1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
fit 15inch wheels on a 5.5th gen
Old 08-27-2015, 08:12 PM
VQ'ed's Avatar
I was wondering if I retrofit 4th gen caliper brackets/brake rotors on a 5.5th gen, would I be able to downsize to 15inch to get 23.5/8.0/15 for drag racing?
VQ'ed is offline
Old 08-28-2015, 07:09 AM
Brudface's Avatar
Pretty sure that depending on what the offset of the supposed rims are WITH the correct spacer you should be able to run them with the stock brakes.
What rims are you looking at?
Brudface is offline
Old 08-28-2015, 07:16 AM
VQ'ed's Avatar
The lightest possible I can fit, I just want to have 15 inches because of the slick size choice I'm looking to run (23.5/8.0-15 E.T drag radials)
If I can figure a width and offset layout that can be installed on stock brakes, with spacers to clear the outer edge of the caliper, i'd be pleased.
VQ'ed is offline
Old 08-28-2015, 07:23 AM
VQ'ed's Avatar
15x7 0 offset 5x114.3mm would probably fit. Black steelies would do the job...
VQ'ed is offline
Old 08-28-2015, 07:53 AM
schmellyfart's Avatar
Spacers will not help fitting 15's over 5.5gen brakes.
Yes 15s will fit if you install 4th gen calipers and rotors. But then you have the issue of the different bolt size for the hub to torque member bolts. You could either drill and tap the torque member for the larger bolts, or find/have made a concentric spacer that will center the smaller 4th gen bolt in the 5.5 gen hub.
Or you could go to town with an angle grinder on the 5.5gen caliper. We chose this option on my buddies 5.5 gen when we were installing a set of millenias on it.
schmellyfart is offline
Old 08-28-2015, 08:07 AM
VQ'ed's Avatar
I found a set of ford ranger rims on 15x6.5 7offset for 51$ each brand new. I might try to fit them on the car just to see the space I have and work to do on the caliper shaving
VQ'ed is offline
Old 08-28-2015, 10:58 AM
VQ'ed's Avatar
I confirm that Ford Ranger rims in 15x6 5x114.3mm +7 offset bolts on directly without ANY modifications on oem brake size on 5.5th gens. My part number is X40709 from Macpek, Canada.
Nice pioneering. Next 23.5/8.0/15 gummies from my friend Mickey thompson.
VQ'ed is offline
Old 08-29-2015, 09:23 AM
How much do those wheels weigh?
Old 08-30-2015, 05:32 PM
VQ'ed's Avatar
steel 15inch rim...not weighted but not that light. say 15-16lbs. anyway im gonna try these on with slicks in 23.5/8.0-15
VQ'ed is offline
Maxima_Joe
11-25-2015 08:19 AM
Maxima_Joe
10-15-2015 08:01 PM
Cant_Get_Ryte
08-28-2015 06:41 AM
VQ'ed
08-19-2015 04:52 PM
twotonezed
08-16-2015 11:41 AM
Quick Reply: fit 15inch wheels on a 5.5th gen
