NWP Engineering VE Auto does 12s!
Update: Video has been added for my 12.8 second run. Sorry for the crappy resolution.
12 sec 92 Maxima vs SC300
The VE Auto runs 12s with just a 50 shot!
I ran two 12.95s tonight with the 50 shot. Both hooked up pretty well. This is the best one out of the two.
RT .074
1.827
5.239
8.191 @ 82.384
10.698
12.957 @ 104.372
The 50 shot hooked up pretty well tonight since I have the front spring perches locked together now. I'm really happy I almost saw a 1.7 60 foot. It will come someday!
I had only ONE run that I was actually able to hook up while spraying the 75 shot on the launch. After that, the track prep got MUCH worse since they stopped spraying VHT down, plus the temps were quickly dropping below 42 degrees. The track was much better near the beginning of the night when the really fast cars were running.
Here is the best 75 shot nitrous run out of my three 75 shot attempts. My other 75 shot attempts resulted in 13 flat runs with 2.0 60 foots. I spun the slicks REALLY bad, especially since track prep went down hill right after my first and best 75 shot run. Here is the best run:
RT .116
1.809
5.219
8.141 @ 83.037
10.641
12.896 @ 104.559
Anyway, it's late. I just wanted to post before I pass out. At least I saw 12s tonight. I have the 50 shot figured out. It's the 75 shot I'm still scratching my head over. I haven't figured out the best way to get consistant launches. I had the 100 shot jets with me tonight, but since I couldn't get good results from the 75 shot, I figured it was useless. Plus, I think I am seeing detonation from my 2 step colder plugs, pump gas advanced timing program, with straight 110 leaded race fuel! I just can't understand how I could possibly be detonating. My timing isn't advanced that much since it's just a normal 93 octane NA program I'm using. My eyes are burning so bad right now from the race fuel. The ride home was miserable. lol But it was worth it!
12s BABY! How you like that!!!?
RT .074
1.827
5.239
8.191 @ 82.384
10.698
12.957 @ 104.372
RT .116
1.809
5.219
8.141 @ 83.037
10.641
12.896 @ 104.559
Well I ran my normal NA 93 octane program. It's a 13:1 AFR for daily driving. So I made sure to put in the right fuel jet to accomodate this. My average AFR tonight was 10.5:1.
I pulled a couple of my brand new plugs after a 50 shot run to see grey speckles on the white insulator. Last time I saw detonation on 93 octane gas, I saw black speckles like pepper. But this time, it was tiny silver dots, which i've read can still be detonation.
But there is just no way I'm detonating with this race fuel I'm running. Even with advanced timing, I should be ok. I might try to get another set of new plugs and try the 75 shot again to see what happens on the STOCK program with stock timing. If I see the same silver specks, then there's no way it was detonation.
Congrats Aaron, looks like the cables on the front struts helped.
Looking at your timeslip is also proof my stock internal 3.0 should have hit 12.9x last year... Almost identical 1/8 and 1/4 #'s, except my sixty foots were 1.7's.
This is really exciting - all that work and planning paid off! Isn't it great when a plan comes together? And on a 50-shot, too....
Well, now that I'm about 130lbs lighter than last time, plus my suspension was setup like I wanted it to, it was easy to get 1.82s with the 50 shot. But the 75 shot only hooked ONE time with that 1.80.
I have wider wheels on their way right now. Some 15x8 Rota Slipstreams will be here Monday. Right now, I'm using the 22x8x15 MT slicks on a 15x6 millenia wheel. I'm hoping the wider wheel allows for better traction with this slick. We'll see. I'm thinking about hitting the track again pretty soon with these new wheels. I'm going to keep my car in track mode for the next couple weeks and just drive my beater Stanza everywhere.
Originally Posted by grey99max
Congrats! My guess is that you have too much spark advance - try the stock advance. I use about 10* max advance which never gave me speckles... Think about better slicks now. With all that tire-spinning, a larger diameter slick might be good. Then the 75-shot can hook up for you. I officially proclaim you to be a nitrous addict, and you may now join the secret society of N2OGasPassers. Addictive, isn't it?
