Lets see. You say it comes seems to be coming from the accessories area of the motor, power steering is fine. I would check a couple of other things. Check all your belts, make sure the surface on the belt that goes around the pulleys are in good condition, not shiny cracked etc. Next check the A/C compressor clutch, these can be notorious for making strange noises. I would also check your alternator. Though you said it can be replaced, from experience, an alternator can go bad at anytime. If all those check out, I would check the bearings on all the accessory pulleys. It could be that one of those have a bad bearing and it could make a noise someone what similar to what your are describing.
Hope this helps.
Sarin
__________________
-Sarin
02 GLE - Majestic Blue/Frost Leather
6k D2R HID - AE/Clear Headlights - 3k HID fogs w/Lexus Capsules - Exterior LED's - AE Tails
Smoked Sidemarkers - 15% tint - G35 Coupe 18's - Short Ram Intake
Past:
86 SE - MOTM
97 GXE SC'er - RIP 10/12/08
http://www.nwmaxima.com
