1/4 and 1/8 Mile RacingTalk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Hey just a question for the experienced racers w/ automatics:
If you are manually shifting what is the best RPM to hit the shifter?
I was practicing on a country road in prep for going to the track and it seems there is a delay between moving the shifter to 2nd and when it actually shifts...
needless to say i shifted pretty high RPM because I didnt realize they delay and thought it would shift immediately. any suggestions would be appreciated!
To hit the same rpm for the 1-2 and 2-3 you will have to shift sooner for the 2-3 because the shift takes longer than the 1-2. If you are insistent on doing this a shift light would be recommended.
Personally I tried manual shifting when i first started racing but found that I could never duplicate the same shift point. So I never shift manually. If you do want it to shift at a higher rpm than the stock shifts you might want to consider the Suprastick.
im a 5.5 and i shift 1st at 6200-6300 and 2nd at 6500
__________________
SHIFT_LOTS OF OIL
DCMAX current mods- 4th gen intake, 2.5" custom catback, NWP block off plate, 00SE tailight w/overlays, Rewired fog lights, Eyelid, JIC coilovers, FSTB, 3.0 OBX headers, SSIM...
95 White GXE- 15.1 sold... now 14.9 (car next to me in sig)
00 Sterling GXE- 15.0 (ebay intake, exhaust) my next love and beauty (crashed n sold)
02 Sterling GLE- 13.84@100 2.1'
Is that a shift kit? Is it expensive/hard to install? Im gonna do some research right now. Is there any way to modify the ecu to adjust the shift point besides the TC ecu mod??
__________________
SHIFT_LOTS OF OIL
Im practicing these shifts on a country road as soon as I get off work... hopefully I can get this to work before the track opens.... But if it shifts faster for 1-2 than 2-3 should I try reversing these numbers - 1st at 6500 and 2nd at 6200-6300? what do you think?
No... 1st gear is torqier and the Rpm climbs faster, when u shift at 6500 you will be miss shifting due to it taking that very slight delay, 2nd and 3rd isnt so bad, it wont climb as quick and the delay wont really matter
__________________
SHIFT_LOTS OF OIL
So I just got back from the track.... a little disappointing. I lost both races first an rx7 and then a suped up RAM 1500 (pretty sure he had forced induction). I ran 16.18 and 16.24...
The manual shifting didnt work out for me. I need to practice more before I go again. My 1-2 was right on but when I did the 2-3 it just didnt want to shift up... I was climbing too high in rpms for my comfort zone and just kept climbing... I had to let off the gas before the end of the run because I dont want to risk any damage to the car...
I will continue practicing as the manual shift run was the better of the two even though I let off early... I think I will benefit if I figure out how to make it shift were I want.
Does it sound weird that it didnt shift up? should I just let off the gas a tad to make it shift or something?
you won't do damage. Your car has a rev limiter. Sometimes, depending on throttle position, the ECU decides when its best to shift. Did you do the Drop resistor mod?
__________________ Paying a man to work on your car is like paying another man to sleep with your wife.
-Hank Hill
99 SE-L - 00vi - Y/E
^^^ for you it will be an emanage or Utec, for us 5.5 its Technosquare... nzelinksy doesnt matter how far up in the RPM you go, if its too far up you will just hit your rev limiter (basically miss shifting), no damage will be done, if 6500 didnt do it for ya, try 6400 IIRC 5.5's have a 300rpm error, so even shifting at certain RPMs it would go the extra 300rpm (IDK if its all 5.5's) but keep on the gas bro... seems like you could've broke 15's on the runs... whats the 60'?
__________________
SHIFT_LOTS OF OIL
have you grounded the knock sensor? that made a huge difference for me.. haven't been to the track after i grounded it but hoping to go within the next couple of weeks, just waiting for better weather
__________________
2002 Maxima SE Auto - Totalled 9/27/09
2002 Maxima GLE Auto - Picked up 10/16/09
__________________
SHIFT_LOTS OF OIL
Y do you think it didnt shift though? 60' was 2.5 on the first run... What happens if you hit rev limiter in gear?