I think my bottle may be empty after only 5 nitrous runs on the 50 and 75 shot. It can't be, but I saw really rich conditions on back to back runs. I gotta undo everything and weigh it. Hopefully, I got some nitrous left so I can make a pass on the street while I still have plenty of race fuel left in the tank.
I'm really hoping I can take advantage of the 75 shot on the launch. It's going to be tough to get it to hook up though everytime since track prep is so erratic at my local track.
Jime said he sprayed a straight 150 single shot. I don't know how he did that and still get a 1.7 60's. Do you have any idea how that can be possible? I tried spraying the 75 shot one second after my launch and I got a 1.9 60 foot. Traction was there, but the TC didn't flash nearly as high and the car didn't lay down nearly as much power compared to launching on nitrous.
I still can not search old posts
btw great times and with a 50shot
Originally Posted by Aaron92SE
Jime, do you know how high of a shot you were capable of launching with, without making your 60 foot suffer? I know you had the Maximizer, but I wonder if the 50 shot was too much power to launch straight out of the hole with.
Originally Posted by Jime
Aaron I found a 50 shot was optimal with the 2k2 but I ran the 150 on my 95 before I had the optimizer and still pulled 1.7's. All my 12.1 times were without the maximizer or dual nozzle setups. Not sure why you guys are having a hard time with traction unless your front end is moving more than you think.
Yeah, the front cables helped a LOT. My best 60 foot without them on the 50 shot was a 1.97. I just kept spinning the slicks, even on 12psi.
Yeah, I could have too much timing advance. But I still don't see how it could detonate with this race fuel. Next time, I am going to do with the same exact setup, but run stock timing with race fuel. I'll see how the plugs look then. Before I go, I'll have to put in new plugs b/c these are coating in silver specs pretty good.
Those silver specks could be aluminum specks. IMHO, that's preignition, from too much advance. Your cut grounds and race gas probably saved you from making lunch meat out of your motor, but try the retarded ignition next.
If you have a 10lb bottle, with 5 50-75 shot passes on it, the level is too low now. I weight the bottles when filled, then expect to replace it when the N2O is 1/2 gone. Lots of experience with this problem. I keep a digital bathroom scale handy for this.
Face it - Jime has made things work that us mere mortals may never duplicate - no joke. Don't ask me how his 150-shot worked - I would launch with a 75-shot and go into 150-shot while still in first gear - some 1.9x 60's happened, but lots of tire spin too. I never did figure out the right way.
Fill your bottles, at least wider wheels for slicks, wash your slicks with VHT/alcohol 50-50%, and try again.
Hey Aaron, good stuff and there is much more there yet. I'm still puzzled why you guys can't launch at higher shots. I really don't have any secrets to share or I would. I just nailed it right off the line with any shot and no traction problems. It wasn't until I got the 3.5 that I had to keep it down to a 50 or 75 launch. Plus that was all with the 22x8x15 M/T's and my M&H 23.5's are even better.
I m still looking forward to putting the spray on the 3.5 swap but it will be a while because I still think I can wring a bit more N/A. I have 3 NX bottles just waiting. Nitrous is the best boost solution going because you don'/t have to live with the everyday wrinkles that s/c and turbo's have and I still believe I can out perform them even with the poor old auto that everyone loves to curse.
I am in the process of getting a G35 for my wife but I have no ideas about racing with a second rate rwd.
but you should plan on taller and wider slicks. M&H has 23/8.5/15 and 24.x/8.5/15 slicks...
Also, I have a digital postal scale that measures pretty accurately. I always weigh my bottle when I get it filled. They usually put 10.5 lbs in it. I know my before and after weights.
I still haven't had a chance to weigh my bottle. I'll do that probably Monday and make a couple test runs on the street with new plugs if I have over 5 pounds left. I found out when I'm right at 4lbs, it starts to surge and it's useless to get great track times with it.
