit the link and then bookmark it as well.
http://www.sqntech.com/maxima/
hey...i tried visiting the link...wouldnt go through...i wanna try to get a turbo on my 86 wagon...so if theres another way to get to the site let me know
adl90 is offline
Old 11-20-2008, 02:33 PM
  #182
Niku-Sama's Avatar
your also trying a link that was posted on 12-13-2002 and the user hasnt been active in about a year or more
Niku-Sama is offline
Old 11-21-2008, 01:01 PM
  #183
adl90's Avatar
that could very possibly be it
adl90 is offline
Old 03-11-2010, 10:29 AM
  #184
Dave87's Avatar
I'm pretty sure I may be your MAF sensor and I say this because I had a '86 Z31 that didn't start sometimes due to it. It took me while to figure this out after the many hours I spent swapping parts from other Z31's. But I hope it all works out for you.
Dave87 is offline
Old 03-11-2010, 11:53 AM
  #185
chrome91's Avatar
that post is over a year old so i think he figured it out already lol
chrome91 is offline
Old 03-31-2011, 11:39 AM
  #186
rmd08's Avatar
Turboo!!!
rmd08 is offline
Old 03-31-2011, 11:40 AM
  #187
rmd08's Avatar
haha sory
rmd08 is offline
  #188
rmd08's Avatar
sorry*
rmd08 is offline
Old 04-10-2011, 08:40 AM
  #189
lww
lww's Avatar
Do we have a moderator that can split this thread? Or possibly delete the posts that aren't relevant to it's stickiness?
lww is offline
Old 07-06-2013, 01:11 PM
  #190
WARZAZ's Avatar
Max 2nd gen 300zx turbo swap
Hello,
Anybody can help me tuning my 1986 turbo swap? It runs but it's been a ***** to tune, I've been multiple times to the smog (I'm in CA) and it always fail. Last time it had 5000ppm of nitrous oxide LOL. Anyway, I will give details after I get an answer since I am not sure this forum is still active... Please HELP! Thanks,
WARZAZ is offline
Old 07-14-2013, 01:40 PM
  #191
WARZAZ's Avatar
Max 2nd gen 300zx z31 turbo swap
Hey, following up with the tuning of my 86 max with 300zx z31 turbo swap.
Big-E-dog told me it could be that I have a 200sx distributor in there (yes the 1987 200sx has the same engine as the max and 300zx) so I got a 1984 300zx turbo distributor (part # ends with 01P00) and I also swapped the idle-up solenoid valve to a turbo one since I had one from a N/A.
The problem is that the VG30E and VG30ET idle-up solenoid valve units have different plugs so I had to mess up with the wiring, and I am not sure that this works right (that the ECU signals are sent properly). I guess that's really the main question, since the car drives OK but rpms are not very stable at idle.
After doing these two changes + rpm tuning + timing I can say it is close to completion, but still not perfect and I am still not willing to test my luck at the smog ($50 every time :-((
Would appreciate any input from someone who did the swap and remember encountering a similar issue. How to get the idling steady?
WARZAZ is offline
Old 10-08-2015, 12:34 PM
  #192
WARZAZ's Avatar
Hello,
Looks like this thread's unfortunately dead and I joined the train way too late... I would appreciate if anybody who has experience with turboing a 2nd gen maxima wants to share his experience. In particular, what solenoid valve they used with their turbo setup and how they tuned it to pass smog. Thanks,
WARZAZ is offline
Old 03-09-2016, 04:07 PM
  #193
robertpatten.13@gmail.com's Avatar
Originally Posted by WARZAZ
Hello,
Did you ever get the build specs for turboing a VG30E 2nd gen? I'm looking to do the same thing but don't know where to start and I'm also a bit late
robertpatten.13@gmail.com is offline
Old 03-10-2016, 05:38 AM
  #194
Dave87's Avatar
So I do have a 2nd gen, but I'm not building that car. However I do have a Z31 N/A which has the same motor. I purchased all new internals because the power goal I have is pretty outrageous for stock internals. I'm going to use the Nistune ECU for tuning and I believe it will keep the car smog compliant. I'm not sure as that's not something I have to worry about.
Dave87 is offline
Old 03-11-2016, 06:37 PM
  #195
akurtzer57's Avatar
Stock VG have been proven to make mid 500s. If have any questions pm me I have a z31 as well run nistune on that as well as my 3rd Gen maxima.
akurtzer57 is offline
Old 06-13-2016, 09:17 PM
  #196
Cboogie8484's Avatar
Hey whats going on Im Chris From Nj Im selling my 1988 maxima 5spd for $1000 128k orginal miles..new suspension ect.. if you know anyone that interested give me a call or text 201-926-0881 or reply here i will sned pictures
Cboogie8484 is offline
Old 01-16-2017, 07:50 PM
  #197
WARZAZ's Avatar
Hi,
After being stopped by the cops a few years ago w/o registration (however car was insured), I decided to stop drive the Maxima turbo until I have more time to tune it and pass the smog. So here we are fast forward several years later LOL
I am checking electrical connections and try to map their correctness based on the 1986 Maxiima harness (with custom modifications to accomodate 300zx turbo parts such as AAF and FICD), the 1986 300zx turbo ECU, using Nissan factory manuals from a 1986 maxima and 1986 300zx.
It turns out I had two sets of wires that were wrongly connected. Now, I know that all signals go to the correct pins on the ECU.
There are still issues though, and I wonder if it's due to the fact that my 300zx turbo ECU is for Federal emissions when my car is CA (?). So I found a 1985 turbo ECU that is for CA emissions and will be swapping and testing it tomorrow.
Also, I found a funny albeit interesting thread that deals with swaps such as the one in this thread:
http://www.zdriver.com/forums/280zx-...cu-swap-21623/
It is full of good info and thought it will help the 2nd gen max community to troubleshoot their own issues. Good luck!
WARZAZ is offline
litch
123
01-04-2024 07:01 PM
James92SE
142
01-02-2024 09:23 AM
hcarter1112
42
07-18-2022 03:35 PM
aw11power
10-10-2021 04:57 AM
09maxshawn11
09-30-2015 10:28 AM
Quick Reply: Turbo a 2nd gen.
