Go Back   Maxima Forums > Maxima Discussions > 1st & 2nd Generation Maxima (1981-1984 and 1985-1988)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 11-22-2002, 01:33 PM   #1
Super Moderator
2nd Gen. Mods
Gude Performance Headers and Cams
www.gude.com
Wings West body kits
www.wingswest.com
Kaminari Body Kits
http://body-kits.com/kaminari/maxima.htm
Erebuni corp
http://www.erebunicorp.com
Homemade Urethane Motormounts
http://www.geocities.com/CapeCanaver...-r/mounts.html
Want 450 hp project vg30et heres how at z31.com
http://z31.com/jwt.shtml
KVR Performance brakes and rotors
http://www.kvrperformance.com
Indiglo gauges. Procarparts has them for 86-88 applications
www.procarparts.com
Another great site to see and look up performance parts
with one of if not the most elaborate listing of performance parts for the 2nd gen maxima:
http://secondgenmax.sifen7.com
__________________
Shift_PRND21
1995 BLK/BLK SE:
Warpspeed superflo y-pipe, Tokico Illumina Suspension Kit,
5th gen Strut bar, ADDCO RSB,
17x7 ADR SZ1 rims, red laquered calibers, Nexen N3000 tires,
Smoked Diamond clear turn signal lens,
AE Headlights/clearance lights/foglights, rewired fogs
max95q is offline   Reply With Quote
Old 11-23-2002, 01:10 AM   #2
Super Moderator
Mods for 2nd gen Maximas
Intake:
-K&N Panel drop in filter
-You can make a custom CAI(Cold Air Intake) out of pcv piping or from aluminum or plastic drier hose with a cone filter on the end. You can also take out the Factory Air box and get a Nissan Adapter for maximas and just add a cone filter to it.
90 and up Stanza 60mm throttle body
For better flow on the intake side you can add a 60mm throttlebody from a 90 and up Stanza. Note this would require you to port out the intake collector to get the same diameter as the throttlebody for the best use.
Exhaust:
To help release and excuse some of that extra air you're going to need to open up the exhaust side. Your options.
2.5" Catback setup to open up the back end with your choice of a performance muffler. Pacesetter has a catback set up for our applications or you can just custom make yours at a muffler/exhaust shop.
A Hi Flo Cat
And if you really wanted to see some gains you could take out the factory Y pipe or downpipe remove the precat section and replace it with a straight through pipe. Most likely for racing applications only.
Suspension:
Springs
Suspension Techniques Lowering springs: lowers 1.5 inches on all fours for 86-88 maximas
Intrax lowering springs: Lowers front 1.8" Rear 1.6" for 86-88 Maximas.
And if you are lucky to find them Eibach had some for our applications which lowered the car 1" all around
Struts
KYB has the KYB GR2s available for our cars to help tighten the suspension
Tokico also has a set that help tighten up the turns as well
FSTB(Front strut tower brace)
Currently there arent any out for our cars. You can find a 93-97 Nissan Altima front strut tower brace and modify the brackets on the ends to fit our strut towers.
RSB(Rear Sway Bar)
ADDCO has a sway bar for our applications which increase the diameter to a respectable amount to help control the rear end in hard cornering
Camber adjustments can be done with Intrax's Camber kit for 86-88 maximas they are rarely needed but if so they are available for the front and rear.The front part number is 99.9.007, adjustment is 1.75 +/-, list is $32.00 per side. The rear camber part number is 99.9.035, adjustment is -2.0-+2.75, list is $76.00 per
side. These prices may differ in time. Website www.intraxsuspension.com
Wheels:
Any wheels that have a 4x114.3 should fit the 86-88 Maximas I believe safe offset is between 40-45
Any year except the 2002 Altima rims will fit our cars
The Se-r Spec V 17" five spoke wheels will fit our car as well.
Other Mods:
Unorthodox Racing underdrive pulley to free up some hp from the engine.
Cams can be had from ISKY. ISKY 262 cams are a mild grind which give good mid to high rpm hp
Transmission cooler
Hayden or b&m are pretty well known tranny cooler companies.
Transmission coolers help reduce heat and prolong tranny life. They all come in different sizes. The most common used is the Hayden 404 size(I have this one). Its good for big RV's, diesel engine trucks, Hualing big boats etc so you know they will be good for our cars. There is also a smaller 403 model that works good as well. Tranny coolers can range from uses on compact cars up to huge RVs some even have electrical fans to help increase cooling. Tranny coolers can be found at any Pepboys, Advanced Auto Parts stores, and you might want to check Autozone too. They range anywhere from (guestimate)30.00 on up. And only take about 30-45 minutes to install. This upgrade could possibly prevent you from spending close to 2k for a new transmission.
