1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Full Spool for Maxima (aka Fully Locked Differential) - Interested?
Old 05-05-2010, 12:45 PM
NWP Engineering.com
Aaron92SE's Avatar
I am just curious if any serious Maxima racers are out there that would like to get their hands on a full spool for your Maxima. A spool permanently replaces your differential resulting in a fully locked front end with an equal amount of power to both drive wheels at all times.
Here is what it will look like:
I am thinking about having a custom one made. It will be made out of steel and weigh 5-10 lbs. The stock VLSD unit weighs 31lbs and the stock open diff weighs around 20lbs. Plus, having a full spool will be better than welding your spider gears. And NHRA and IHRA do not allow you to weld the gears. They only allow a type of spool.
I checked the part numbers of the differential real quick. The AT diffs between 92-99 are the same. And the MT diffs are the same between 92-99. But the MT and AT diffs have different part numbers. Does anybody know if the MT and AT differentials can be swapped? Also, I'm assuming that the open and viscous differential can be interchanged as well. If anybody has any ideas, please post.
Ballpark price would probably be around $400 for the spool.
Aaron92SE is offline
Old 05-05-2010, 01:19 PM
NYC A32's Avatar
More info on how it works? I'm a 97 auto and trying to beef up the tranny but wonder if this acceptable for a DD.
NYC A32 is offline
Old 05-05-2010, 01:30 PM
NWP Engineering.com
Aaron92SE's Avatar
It depends what kind of daily driver you consider yourself. For me, I don't mind it at all on the street. Same goes for Jime, the world's fastest.
With a fully locked front end, all tight turning in a parking lot will cause the outer wheel to hop. But once you are moving 20mph or faster, it shouldn't be too different.
But traction will be drastically improved since you will have full power going to each tire.
Maybe Jime will chime in with his two cents on street driving with a locked diff.
Old 05-05-2010, 02:04 PM
streetzlegend's Avatar
From what Jim told me on his welded Diff, he likes it, just that in parking lots its a head ache, but once over 10mph you dont even notice its locked.
I was seriously considering locking mine but I drive my car daily too much, and in miami, parking, school parking lots, etc... way to many tight turns on my daily routines. Maybe in the future when my car is track only i'll do it.
streetzlegend is offline
Old 05-05-2010, 03:31 PM
NWP Engineering.com
Aaron92SE's Avatar
I wouldn't mind the chirping at all in the parking lots. I'm sure your turning radius would get worse though. That's the least of my worries. I just need traction!
I'm still planning on putting full interior back in my car in the future. I'll only be about 70lbs heavier. (1 tenth in the 1/4 mile)
Old 05-05-2010, 04:05 PM
schmellyfart's Avatar
Im interested, I have a 97 5MT.
Will this require different axles? I know you have to get a different axle when swapping from open diff to VLSD..
schmellyfart is offline
Old 05-05-2010, 04:25 PM
NWP Engineering.com
Aaron92SE's Avatar
Are you sure you have to change axles if all you do is change out the differential inside your transmission? Or are you referring to swapping transmissions? If so, do you know why you have to change axles? Is it a different spline count? Different axle length?
Old 05-05-2010, 04:29 PM
NYC A32's Avatar
..waiting on jimes response... not sure if it be fun to have in nyc with traffic and all.
NYC A32 is offline
Old 05-05-2010, 04:42 PM
NWP Engineering.com
Aaron92SE's Avatar
I just did a quick search and found a sticky pertaining to vlsd transmission swaps. People usually just have to swap the driver's side axle and everything works.
Also, schmellyfart, it shouldn't require different axles. It actually depends if the splines in the open diff are different than the VLSD. I haven't gotten the two diffs side by side yet. But according to Neal, the splines on the driver's side of the differential are different somehow between open and VLSD.
I can produce a spool meant to replace a VLSD or an Open diff, whichever seems to be most popular. If nobody chimes in, I guess I'll just make one to replace my VLSD. The driver's side splines seem to be different and the bolt pattern for the final drive gear is different.
Old 05-05-2010, 05:01 PM
QNO_A32's Avatar
6mt's
QNO_A32 is offline
Old 05-05-2010, 07:25 PM
nismomaxct's Avatar
Originally Posted by QNO_A32
6mt's
I am definitely down for this if it is for the 6MT
nismomaxct is offline
Old 05-06-2010, 06:44 AM
Blown
cardana24's Avatar
Since I am not familiar with all of the parts inside of the transmission this will probably be a stupid question. Will this work on an open diff tranny or do you need to have a VLSD for this to be an option?
cardana24 is offline
Old 05-06-2010, 07:40 AM
SonicDust187's Avatar
It will work on them both as the tranny will be turned into a locker.
SonicDust187 is offline
Old 05-06-2010, 08:35 AM
NWP Engineering.com
Aaron92SE's Avatar
Well, this spool will be copied from one or the other. As I mentioned, I guess I will just go with whatever is most popular. If nobody shows interest, then I will just make the spool for the VLSD unit. The open diff has a different bolt pattern than the VLSD for the final drive gear.
And the bearing on the driver's side MAY be different. Does anybody have a picture of an open differential? I need to see the driver's side bearing. That's the side where the large final drive gear is on. If that is the case, then you can't interchange differentials like I originally thought. Neal mentioned something about that in a thread I found. But he was only referring to a MT I think.
