Go Back   Maxima Forums > Track and Tune > 1/4 and 1/8 Mile Racing
1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-02-2009, 09:03 AM   #1
The LandShark has teeth..
grey99max's Avatar
Fixed my nitrous - went to the track
My car has been pretty weak the last two times I visited a track. The problem was the fuel solenoid on the first stage (75-shot). Highway tests showed a A/F of 15.6 when spraying the first stage! - and the plugs looked badly burned... I changed out the bad solenoid, blew out the lines and nozzle, then a highway test showed the A/F to be 12.4 - much better. DA was good - 1000', DA was 1446. Air temp 59*, Hum 42%, Baro 29.82.
So, off to Heartland Park last night for a T-n-T. I made three passes - discovered I still have a shifter problem that requires me to lift for the shift, then get back into spray, but the car now pulls hard again. I haven't scanned the slips yet, but here are the important numbers.
........75-shot-only.........75-shot+some..100-shot.....75-shot+some..100-shot
60'....1.765...................1.777.............. .................1.780
1/8....8.275...................8.218................ ...............8.218
MPH...84.16...................83.72............... ................86.06
1/4....12.854.................12.671................ .............12.593
MPH...108.95.................112.14............... ..............114.54
In the third pass, I was 1/2 car behind a 12.65-ET Camaro until I got into third gear, then I picked up at least 3 car lengths on him for the win. My 3.5 does make some serious HP. and those 60' times are my PB..
The shifter still has problems, and I'm still bouncing off the rev limiter and nitrous window switch on the 1-2 shift, but with that fixed, times could get better. I'm going to hate to throw this engine away.... Oh yeah, I switched to Lucas Semi Synth Racing Oil for the transmission - it does help.
http://www.lucasoil.com/products/dis...tid=9&loc=show
Overall, a good evening...
EDIT 10-04-2009 Here are the scanned time slips:
__________________
'99 GXE, Tune-by-Tape MAF mod, 3.5L w/cams, SSIM, 255Walbro,AERO FPR, VLSDauto, Edge TC, DR-mod, Shift_Fast, dual-B&M cooler, JClawbars, cryoed axles, dual-NX nitrous, dual heated15lb bottles, OBX headers, 3"Warpspeed exhaust, PLXR-300 wideband, IlluminasStrut/springs, 24.5"M&H, ProgressRSB, HawkHPS, Clarion50Wx4 head w/Alpines, Fosgate sub. Spare tire+jack,3300 lb car. 355WHP-dyno.
12.394 @113.22 ( 114.51 now) w/3.5
http://i48.photobucket.com/albums/f2...9/DSCN0527.jpg
grey99max is offline   Reply With Quote
Old 10-02-2009, 09:33 AM   #2
nycnissans
secondtonone317's Avatar
Send a message via AIM to secondtonone317
very nice, what rim/tire combo are you using?
spraying the 75 out of the hole I assume?
__________________
Co-Owner and Founder of NYCNissans.com
secondtonone317 is offline   Reply With Quote
Old 10-02-2009, 10:09 AM   #3
grey99max's Avatar
Yup, sprayed the 75-shot right at launch. Stalled up to 2800 and hit it at the last yellow.
Tires and wheels were M&H 24.5x8.5x15 slicks on AR 8" rims... obviously they can hook up well. Since I was going into 4th just before the traps, I think I'll go to a larger slick - like 10x26x15 or 12x26x15 M&H. The taller tire should prevent going into 4th gear at the traps.
http://www.mandhtires.com/store.php?...mode=cat_click
__________________
Old 10-02-2009, 10:27 AM   #4
Very Nice ET,and Trap speed. Congratulation.
