1/4 and 1/8 Mile RacingTalk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Removed USIM from 3.5 and put 3.5IM on, disappointed with track results.
I got my 3.5IM installed on my 3.5 swap finally, I had been running with USIM (3.0 Intake Manifold) before.
I made most of my runs with a VIAS block off plate installed.
EDITED with more analysis:
Before I edited this thread I said I was not too disappointed with the results but then I found the timeslips that I'd forgotten about from June of this year and I'm disappointed again.
I've never before corrected my numbers to sea level but I decided to see what the trap speeds correct to using DA correction.
In June I ran with the USIM installed and trapped as high as 101.74 with a DA of 1900' which corrects to 104.0mph. My traps on 8-2-09 were 102.x for the most part with some high 101s with a DA of 2200-2300 translates to 104.5-105.2mph I'm not sure what to think here. I would think that the addition of the USIM to the 3.5, with the ports being perfectly matched now and all, would be more significant.
Granted the car was about 70lbs heavier so that might be worth half a MPH or something, but I was hoping to see more. Also though I was on slicks this time as opposed to street tires, it's a different track, etc, so it's not the best comparison I guess. I'm heading to the same track as I went to with the USIM next week perhaps, so maybe I'll get some more data then.
Here is my setup:
95 SE 5spd
2002 3.5L with stock 3.0 cams, 3.0 ECU, stock timing, 3.5IM with VIAS block off plate, rough tuned to 12.2AFR because my laptop died and I can't tune my emanage right now
Homemade generic intake, y-pipe, 3" exhaust
26x10.5x15" MT ET Streets on 15" Welds ProStars
3050lb race weight
I can't wait to *possibly* get those headers modified and installed, and definitely get my Bikisoft ECU installed and really tune it. I think it'll move pretty well then but for now I'm a little disappointed.
RT 1.705 <---lol I wasn't ready I was turning my camera on
60' 1.924
330 5.500
1/8 8.530
mph 80.63
1000 11.15
1/4 13.365
mph 102.24
For these last two runs I removed the VIAS block off plate and had the VIAS mechanism installed but the butterfly plate removed so it was just an open round hole.
RT .049
60' 1.863
330 5.452
1/8 8.491
mph 80.17
1000 11.117
1/4 13.342
mph 101.69
This run I short shifted the 2-3 shift at like 6300rpm just out of curiosity, it did not help
RT .071
60' 1.921
330 5.560
1/8 8.623
mph 79.56
1000 11.268
1/4 13.510
mph 100.98
__________________ 95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto DR 3.5L swap with I/Y/E
12.92 @ 104 - 1.69 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
__________________
97 SE Auto Built Auto
97 SE Holset HX52|N2O|6 SP|Built 3.56|More to come
91 GXE Auto bone stock beater
91 GXE 5sp Another beater
Led retro's Pm me
Could be but the difference in the cams is fairly negligable if my memory is correct, something like 8mm of duration and another .9mm lift or something along those lines. It's hard to judge with only one set of datapoints from a different track on a totally different tire size and style (bias at 10psi vs radial at 32psi). I was thinking of going to the track again this weekend but it's supposed to be 100 degrees this weekend so maybe not.
Tire size could be affecting you also. 26" slicks are probably not ideal for your car sans turbo. It seems like there are too many other variables also.
You are definitely not optimized right now anyway, between the weather, AFR, stock timing, 3.0 cams, etc. you might not be able to realize the extra airflow of the 3.5 IM compared to the 3.0 IM.
__________________
96 Pebble Beige SE
14.2@97mph as an auto
13.7@102mph as a 5spd
12.9@106mph after 3.5 swap
11.6@120mph with the S/C
Cams info, the three I've tried. I liked the stock 3.5 cams the best for driveability.
Stock 3.0 cams 8.55 mm lift
Stock 3.5 cams 9.5 mm lift
Aftermarket nismo 3.5 cams 10.7 mm lift
I can assure you that 70 pounds equals to .1 and 1 FULL mph on a maxima. Weight makes more of a difference than you think, I could feel a 40 lbs difference off the front end while driving the car.
I blew my engine BWAHAHAHAHAHAHAHAHAHAHAHAHAHA
I hate you.
__________________
1995 SE VQ35 5-speed - untuned
13.680@104.544 stock tires off idle 2.13 60 foot
2.022 Best 60 foot on stock tires
14.481@105.568 Best MPH
