1/4 and 1/8 Mile RacingTalk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
well i went to the track for my 2nd time ever but this time as a 3.5. I put up a new PB but i only got 2 runs in before they kicked me off because i had a gear oil leak(stupid pass. side axle seal) but heres my #, pics, and vids
1st run: the 60' sensor wasnt working in the left lane so idk the 60'
R/T: .177
1/8: 9.2
MPH: 78
1000: 11.8
1/4: 14.1
MPH: 100
2nd run: i launched way to high and spun the Dr's through all 1st
__________________
SHIFT_LOTS OF OIL
DCMAX current mods- 4th gen intake, 2.5" custom catback, NWP block off plate, 00SE tailight w/overlays, Rewired fog lights, Eyelid, JIC coilovers, FSTB, 3.0 OBX headers, SSIM...
95 White GXE- 15.1 sold... now 14.9 (car next to me in sig)
00 Sterling GXE- 15.0 (ebay intake, exhaust) my next love and beauty (crashed n sold)
02 Sterling GLE- 13.84@100 2.1'
Jean the burnout's were not long enough for the temp's, did you pull the e-brake
also ingore those dumbazzez at the track when it comes to the waterbox they were bring you up too far and had your rear tires in the water. put the front tires in the water and just flag them off
start the burnout there with the e-brake on till the dr's start to pull you out
all in all nice times for your 1st time out
__________________ My Cardomain _ _Maxima runs 13.4@109
Dyno:? whp & ? wtq
Nitrous PB: 13.4@110mph
All Motor PB: 14.0@99mph
3280lb with driver, full trim, rims, spare, jack, fluids, etc & notorized proof
Thanks for the advise, i pulled the ebrake in the 2nd, 3rd run
and thanks
__________________
1993 Maxima GXE 1995 Maxima GXE
As A De-K: 11/28/08 14.8 @ 93.8mph
As A 3.5: 03/13/09 14.1 @100mph
Are those 26" tires? That's probably a little too much tire. I noticed you're nowhere near 4th when you cross the traps. I think you would be see a decent improvement in ET if you tried some smaller diameter tires like 225/50-15 MTs.
Also, are you doing your burnout in 1st gear. If so, try 2nd. It's a little harder on your drivetrain, but it'll heat up the tires better. I prefer to spin the tires just a little while I roll through the waterbox. Then I start my burnout at the end of the waterbox.
Looking into my crystal ball, I see mid-low 13's in your near future.
idk the specs on the Dr's they were rented for the day but ill see if i could squeeze mid 13's on the motor then comes the spray and or Boost
but thanks for the info
__________________
My axle seal leaks too. I changed it two times with the correct one....and it still leaks....it is so annoying.
How are you running the stock clutch? My 3.0 makes the stock clutch smell when i launch it.... I could only imagine what that 3.5 is doing to the stock clutch.
you might be burning your clutch my clutch is holding for now
__________________
well i learned this the hard way, but when you fill the transmission up with gear oil, you gotta let it drain before you close the fill plug. too much gear oil in the tranny can mess up the seal. perhaps thats what you are doing
Wait.... so your saying when you fill it up... let it drain? Should I be topping off the gear oil? I don't really understand what you mean by let it drain. Let how much drain? Or just not fill it up to that amount that causes it to break the seal?
If you are trapping 100 mph, there is a 13 second pass in the very near future. I would be happy with a 13.999 @ 100 mph. LOL! Good runs!
__________________ 321VQ35MAX - 03 Black 6spd T.E - Injen CAI-Tein S Tech Springs - Tokico Illuminas - Clear Markers- ES Shifter bushings - ES subframe bushings - ES mount inserts
hmmmmm whats stage 2, do tell....man yall throwing in engines, clutches, etc like yall changing brake pads. what da heck. man if you look under your hood in my neighborhood, people look at you funny, they dont want a spec of oil on the asphalt...this has been on my mind for a minute now. why is it that when you swap the VQ35 in a 4th gen, it doesnt have that 350Z/G35 like growl like when its in the 5.5 gen, is it cuz most people use the 3.0 ECU, which doesnt allow the use of VTC/timing, etc. to me it sounds like the 3.0, just with a lot of bolt-ons. i heard one on the dyno, and if you didnt look under the hood, you would not be able to tell he had a 3.5 in his 4th gen....just curious
yea mines dosent sound like a z but it does sound slightly different than my de or de-k
__________________
iam about to install my headers, clutch and tune it so hopefully sometime in april ill get my 13 sec. slip then its on to stage 2 of my setup
With all those additions you will easily be in the 13 second class. Good luck. Keep us posted.
Too many things to take in account exhaust and intake manifolds ecu's simply put a Maxima will never sound the same as a Z. A Maxima can sound awsome but there are alot of differences in the the setups
