Go Back   Maxima Forums > Track and Tune > 1/4 and 1/8 Mile Racing
1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 08-06-2009, 07:20 AM   #1
advice please
I am attempting to break into the 13's on street tires. 2 weeks ago I had the zex 75 hp jets installed and only ran a 14.2 Last night I had the 100 shot jets in, and I could only get a 15.0. I can't activate the nitrous until the top of 1st gear otherwise I spin using the 75 and 100 shots. I definitely felt the 100 shot kick in, so I know its working, but I think traction is a serious issue. I was thinking of actually dropping the shot down to a 65 shot so hopefully the car can keep traction, and then save the higher shots for when i finally get slicks. I'm beginning to realize how pointless it is to have higher shots on street tires. What is your guys' advice? Should I drop the shot down so hopefully the street tires can hold it, or stay with a bigger shot?
__________________
J Schultz
2003 Titanium SE Auto
Exterior mod: Tint
Performance mods: GAB w/ KN panel filter, NWP vias delete, Timing 17*BTDC, Custom test pipe/ exhaust cut-out, drop resistor mod.
Best 1/4 Mile Time: 14.6
jr schultz is offline   Reply With Quote
Old 08-06-2009, 07:23 AM   #2
As a side note. Just thought I'd mention the brand new GTR that was there last night. It was running 11.7 -11.9 all night. Taking out muscle cars left and right. It was awesome! Ok, back on topic.
__________________
J Schultz
Exterior mod: Tint
Old 08-06-2009, 08:35 AM   #3
There is a forum for nitrous you can find a lot of detailed info on there. From what I have read and heard from other people is that its pretty much pointless to get nitrous if you dont have slicks. Im gonna do a 75 shot but Im waiting till I can afford a set of slicks to go with it.
nzelinsky is offline   Reply With Quote
Old 08-06-2009, 08:35 AM   #4
Quote:
yeah GTR's are fukcin awesome!
Old 08-06-2009, 08:40 AM   #5
What rpm are you starting to spray at?
What are your 60ft times?
What kind of street tires are you using?
What is your tire pressure at?
The initial torque is causing you to loose traction. I would say try the 65 shot to see what happens. Your just gonna continue to spin on the 75/100 shots. I'm not saying it's impossible but it's gonna be tough! I was trying to get into the 12's on street tires and was having a VERY diffucult time so I finally gave up lol. I still have traction issues on a 100shot using Nitto DR's.. Nitrous is fun but you def have to figure your car out in order to get it's full potential out of your setup.. But again since you've had no luck with the higher shots give the 65shot a try and see what happens.. If that fails then go buy some DR's or slicks which ever ones you prefer.. Good luck!
__________________
(Turbo Build in progress)
Juiced SE-R is offline   Reply With Quote
Old 08-06-2009, 08:50 AM   #6
Spraying at top of first gear. About 4K rpms...Maybe wait until 2nd gear?
60 ft times are 2.3 to 2.5...Crappy!
Dunlop sp 5000's one size larger sidewall than stock.
Tire pressure at 25psi.
If you have traction issues on drag radials I have no business running my 100 shot on street tires. I'm going back tomarrow. I'll start with the 65 shot jets.
Any other advice?
__________________
J Schultz
Exterior mod: Tint
Old 08-06-2009, 08:54 AM   #7
SLOW
Nealoc187's Avatar
Send a message via AIM to Nealoc187
That's the problem with nitrous being WOT only on street tires. Once you hit WOT your nitrous kicks in and you go from 250hp to 350hp or whatever, but your tires can only hold 300hp, so you can't find that happy medium to be on the very edge of traction.
I don't know what kind of 60's you're cutting but if you are dead set on sticking with street tires the best thing is probably to get a progressive controller to run the maximum amount you can without ruining your traction in first gear and then turn up the juice once you're in second gear. Or at least run a dual stage. I don't run nitrous so I don't know the specifics of what parts you'd need, but you obviously have too much power for your tires in 1st gear and there's not much you can do about it besides either have less power in first gear or better tires which you said you don't want.
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto DR
3.5L swap with I/Y/E
12.92 @ 104 - 1.69 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - I/Y/E/MEVI/JWT ECU
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Stock winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
Nealoc187 is offline   Reply With Quote
Old 08-06-2009, 09:11 AM   #8
I definitely want slicks, but my cash flow is low right now. That's why I'm trying to do the best I can on street tires. I'm going back with a smaller shot on friday. I'll save the bigger shots for when I can afford slicks.
__________________
J Schultz
Exterior mod: Tint
Old 08-06-2009, 09:12 AM   #9
The LandShark has teeth..
grey99max's Avatar
What he said.... Even with M&H 24.5 x 8 slicks, I can only hold a 75-shot on launch - then I can usually get into the second-stage 100-shot later into first gear. If the track has a lousy prep, then even the 75-shot is too much.
Try a 35-shot next with street tires - you still can't launch with it, but you'll get better traction and a better experience.
If you want to use the higher nitrous levels, then you will need slicks.
__________________
'99 GXE, Tune-by-Tape MAF mod, 3.5L w/cams, SSIM, 255Walbro,AERO FPR, VLSDauto, Edge TC, DR-mod, Shift_Fast, dual-B&M cooler, JClawbars, cryoed axles, dual-NX nitrous, dual heated15lb bottles, OBX headers, 3"Warpspeed exhaust, PLXR-300 wideband, IlluminasStrut/springs, 24.5"M&H, ProgressRSB, HawkHPS, Clarion50Wx4 head w/Alpines, Fosgate sub. Spare tire+jack,3300 lb car. 355WHP-dyno.
12.394 @113.22 ( 114.51 now) w/3.5
http://i48.photobucket.com/albums/f2...9/DSCN0527.jpg
grey99max is offline   Reply With Quote
Old 08-06-2009, 11:36 AM   #10
Get some used slicks off of craigslist or something.
__________________
04 6 speed || Intake and 3" exhaust
SHIFT_faster than you can
8.7@80mph
krazy6 is offline   Reply With Quote
Old 08-06-2009, 11:44 AM   #11
If you really wanna know then you have two guys in this thread that really know what they are doing and that would be Neal and Greymax, they both have been in the game for a while, know what they are doing and provide some great tips which they have done for you...
__________________
Old 08-06-2009, 06:48 PM   #12
add some headers in the mix.... i though it should be a 13 sec car already though... im gonna shoot for 13's after my header install
__________________
SHIFT_LOTS OF OIL
DCMAX current mods- 4th gen intake, 2.5" custom catback, NWP block off plate, 00SE tailight w/overlays, Rewired fog lights, Eyelid, JIC coilovers, FSTB, 3.0 OBX headers, SSIM...
95 White GXE- 15.1 sold... now 14.9 (car next to me in sig)
00 Sterling GXE- 15.0 (ebay intake, exhaust) my next love and beauty (crashed n sold)
02 Sterling GLE- 13.84@100 2.1'
Grand_hustle17 is online now   Reply With Quote
Old 08-06-2009, 09:56 PM   #13
Quote:
I have a goal of trying to get as fast as I can w/o expensive exhaust work for now. I know headers would benefit me a lot, but I want to try to get to the 13's with street tires and no headers. Then my next goal will be high 12's with slicks and a bigger shot. I want to say I can run fast times with my only exhaust mod being a test pipe/cutout. We'll see...
__________________
J Schultz
Exterior mod: Tint
Old 08-07-2009, 06:18 AM   #14
Good luck..
__________________
Old 08-19-2009, 05:54 PM   #15
yea goodluck
__________________
SHIFT_LOTS OF OIL
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