So the 150 shot hooks perfectly on the launch or just it spin a lot, but still get you 1.7s or 1.8s?
I am racing at one of the worst 'track prep' tracks in NC. There are a ton of 9 and 10 second cars that continually have problems breaking traction at half track and go towards the wall. This does not happen nearly as often on the other tracks I've raced at that spend the time and money to properly maintain the launch pad. Las Vegas was by far the best.
Ceasar, yeah, I got some videos. They are pretty crappy though. The microphone on my friend's camera cuts in and out. The footage should be ok, but the sound sucks! I haven't seen them yet, but I hope to get them today from him. I wish I would have raced some fast cars. The only cars I raced were those doing 2.2 - 2.4 60 foots. I do remember racing a Stang that did 12.1 with a 1.7 60 foot. I was RIGHT next to him on the launch. But as soon as he snatched 2nd gear, he just walked away from me.
VQrebuild96, please look on my website for a full mods list. www.NWPEngineering.com under the Project Car section.
I have run a 1.7 60' and 12.1 on 22" slicks spraying a 150 shot out of the hole so as soon as you hit that milestone I would consider upping the size. I ran approx 12 psi in the M/T's and they would sqawk coming out of the hole but thats all.
I have some 15x8 wheels on their way as we speak. I could see MUCH better results from them with the 22" slicks. I hope to try these out in the next week or two with the 75 shot launch.
Currently, I have the 22" MT slicks mounted on 15x6 Millenia wheels. The slicks do balloon a lot and I can noticeably see how the contact surface of the slicks are hindered.
I'm trying to get somewhere in your ballpark as far as 60 foots with the 22" slicks before I decide to go bigger. I KNOW it's possible. My track prep could be the biggest difference between me and you. Driving the car is pretty easy. I just do my burnout until the slicks yank me out of the water box, then I make sure the wheels are perfectly straight before I creep up to stage. I wiggle the wheel left, then right, then left a little less and right a little less and then almost let go of the steering wheel as I creep forward to prestage. I've always done this even when I was bracket racing and running high 15s on street tires. I believe every little thing helps consistancy.
But the slicks hook AWESOME after I do a good burnout. My rear skinnies get drug out of the water box and after about 3 or 4 seconds, they dead hook and yank me out! It actually catches me off guard sometime snapping my head back into the seat!
I just got the videos from my friend. It turns out that he filmed everything on the lowest resolution.
But here is the best video of the night. The others were much crappier. The fastest run is the best video I think.
I just added the video to the website. Please check it out. Sorry for the crappy resolution.
As you'll see in the video, I had quite a few fans near the end of the night that were cheering for my car. Nothing like a grocery getting doing 12s to get the crowd's attention. lol
Way to go, bud. Way to go.
I recently upgraded my drag wheels from the 12lb (recently weighed on my accurate postal scale, they are 12, not 11lbs.) 15x6 Millenia wheels to 15x8 14.5 lb Rota Slipstreams. The MT 22x8x15 slicks that I am using will be much happier on a 8" wide wheel! I am hoping for better 60 foot times b/c of it. Here's why....
Here are the old 6" wide wheels at 10psi:
In this pic, you can actually see how rounded the contact patch is.
Here is what they look like on the 8" wide wheel:
Big difference, huh?
Here is a measurement I took of these slicks with the Millenia wheels:
This is a measurement of 3/4" roughly at 10psi.
Here is with the slicks on the 15x8 Slipstreams at 10psi:
This is a measurement of about 3/8"!
One final pic:
These slicks are just so beautiful! I would have never thought I'd like the red lip. I didn't have much of a choice since these 15x8 Slipstreams are so hard to come by. I can order them straight from Rota, but it can take up to 6 months to come in. I didn't care, I would have gotten them in purple if I had to. Anything to see 1.7s!