Brakes
Stainless Steel Braided brake lines are available for the 2nd gens 87-88. For better Braking and shorter braking distance. Its avail. through Stillen at Stillen.com for 62.00
__________________
Shift_PRND21
1995 BLK/BLK SE:
Old 11-24-2002, 11:50 PM   #3
Super Moderator
Turning your N/A vg30e into a vg30et
Here are two links to successfully turboing the vg30e
One from z31.com
http://www.z31.com/nfaq/faqview.php?ParentID=7
And heres the other site
http://home.pacbell.net/ehouts/z/swap/
Even though these swaps are done on Zs. They carried the same engine our cars have so its all the same thing.
__________________
Shift_PRND21
1995 BLK/BLK SE:
Old 04-07-2003, 11:35 PM   #4
Super Moderator
Since our cars are similar to the Stanza and early 90's 240sx's here are some parts that can become retrofit to ours.
For reference U12: Stanza
U11: 2nd gen Maxima for U.S., Bluebird and early model Stanza for other countries,
1. TB upgrade. The U12's(Stanza) KA24E TB is bigger than the
U11's(2nd gen Maxima) VG30E TB. Direct fit. A lot of VG30E owners done it. Price, kinda so-so. Benefit: more throttle
response, more power at the top end.
These are possible mods that I was referred about by a previous Stanza owner. Do any of this at your own risk
__________________
Shift_PRND21
1995 BLK/BLK SE:
Old 04-08-2003, 09:25 PM   #5
I love lamp.
maximase86's Avatar
Send a message via MSN to maximase86
One note about the TB upgrade, in order to really benefit from that mod, you have to match port the intake collector inlet to 60mm too. That can be done by removing collector (you don't have to remove the lower intake), and either machine it yourself, or take it to a machine shop.
S
__________________
-Sarin
02 GLE - Majestic Blue/Frost Leather
04 Sentra SE-R Spec-V - Super Black/Silver-Black Cloth
Northwest Nissan & Infiniti
maximase86 is offline   Reply With Quote
Old 11-30-2003, 08:27 PM   #6
Super Moderator
Changing your dashlights to a different color
This dashlight mod was done in the color red but can be done in other colors of your choice.
Well guys, I did it and now have cool red dashlights. The only difficult part was the instrument cluster, other than that it was easy. Here's a rundown of how I did it.
Shifter, ashtray and lighter - These simply have the bulb filters ( or condoms ). I couldn't find red bulbs in that size so they got painted with transparent red nailpolish.
Heater controls - The back of the panel is painted green. Simply snap the translucent peice out and replace it with one from an 87-88 Pathfinder. They are exactly the same, but the Pathfinder has orange illumination. There is a diffuser on the back of it, simply peel it off to let a bit more light through. Paint the bulb red and you're set.
Instrument cluster - Here's the tricky part. I tried changing the bulbs for red ones, 194's are readily available in many colors. It worked, but was pinkish and dim. If any of you have had it apart, or changed a bulb, there are little plastic domes where the bulbs go. They are sort of a bluish green. So I dismantled the cluster, note the position of the needles and removed them. They come off fairly easy. Next I pulled the gauge faces and then I could remove the offending plastic domes. Reassemble everything, check the guage operation, and install three red 194 bulbs and paint the two small ones.
Voila! Red dashlights. It looks so much better than the irritating green. I'll try to get a decent pic for you guys this evening of the new look. I think the next project will be changing the keyless entry illumination to something more appealing.
Here's a link to the thread with pics
white/yellow lights
Courtesy of wylie-c
Old 02-27-2005, 08:00 PM   #7
Send a message via AIM to Niku-Sama
i've been keeping trace of some places over the time i have owned my car but i thought the links where in here:
Unorthodox Lightned Flywheels
Some Higher Flow Injectors
Nopi has Illumina Fronts
Niku-Sama is offline   Reply With Quote
Old 08-04-2005, 11:08 PM   #8
2nd Gen Boostinator
Big_E-Dog's Avatar
300zx ECU and MAF
__________________
CUSTOM HEADLAMPS/CARBON FIBER/FT&RTSB/OIL COOLER/LED'S/VG30ETT/PATHFINDER INTAKE MANIFIOLD/2.5" EXHAUST/NISMO MUFFLER/HKS TT, BOV, BOOST GUAGE/Q45 BBK/K&N/2x GARRETT T-25/NISTUNE/......
