04-07-2005, 11:14 AM
Unsuccesful STL Coordinator
Launch
What is the best way to launch an automatic off the line? Also, would you suggest manual shifting on the automatic through the first 3 gears?
__________________
04-07-2005, 11:31 AM
Throbbing member
Two schools of thought on this:
1) Flash your TC and floor it
2) Brake torque to 1500-2000rpms
Personally, I'll be going with the first method as I don't think it's as hard on the car.
~THT
__________________
Some people call it an obsession; I call it my Maxima.
Daily driver: 2004 Obsidian Black Infiniti M45
Fun/project/track: 1996 Deep Evergreen Nissan Maxima w/ cammed VQ35, Quaife 5spd, and a whole bunch of other stuff
Bad weather/winter beater: 1998 Silver Toyota Rav4 (AWD w/ LSD)
STUFF FOR SALE!
FS: VQ35 cams
FS: 4th gen David L red/clear tails
04-07-2005, 11:33 AM
TC? Brake-torque?
__________________
04-07-2005, 11:52 AM
Throbbing member
TC - Torque converter. You flash it by holding the brake with just enough force to keep the car from moving forward.
Brake torque - Give the car gas until you reach desired RPMs while standing on the brake pedal.
~THT
__________________
STUFF FOR SALE!
FS: VQ35 cams
04-07-2005, 12:00 PM
Quote:
~THT
Yeah, I already do that. What would be the best rpm's?
04-07-2005, 12:11 PM
Throbbing member
Depends on your mods as well as the condition of your tires. Try a variety of RPMs and find what results in the best 60 ft.
~THT
__________________
STUFF FOR SALE!
FS: VQ35 cams
04-07-2005, 12:20 PM
Would it be better to manually shift the gears?
__________________
04-07-2005, 12:23 PM
Throbbing member
Personally, I won't because I have a GXE that naturally redlines every gear. If yours is the same way, no sense in interfering with it. Again, try it both ways and find out what's best; that's what tracks are for.
~THT
__________________
STUFF FOR SALE!
FS: VQ35 cams
04-07-2005, 12:50 PM
Certified Hooptie
~THT
Did I miss something here, since when did GXE's shift at redline?
Epcay Shift at redline otherwise and don't bounce off the limiter, it's hard not to do in 1st. What mods do you have? When are you going to run? What's the elev. of the track? Post results ..
04-07-2005, 01:47 PM
Throbbing member
Few do, most don't. SE models are the opposite; most do, few don't.
~THT
__________________
STUFF FOR SALE!
FS: VQ35 cams
04-07-2005, 01:59 PM
You can see the mods in my sig. Intake, Catback are the main performance ones. I have run a few times. Best I have done so far is 15.09. I keep dropping at least a tenth every time I run so it is just a matter of driving it right. I do have 18's on though. Thinking about putting my stock 17's up front and seeing how it runs.
I don't know the exact elevation but the surrounding area is about 450ft above sea level.
__________________
04-07-2005, 03:44 PM
Certified Hooptie
~THT
Niether of my SE's do.
04-10-2005, 01:07 AM
Any more help?
__________________
04-28-2005, 10:14 PM
When I was A/T I simply stood on the brake and dumped the accelerator. The TC only let me up to about 1800. I did notice there was a way (at times) to feather the accel. up instead of dumping it and getting better 60' but I never had enough time to experiment before I converted to 5spd.
__________________
04-28-2005, 11:36 PM
Certified Hooptie
Now with my VB mod it shifts closer tor edline, but since the shifts are so crisp, I need to hold the gear longer because being that is shifts quicker the recover rpm in 2nd gear is much lower tnan with the stock unit. So now I have to do it at redline, and a little after (darn Max tachs being odd so much) so that I will be at about 4.1-4.2k. Also, I wanted to ask opnions of what people think about ... ok Do you finish 3 gears in the 1/4, or finish while still in 3rd? Just a though from driving maximas for a while ... basically the lockup tq convertor will rob about 300 rpms if left in 3rd, and if not you gain it if you leave it in 4th/OD, but by leaving it you can't shift past 6k ... but would this be worhtwhile rather than going from 2-3 and leaving it in 3rd, but instead going from 2-4 (the auto will stay in 3rd while WOT if any one doesn;t know) so you will have the extra 300 rpms ... just a thought ...
05-02-2005, 04:53 PM
Yeah i just Break-Torque at about 1500 rpms
05-02-2005, 06:50 PM
i have to manually shift myn so i can get her to shift at 6600. and yes i brake tq. simply becuase engine is starting at a higher RPM so it has less distance to climb and you have much more power at 1500 RPM than 700 rpm
05-05-2005, 06:06 AM
i hate manually shifting. feels so bad for the car, and yea it's hard to time it right in 1st so youre not workin the limiter, happened to me once and oh did i feel the pain, and the smell afterward....
__________________
AEM/Cattman/Energy Suspension/FrankenCar/Motostorm/Place Racing/SSR
/////Alpine/CDT/Eclipse/KnuKonceptz/Optima/SoundSplinter/US Amps
01-10-2006, 05:28 PM
how much for the tranny swap thinking about doing that or full tranny rebuild
01-10-2006, 05:36 PM
Certified Hooptie
Quote:
adollartw0ninetyeight.
01-10-2006, 05:57 PM
In order to really reach the stock redline, your tachs needs to go to 6700-6800 (depends on the car).
01-10-2006, 06:04 PM
Certified Hooptie
Quote:
Dude, the former member that started this thread is  ... Let it die  But you make a valid point, just that it's been beat to death..
My A33B tach is  compared to my A32... I've said this before though.
E55AMG2 said it best ... Depends if your car was class clown or valedictorian
01-10-2006, 06:08 PM
I hadn't noticed he was banned.
01-10-2006, 06:12 PM
if you dont want to bounce the limiter you have to shift a while before it. I just went on sunday and i bounced it once when i shifted at 6300. as for the time, with your mods you should be able to pick up about .3 from what you have done. just dont stomp the pedal at start, go slowly into it so the engine doesnt bog...trust me it works. i ran 15.08 with the own the pedal method and 14.7 with the slow pedal method (with 18's). also, youve got to manual shift otherwise you wont get everything that your car has. so back to the question. when i launch i brake torque it to between 1200 and 1500, it actually seems to give me better times when im at the lower rpms, dont know why. i think that revving to 2000 before you launch confuses the computer, just a guess. give a couple methods a try and just remember what you did for each run so you know whats fastest.
01-10-2006, 06:13 PM
bah, banned, i didnt notice either.
01-10-2006, 06:14 PM
Certified Hooptie
Damian87 brought it back from the dead
01-10-2006, 06:17 PM
I hadn't noticed his post.
ARRRRRRRRGGGGGGGGGGHHHHHHHHHH!
01-10-2006, 06:46 PM
Epacy - if you're pretty close to stock don't power launch (brake down with 2,000rpm) - you will not go as fast as what THT calls a 'TC' launch.
Try 1,000 with just enough brake pressure to keep still then push the gas down hard when it goes green.
I've only had two 1/4 mile runs but even I can see that there are too many variables involved to be accurate here mate: tyres / pressure (25PSI fronts and 40PSI rear) / mods / ride height - have you lowered your SE?
Best advice is to launch @ 1,000rpm (just above idle) and work from there. That's what I'm doing bro.
__________________
UNDERESTIMATE THE VQ AT YOUR PERIL!
http://youtu | |