Quote:
no I havent done anything except my intake.... Does the stilling grounding kit do the knock sensor? or can I just buy some regular wire and do it myself? what would you reccomend?
could I be running 16's with a bad MAF? I mean the car doesnt feel slow but compared to other 5.5's I guess it is... Should I try the CNC cleaner or replace it?
Do you guys know anything about using a bigger MAF?
nothing it just means get out of the gear the car will just stay at the same speed... 2.5 60' is waaaaay below average, what type of tires are u using and what condition?
__________________
SHIFT_LOTS OF OIL
tires are a big problem for me right now... I have Nokian winter tires. They are pretty much brand new I have about 70% left on front and 90% on the rear. I think I might try using the traction control it might help my launch, Im just worried that it will cut too much power and make me slower.
We have snow on the ground for usually 7-8 months a year and it gets pretty bad. Im waiting till next spring to buy rims and better tires since the seasons almost over now Im not spending the money...
your times are so high because your 60 ft. is so high.. you need to be down to to 2.2 at MOST to see a decent time.. how fast you get off the line is key to your quarter mile time
__________________
2003 6 speed TE
Looks: Superwhite LEDs Inside Smoked Side Markers
Performance: Stillen Intake with Custom MAF-TB Pipe, NWP Phenolic Intake Spacers, NWP Block Off Plate, Cattman Gen 3 Headers, Custom 3" Magnaflow Cat-back Exhaust
Suspension: Tokico Illumina Struts, Ebay FSTB, Progress RSB
with the winter tires i dont think its too much u can do to help... 2.5 is below avg, some better tires would help... what about getting all season tires???
__________________
SHIFT_LOTS OF OIL
haha no all seasons are no good here. If you dont have winter tires you will crash your car... the roads get extremely icey and deep snow. its just gonna have to wait for next year.... I cant afford headers/exhaust AND tires so Im goin with h/e Its my best choice for right now.
do you think traction control will help my launch? I've been turning it off all the time
honestly, that one u got me beat... never owned a car with traction control ever... try it... go and get as much runs in... keep the engine cool... might wanna look into some spacers, my auto stays hot
__________________
SHIFT_LOTS OF OIL
yes... more tq and it keeps the engine 40* cooler, a definate plus...
__________________
SHIFT_LOTS OF OIL
hmmm sounds decent. I can't afford that right now either though...
I was thinking of replacing my thermostat with one that has a cooler temp so the fan comes on sooner. That or hooking up a switch to turn it on manually... what you think?
ur car bro... it can be done, idk how that affects anything in that i personally never tried it nor seen it
__________________
SHIFT_LOTS OF OIL
Hook up the switch. Thats what I have. It helps alot with cooling the car off.
You dont have to buy a thermostat you can mod the one you have by adding a spacer to it. Check JIME's website for the how-to.
Same here. 6500 rpm on the 2-3 seems to make a noticably difference in how the car pulls in 3rd, since our 3rd gear is so long. If I let the car shift for itself, sometimes it short shifts into 2nd at 5800 rpms.
__________________
2002 Maxima SE, NWP block plate, GAB, K&N panel filter, Vibrant FSTB, grounding kit.
What was your trap speed? If it was in the upper 80s you are definitely not making the power you should be. If it was around 93-94, then your problem is your launch.
Bad MAF means no power above 2500 rpm, you probably couldn't crack the 18s with a bad MAF.
My best trap was 87mph... I have power, its just not enough any suggestions?
More mods...... I need them as well...... May do my 3" exhaust in about 2 or 3 weeks, want to trap closer to 98 mph....
__________________ 321VQ35MAX - 03 Black 6spd T.E - Injen CAI-Tein S Tech Springs - Tokico Illuminas - Clear Markers- ES Shifter bushings - ES subframe bushings - ES mount inserts
Well then you should shave quite a bit of time off....... Low 14's????
if u dont run it, i sure will lol, just got my obx headers
__________________
SHIFT_LOTS OF OIL
shoo you should be lookin forwad to 100mph or 101... im gonna be looking for 98mph with my auto
__________________
SHIFT_LOTS OF OIL
87 mph? Something is definitely wrong. Bad spark plugs can hurt performance but probably not that much. Could be clogged cats, problem with the throttle body not opening fully, bad knock sensor pulling timing back too far.