Big_E-Dog is offline   Reply With Quote
Old 09-26-2005, 04:43 PM   #9
Super Moderator
2nd Gen. Custom Projectors
Click on the link below:
http://forums.maxima.org/showthread.php?t=427473
Old 09-26-2005, 05:14 PM   #10
2nd Gen Boostinator
Big_E-Dog's Avatar
Quote:
Originally Posted by max88q
only if you dare!
V 1.1.0
look for v2.1.0
Old 12-02-2005, 06:11 AM   #11
Super Moderator
Are you needing the color code to install an aftermarket stereo? Here it is
Constant 12V+ Green/Red
Switched 12V+ Pink/Brown
Ground n/a
Illumination Red/White
Dimmer n/a
Antenna Right Rear
Front Speakers 5 1/4" Doors
Left Front (+) Blue/White
Left Front (-) Blue/Yellow
Right Front (+) Brown
Right Front (-) Brown/White
Rear Speakers 5 1/4" Rear Deck
Left Rear (+) Red
Left Rear (-) Green
Right Rear (+) Blue
Right Rear (-) Pink
__________________
Shift_PRND21
1995 BLK/BLK SE:
Old 02-26-2006, 05:27 PM   #12
2nd Gen Boostinator
Big_E-Dog's Avatar
throttle body difference pics
S
240sx throttle plate on bottom (red) and maxima on top (gold)
240sx tb on bottom and maxima on top....
__________________
Old 02-26-2006, 05:28 PM   #13
2nd Gen Boostinator
Big_E-Dog's Avatar
Ground n/a
Dimmer n/a
Antenna Right Rear
Left Rear (+) Red
Left Rear (-) Green
Right Rear (+) Blue
Right Rear (-) Pink
__________________
Old 03-15-2006, 10:02 AM   #14
Send a message via MSN to jp50662
which is the power antenna power wire??
jp50662 is offline   Reply With Quote
Old 03-15-2006, 05:43 PM   #15
2nd Gen Boostinator
Big_E-Dog's Avatar
the blu with the white stripe i think if it isint then its the staright blu one
Old 03-23-2007, 12:14 PM   #16
It's amazing how much can be done to these things!
barneyboy01 is offline   Reply With Quote
Old 03-23-2007, 12:20 PM   #17
This doesn't really have much to do with mods...but what could I get out of a '92SE 5spd w/223.xxx and a slipping clutch?
Old 05-03-2007, 02:43 PM   #18
Quote:
Originally Posted by Big_E-Dog
300zx ECU and MAF
Hey Big_E-Dog
I like the head lights and tail lamps, what parts did you use and how did you get them to fit? I have a 1987 Maxima that I definately want to change the lightiong on.
Hagii73 is offline   Reply With Quote
Old 05-03-2007, 08:23 PM   #19
2nd Gen Boostinator
Big_E-Dog's Avatar
for the headlamps.....
you gotta do a lotta hacking check above for the projector retrofit
the taillamps i just used 50+ led truck units and yellow ones to match the blinkers
__________________
Old 05-03-2007, 08:48 PM   #20
sweet -- thanks.
Old 05-07-2007, 07:52 AM   #21
I cannot find the indiglo dash mod, still searching. Do the tail lights use more power than the factory bulbs? I ran into an issue where I hooked up a cd player ( the radio was trash) and now my tail lights and dash fuse blows.
I took the amp off and tested and it still blew. I also tried unplugging the radio from the hot power and the fuse still blew.
Old 05-07-2007, 08:12 PM   #22
2nd Gen Boostinator
Big_E-Dog's Avatar
well if you cant find it (reverse glo guages)ill sell you one that i have for like 20 shipped just hit me up
sometin you dont have hooked up right check the wiring diagram
__________________
Old 05-11-2007, 10:32 AM   #23
How can I contact you for the gauges? I figured out the issue, instead of wiring the radio to the harness, I ran new wires and fuses to the battery and grounded the radio to the chassis. Now I need to get a new antenna cause the new cd player doesnt match up to the original antenna plug.