If anybody has an open diff from an automatic RE4F04A laying around, can you please snap some pictures for me? If you have no way to host them, you can send them to me via email to [aaron@nwpengineering.com]. Thanks.
Edit: I found several great pictures on my hard drive from a member who did a complete rebuild of an RE4F04A. They answered my questions.
Old 05-06-2010, 10:12 AM
SLOW
Nealoc187's Avatar
you can't interchange the diffs dude... the bearing on the VLSD is about 4x the size of the open diff bearing.
were you to do this you'd need different spools for manual open diff and vlsd transmissions. not sure on whether or not auto or manual would also be an issue.
Nealoc187 is offline
Old 05-06-2010, 10:28 AM
NWP Engineering.com
Aaron92SE's Avatar
Thanks for chiming in. I knew you've done plenty of experimenting with the MT diffs.
I wonder if the bearings can be swapped over to the same size spool. I've never taken apart a differential YET. I hope to get my hands on an open diff from an AT. If anybody has one, please let me know.
Old 05-24-2010, 03:13 AM
Maxima fanatic!!!
jEsuSmAx's Avatar
any updates ?
jEsuSmAx is offline
Old 05-24-2010, 10:33 AM
NWP Engineering.com
Aaron92SE's Avatar
Originally Posted by jEsuSmAx
any updates ?
Nope, no updates yet. I was just seeing how many people may be interested in order to reduce production costs over making 1 custom unit for myself.
I still need to get my hands on an open differential to see if it's possible to swap bearings over. If I am unable to easily convert to an open diff, then that means a full spool will be produced that will ONLY replace a VLSD differential.
I am hoping to have a full spool made that will work on the VLSD and Open Transmissions. Hopefully, all you'll have to change is your driver's side axle.
Old 05-24-2010, 07:33 PM
Aaron I got a spare Open Diff, problem is, it will cost a crap load to ship that thing. But if your ever in FL again, you can borrow it.
Old 05-24-2010, 07:44 PM
perkman87's Avatar
Off topic,
Ill be in miramar tomm.
perkman87 is offline
Old 05-25-2010, 09:27 AM
jkpgt96's Avatar
Spools are interesting in parking lots for sure..the looks from people who hear the tires screaming from just turning are funny..definitely a good idea for cars that see the track a lot and for those who don't mind the extra work to drive with one at low speeds..
jkpgt96 is offline
NWP Engineering.com
Aaron92SE's Avatar
Thanks streetz. I'll be in Palm Beach Gardens next week. Maybe Jon can pick it up from you tomorrow and bring it back to PBG.
But, I don't mind driving down to your neck of the woods. I have your number. I'll let you know. Thanks.
Old 05-25-2010, 09:31 AM
NWP Engineering.com
Aaron92SE's Avatar
Yeah, and I am both. Heavy track goer and I don't care how my car drives on the street. My 4000-4500 rpm stall torque converter should be here in a few days! That should tell you how much I care about streetability.
Old 05-25-2010, 01:52 PM
perkman87's Avatar
well that's what the truck is for......
This mod will catch on especially if you can do it for the sentra guys..
Old 05-25-2010, 02:47 PM
Call me or text me, I posted something on your build thread , just an idea lol
Old 05-25-2010, 06:53 PM
NWP Engineering.com
Aaron92SE's Avatar
You saw my Maxima at the last NWP Meet in FL. It's my daily driver. My beater Stanza is gone and now that I have a nice truck, I've been using that as my daily driver lately. My Maxima has been kept in track mode (rear skinnies, no passenger seat, etc).
Old 06-15-2010, 05:01 AM
doublea's Avatar
If that would work for my 2k1 auto, I'd be interested. Will I have to remove the tranny ? or can this be installed from underneath the car ? Sound like a newbie question but removing the tranny is not on my list unless I break something...
doublea is offline
Old 06-15-2010, 08:37 AM
NWP Engineering.com
Aaron92SE's Avatar
You have to remove the transmission entirely and then remove the torque converter housing. That's it.
I am thinking about my transmission in the next week just to install a different high stall converter. Then, do it again if I get this full spool made. You gotta do what you gotta do in order to make race dates.
Old 06-15-2010, 04:00 PM
Rood's Avatar
Id be interested in one for my 00 5 spd.
Rood is offline
Old 06-17-2010, 01:29 PM
Hella internets
XeroX's Avatar
This sounds interesting, def a cool and hopefully cheaper alternative
Subscribing
XeroX is offline
Old 06-17-2010, 02:34 PM
doublea's Avatar
That's what I though but what do I know about that ? I might end up buying one but it's going to stay on the shelf for a little while since removing the tranny is not on my list for now.
Thanks for the answer.
AA
doublea is offline
Old 11-09-2020, 09:03 PM
Dezmon Lion's Avatar
full spool dif
hi I am interested in a full spool setup for my 99 Maxima with a 97 5MT swap. please let me know what's up. Thanks!
Dezmon Lion is offline
LilVito
10-25-2019 08:12 AM
niZ
08-07-2015 10:18 PM
altmycar
08-06-2015 04:44 PM
xUNIxPanther
08-05-2015 09:31 AM
kjm900r
08-05-2015 07:14 AM
Quick Reply: Full Spool for Maxima (aka Fully Locked Differential) - Interested?
