Go Back   Maxima Forums > Track and Tune > 1/4 and 1/8 Mile Racing
1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-27-2009, 03:25 PM   #1
Jime's Avatar
To Lexan or not to Lexan?
So about 3 years ago i decided to put Lexan on my rear windows. Weight savings was the objective so I saved approx 12 lbs (7 on rear and 2.5 on each side). The cost was approx $165 for a sheet of tinted 1/8", not bad for 12 lbs? The rear side windows were easy but the rear didn't look good with a wide swath of black silicone, finger spread around the outside.
It looked not too bad and putting my car# and dial in seemed fairly easy to remove as long as I didn't let anyone put shoe polish on. However the last year its starting to look pretty scratched and hard to see out of the rear from all the number and dial in removal, I even used a special lexan cleaner.
So today I decided enough is enough and went to the U-Pick. Picked up a rear window, the rear side windows, coolant leg (that blew at MAXUS from my fans not working and overheating), master cylinder (that blew last weekend at a $1000 event), windshield washer tank (for my meth setup) all for $80. Not bad.
So was it worth it? For the experience yes, for the weight savings no.
If I was to do it over again I would get the abraision resistant lexan at over $300 a sheet (not tinted), not cheap but if you are going to do it thats the way to go.
If I keep going I will be back to my stock weight. Next thing you will see me with a S/C or Turbo going to the dyno. NOT.
__________________
0-60 MPH = 2.38 sec
Jime is offline   Reply With Quote
Old 07-27-2009, 03:48 PM   #2
Quote:
Well said lol.
When are you gonna run the big shot on the car again?
__________________
04 6 speed || Intake and 3" exhaust
SHIFT_faster than you can
8.7@80mph
krazy6 is offline   Reply With Quote
Old 07-27-2009, 03:54 PM   #3
Jime's Avatar
Quote:
Originally Posted by krazy6 View Post
Well said lol.
4 Oct, same event as last year. I have a new pair of slicks and I'm trying to stretch my old ones until Oct because it really helps the 60'.
This year its going to be a 75 out of the hole and a 125 as soon as I feel I can do it in 1st gear. Probably won't be a whole lot better depends on the temp though.
__________________
0-60 MPH = 2.38 sec
Old 07-27-2009, 04:17 PM   #4
321VQ35MAX's Avatar
Well good luck with everything. I get excited to read about what you have accomplished. Making us Maxima owners and imports owners in general very proud.
__________________
321VQ35MAX - 03 Black 6spd T.E - Injen CAI-Tein S Tech Springs - Tokico Illuminas - Clear Markers- ES Shifter bushings - ES subframe bushings - ES mount inserts
Best 1/4 -14.501 @ 95.99 mph 2.20 60 ft....
321VQ35MAX is offline   Reply With Quote
Old 07-27-2009, 06:09 PM   #5
Good luck at that event Jim..
__________________
(Turbo Build in progress)
Juiced SE-R is offline   Reply With Quote
Old 07-27-2009, 10:31 PM   #6
Nice, can't wait to see what you run!
__________________
8.7@80mph
Old 07-29-2009, 04:18 PM   #7
STFU n00b!
Not that you want to go back to lexan at this point, but one of the things I've seen some of the local guys do is put a small piece of 3M clearbra or other clear removable plastic on the area where they write the numbers. Then when it gets scratched, you just peel it off and replace.
The other thing you can do to make it look better is to carefully tape off around the window trim and hose it down with black spray paint. it'll help to cover up the lines from the silicone.
__________________
04 G35 Sedan 6MT- The DD
96 240SX 5 speed- The track toy
93 Maxima SE 5 speed- retired 1-5-09
Check out the toys I make on my website!
Matt93SE is offline   Reply With Quote
Old 07-30-2009, 03:19 PM   #8
Jime's Avatar
You know Matt if I had it all to do over (but the damage is done). Now they can write in shoe polish if they want, too easy to remove from glass.
Stock windows are now all back in. I also had to put back in some of the rear door bracing to hold the glass so my weight is creeping back up. I will weigh it at the next CSCS 23 Aug but I think am well over 2800 again.
I also just replaced the coolant leg that blew at MAXUS when my cooling fans quit as well as my master cylinder.
Got a big race coming up 7,8 & 9 Aug, $1600 so gotta have everything up to snuff. Its the little things that always get you, have to be prepared for everything.
__________________
0-60 MPH = 2.38 sec
Old 08-03-2009, 12:35 PM   #9
Quote:
exact, Jime's my personal maxima hero! looking forward for that hail mary run!
__________________
1997 Maxima GXE: 00VI, S-AFC2, INJEN CAI,
LSS Y-pipe, Hi-flow cat, LSS Catback,
Freeflow stainless steel muffler, Auto-to-5-speed non-LSD, 6puck stage 3 clutch
copper-ceramic, takeoff!!
R.I.P 02-15-08
New 96 SE lsd 5-speed black ready for fun.
110000miles 1500$canadian
VQ'ed is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