One final pic:
Thanks for the pics Grey. It's nice to have wheels meant for the slicks. With these 15x8 wheels, in the future, I will be able to upgrade to a 23 or 24.5 M&H if the 22" MT slicks won't do a 1.7 60 foot.
Here is an update on my detonation problems. Yesterday, I finally got a chance to do some testing. I had some nitrous left in the bottle so I put in some new plugs and did some nitrous runs.
As some of you may have read, I have an NA advance timing program meant for 93 octane. I tried spraying nitrous with 110 leaded race fuel thinking that would solve any detonation problems. Well, I was wrong. It still detonated to the point of actual metal getting removed from the pistons. That's where the silver specks come from.
Well, I disabled the KS, retarded my base timing from 15 to 8 degrees and still ran the upgraded program with 110 race fuel. After doing a run, I read the plugs and saw a few tiny black speckles. I do a couple more runs with lower fuel pressure since it was too rich on the 1st run. I didn't see any more detonation on the plugs. Did another run, still no more detonation. So I am problem detonating ever so slightly, the motor can handle that. But I'll probably still retard the base timing a little bit more or vouch to run the stock program here on out with nitrous.
So, for my next track visit, I will be running pretty much straight 110 race fuel with the base timing set at 7 or 8 degrees. I'll have an extra set of plugs with me in case I see detonation and have to make an adjustment. That way, I'll have new plugs to be able to read on my next pass.
I really hope to be able to hook up on the 75 shot for a 1.7 60'. If the plugs look ok, then I'll put in the 100 shot and see what happens on the launch.
I was scared of this when I bought nitrous. I'm addicted! Who wants to see a VE Auto in the 11s?
Thanks for the quick shipping on these wheels. I'm motivated right now since the weather is cold, the track is still open, and my car is ready for great times.
Ah, yes, the infamous N2O addiction... better known as Spray and Pray. Nitrous doesn't need much ignition advance, does it? But the 100-shot awaits at long last - then it's 125 and 150 and 200-shot spray...
I think 26" slicks will fit if I have to. It might be a tight fit with the 15x8s with 40mm offset. Right now, with the MT slicks, I have about 3/8" of room, but the spring perch might be a problem when I go with a taller slick. I can always get some zero offset wheels like I've seen on some 10/11 sec Civics.
But yes, nitrous is addicting. And no, I found out that with nitrous, it doesn't take much to detonate. It's very likely that stock timing is best for nitrous as far as making max HP. All dangerous detonation aside, advancing timing may not actually help make more HP. With my VE, it doesn't take much to see detonation.
With stock timing, 93 octane, 11.5:1 AFR, 1 step colder plugs, and a 50 shot, I saw detonation on the plugs. For all those out there that are spraying nitrous on your daily driver, heed that warning! You are most likely detonating on your 50 or 75 shot of nitrous. It doesn't take much!
With nitrous, it's really tough not to just drop in the 150 jets and play dumb. I've thought about getting ahead of myself and just going with an untune 150 shot. But I'm smarter than that. I'm trying my best to take it slow. Increase the nitrous slowly! Every step up in nitrous jet involves a completely new tune! The AFR is always thrown WAY off and the timing needs to be adjusted in most cases.
My change from 50 to 75 shot alone threw my AFR way off and I saw a 13.5:1 AFR one time with the 75 shot. I backed out and had to change fuel jets one more richer than what was recommended by Dynotune.
So, using the jets that NX, Dynotune, or NOS tells you to is just a starting point.
I'm not talking directly to you grey. I'm just spreading information for everybody out there that sprays a 75 shot in their Maxima. Untuned, a 75 shot can blow your engine very fast! I'm trying to get everything spot on before doing the 100 shot, then 125, then 150, 175, 200, etc! It's going to be a long process that will involve me getting more nitrous bottles!
I can see how nitrous starts to get very expensive with you get in to the 150 shot range! On the LS1tech.com Nitrous forum, I remember reading one guy said he can only get ONE pass from his bottle! That's NUTS! The car runs 7s or 8s, but still. ONE PASS!
