1/4 and 1/8 Mile RacingTalk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Alright, got back a little while ago. I ran a 9.2 in the 1/8.
This converted to a 1/4 run is a 14.3.
This was with a 2.2 60ft as well, so it has more in it.
__________________
04 6 speed || Intake and 3" exhaust
SHIFT_faster than you can
8.7@80mph
3rd run:
60' 2.344
330 6.293
1/8 9.578
MPH 75.30
Same launch as before but the car decided to spin a lot. Then I missed third gear, but put it back in pretty quickly.
4th run:
60' 2.281
330 6.179
1/8 9.320
MPH 78.54
Same launch but stuck pretty well. Slight wheelspin.
5th run and the best:
60' 2.228
330 6.114
1/8 9.261
MPH 78.43
Same launch again and had no wheelspin. I was pretty damn excited after I saw the slip.
__________________
8.7@80mph
What worked pretty well was just letting out the clutch normally, and then flooring it once the clutch was all the way out.
I didn't launch at like 3,000rpm or anything, just went off idle.
__________________
8.7@80mph
Just try babying it off the line. No sense in spinning the tires.
Put the pedal down like half way at first, then floor it after you build up enough speed to not break traction. That should get you some better times.
__________________
8.7@80mph