__________________
Vortech V2 T-trim, 2.87" pulley, intercooled, Defi Gauges, RC 550cc, Walbro 255lph, Aeromotive AFPR, Cattman Headers and 3"catback, Emanage blue, B&M Short Shifter,Third PAR Synchromesh Racing Gear, Vortech Maxflow Race Bypass valve, Stillen Sport Drilled Rotors, w/ Hawk HPS Brake Pads,Eibach Pro-Kit on Tokico Illumina,Cattman FSTB,& RSB, Competition pressure plate on-ACT 6 Puck sprung disk.
scmax2000 is offline   Reply With Quote
Old 10-02-2009, 11:29 AM   #5
RIP Kevin007
ajcool2's Avatar
Send a message via AIM to ajcool2 Send a message via MSN to ajcool2 Send a message via Yahoo to ajcool2
Nice! Congrats.
__________________
DCMAX FTW
The Green Lantern 14.98@90mph 60' 2.14 AUTO (Before the 00VI) 170 HP 3140lb w/driver
The 3.5 Swap 15.508@90mph 60' 2.3 AUTO (Bad KS and stock catback) 210whp, 213wtq
The Dark Phoenix 13.402@102mph 60' 1.9 AUTO 257 RWHP 3280lb w/driver
Fear me.
My VQ35 Swap Progress Thread Now Complete!
ajcool2 is offline   Reply With Quote
Old 10-02-2009, 12:42 PM   #6
SLOW
Nealoc187's Avatar
Send a message via AIM to Nealoc187
So was this just a 75 shot or was 75 just the first stage and you had a larger shot in the 2nd stage? Nice 60's.
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto DR
3.5L swap with I/Y/E
12.92 @ 104 - 1.69 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - I/Y/E/MEVI/JWT ECU
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Stock winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
Nealoc187 is offline   Reply With Quote
Old 10-02-2009, 01:23 PM   #7
Very nice Harold.. Glad you figured things out, I knew something wasn't right when I saw you at the track up in Tulsa.. Congrats!!
__________________
(Turbo Build in progress)
Juiced SE-R is offline   Reply With Quote
Old 10-02-2009, 01:27 PM   #8
grey99max's Avatar
Quote:
The first stage is set to be a 75-shot, and it triggers at WOT. The second stage is jetted for a 100-shot and it triggers from a floor switch.
The custom transmission shifter triggers off a MSD 8969 switch set at 6400. There is also a manual "shift up" button. The nitrous window switch is another MSD set to 2700-6500 for spray. I've had to shift early at the 1-2 shift because - I think - that the MSD switches can't respond fast enough to rapid changes in RPM. The car hits fuel cut very fast in 1st, and the engine "stutters" between spray and fuel cut, so I've been manually shifting early. This new quirk cost me a transmission in May.
The 60' times blew me away. It was a good night to launch. (and I really enjoyed walking away from the Camaro)...
__________________
Old 10-02-2009, 01:32 PM   #9
grey99max's Avatar
Quote:
Hi, Juiced - yeah, I knew something was wrong there, but I didn't have any spare parts with me, so I limped through the event. No excuses - so when I got a chance and pulled the plugs, it was obvious that the engine went very lean. I finally got a chance to dig into it and wound up changing out the 1st stage fuel solenoid. That made it better.
Maybe I'll drag the car to the Wichita Import event later this month.
__________________
Old 10-02-2009, 06:06 PM   #10
321VQ35MAX's Avatar
Very nice times. Congrats....
__________________
321VQ35MAX - 03 Black 6spd T.E - Injen CAI-Tein S Tech Springs - Tokico Illuminas - Clear Markers- ES Shifter bushings - ES subframe bushings - ES mount inserts
Best 1/4 -14.501 @ 95.99 mph 2.20 60 ft....