Old 05-16-2007, 10:04 PM   #24
Send a message via MSN to 208max
i am swapin a vg30et into my maxima and is wondering will the vg30e ecu work on da et and if not why ??
208max is offline   Reply With Quote
Old 05-20-2007, 04:39 PM   #25
2nd Gen Boostinator
Big_E-Dog's Avatar
Quote:
no, fuel mps are different but you could use a ecu from a 300zx turbo automatic or five speed, plus by the way if you tried it i dont think itl start
__________________
Old 07-23-2007, 01:17 AM   #26
How hard is a VG30ET swap? I'm talking about mounts and everything bolting in and such.
Katapl is offline   Reply With Quote
Old 08-02-2007, 09:38 PM   #27
2nd Gen Boostinator
Big_E-Dog's Avatar
front motormount and turbo downpipe thats it.
Old 01-28-2008, 02:37 PM   #28
87 maxima advice
ok so i have an 87 maxima with a vg30e. it has 235k on the clock.it runs like new. but i would like to get a blown or rebuilt (doesn't matter cause im gunna build it) vg30e or vg30et. and i would like to know if any other motor swap is applicable
nismoduarte is offline   Reply With Quote
Old 01-28-2008, 06:38 PM   #29
2nd Gen Boostinator
Big_E-Dog's Avatar
if you have an infonite amount of money then anything is possible..
__________________
Old 01-28-2008, 10:16 PM   #30
where can i get some springs
Old 01-29-2008, 11:10 AM   #31
2nd Gen Boostinator
Big_E-Dog's Avatar
Quote:
top of the thread under suspension
__________________
Old 02-28-2008, 11:56 PM   #32
Where can I find the Front Lip that comes stock on all 88 Maxima's. The lower part of the front bumper that sits behind the stock fog lights. Mine ripped in half and I can't find a replacement. Any ideas?
enagee is offline   Reply With Quote
Old 02-29-2008, 09:33 AM   #33
2nd Gen Boostinator
Big_E-Dog's Avatar
junkyard or shell out some cash at nissan....
__________________
Old 02-29-2008, 08:14 PM   #34
I figured those were the only options but thanks for confirming. Anybody know any good ones here in Maryland? I went to 2 today and only saw 1 2nd gen max.
Old 02-29-2008, 10:57 PM   #35
2nd Gen Boostinator
Big_E-Dog's Avatar
Quote:
just gotta look , im here in cali and i see 2 but theytr all deformed and crap, i might just buy one from nissan, and carbon fiber it.....mmmmmm carbon fiber!!!!
__________________
Old 03-03-2008, 01:22 PM   #36
I think i'll go the dealer route but my max is white so probably no carbonfiber. Thanks for the info. I hate to post another question here like this but I don't have rights to start a thread yet(and I agree with that) so I don't have a choice.
I had my power steering pump and rack&pinion replaced last week. Since then the car has been doing weird things in corners, on the highway, at anything above 55mph. When I'm in a corner (right or left doesn't matter) i'll have the wheel turned to go through the corner and the car will pull harder to the right or left depending on the corner and I have to slow down and turn my wheel in the opposite direction to adjust sometimes depending on how fast I'm going it feels like i'm about to lose control of the car altogether. I'm taking it back to the Mechanic today for him to recheck his work but I wanted to see if anyone else has seen this problem. (enagee88SE)
Old 03-06-2008, 09:43 PM   #37
Send a message via AIM to ProphetVG30E
I HAVE 3 INJECTORS OR AN 87-88 VG30E, BEST OFFER TAKES EM
ProphetVG30E is offline   Reply With Quote
Old 07-29-2008, 03:43 PM   #38
Listen guys I'm new to Maximas, former 240sx owner, and I just bought an 87 wagon. I NEED AFTERMARKET PARTS. Bluebird stuff, coilovers, anything! Help me out please with any fresh leads or info, if you have anything to sell, tell me. I'm ordering wheels today, but other than that, I need to lower it nicely and do some other JDM or euro spec stuff (whichever just want to get rid of the stock USDM appearance) to it. Hit me up at NismoTyler@hotmail.com thanks a million guys.
NismoTyler is offline   Reply With Quote
Old 07-30-2008, 09:05 AM   #39
2nd Gen Boostinator
Big_E-Dog's Avatar
rinkya.com, and enter bluebird
__________________
Old 11-05-2008, 10:48 PM   #40
i know it might sound insane...but would it be possible to make my 86 maxima wagon all wheel drive
adl90 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