321VQ35MAX is offline   Reply With Quote
Old 10-02-2009, 06:47 PM   #11
Gut it like a fish
accordingtou's Avatar
Nice 60 ft's
__________________
Stock & performance parts F/S@ PANTRY sale.lol Philly Pa
accordingtou is offline   Reply With Quote
Old 10-02-2009, 06:59 PM   #12
Shift_Broken Tranny
+1 on the 60fts
btw why would you have to toss the motor, sell it or better yeah go all out and spray a 250shot before you retire the motor
__________________
My Cardomain _ _Maxima runs 13.4@109
Dyno:? whp & ? wtq
Nitrous PB: 13.4@110mph
All Motor PB: 14.0@99mph
3280lb with driver, full trim, rims, spare, jack, fluids, etc & notorized proof
t6378tp is online now   Reply With Quote
Old 10-02-2009, 07:22 PM   #13
grey99max's Avatar
Quote:
Originally Posted by t6378tp View Post
+1 on the 60fts
Yeah - 250-shot -........ yeah.....
It's kinda hard to believe that the '02 stock-with-eBay-cams engine is still smoking the slicks - or even still running, considering what it's been through over the last two years.
How about upping the second stage up to 150-shot? That would be a combined 225-shot. That uses a 62+33 jet combination (I'll double-check that), and I have those. Daymn, I think I'll do that before the season is gone.
Hummmm... The Dyno-tune jet calculator says 58+34 and for 175 = 62+36. I'll dig some more. I should get this right - or identify all my available jets and see what I can put together.
EDIT = looks like the calculators say a 62+36 combination is a 150-shot to the wheels. Think I'll go with this one.
__________________
Old 10-02-2009, 11:12 PM   #14
Send a message via AIM to streetzlegend Send a message via Yahoo to streetzlegend
Very good looking times Harold, I also thought to myself the previous times were a little weak and something had to be wrong, glad u fixed it.
__________________
Streetz goes into the 11's!!!
440CC RC injectors for sale, $220 Shipped. PM ME
streetzlegend is offline   Reply With Quote
Old 10-04-2009, 09:41 PM   #15
grey99max's Avatar
Here's the time slips I mentioned earlier. The first pass was just with the 75-shot - and I lifted while the tranny was shifting. I played with the second stage on the second and third pass - more so on the third pass.
__________________
Old 10-05-2009, 10:31 AM   #16
3.5 in the works
DandyMax's Avatar
Send a message via AIM to DandyMax Send a message via MSN to DandyMax
Good numbers Harold, and very good 60 fts!
__________________
2000. 3L. 5-spd. Black on black. SE. (DD)
1998. 3L. 5-spd. Sterling Mist. SE. (fun car)
1/4 mile stats (all N/A VQ30):
Best 60': 1.73
Best ET & trap: 12.61, 108.98 mph
Click to see the video. More videos also here.
Mods list and dyno here (as of May 9/08).
My EU writeup can be found at VQ Power.
DandyMax is offline   Reply With Quote
Old 10-05-2009, 01:14 PM   #17
Awesome 60 foots. I wish I could match those!
tuko316 is offline   Reply With Quote
Old 10-05-2009, 02:34 PM   #18
grey99max's Avatar
Quote:
I wish I could do this again! I guess all the planets were in alignment that evening - it was 59* for the second pass.
__________________
Old 10-05-2009, 05:10 PM   #19
If you go with some bigger slicks, I would go with some 26x8.5-15 ET Drags. Should be a good tire for you. No need for the 10 inch wide.
__________________
04 6 speed || Intake and 3" exhaust
SHIFT_faster than you can
8.7@80mph
krazy6 is offline   Reply With Quote
Old 10-05-2009, 09:07 PM   #20
grey99max's Avatar
Quote:
Think about the Cosworth-component new engine. I'll need the larger slicks.
__________________
Old 10-06-2009, 12:18 PM   #21
SLOW
Nealoc187's Avatar
wait is this with your built engine or a stock motor?
__________________
Old 10-06-2009, 01:33 PM   #22
Quote:
Didn't think about that lol.
__________________
8.7@80mph
Old 10-06-2009, 01:37 PM   #23
grey99max's Avatar
This is with the old almost-stock 2002 engine (Ebay cams, headers, SSIM). It has taken a lot of abuse and apparently still makes some WHP.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
