Go Back   Maxima Forums > Track and Tune > 1/4 and 1/8 Mile Racing
1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Thread Tools Display Modes
Old 03-19-2005, 12:20 PM   #1
First time at the track - 14.423
I just went to the track last night with my 02 Max for the first time. My best run was a 14.423 @ 92.026 with a 2.168 60'. I didn't shift into forth on that run thats why my mph is low. However, my highest mph of the night was a 93.319. Is this mph low for a for a bone stock 2002 Max 6 speed? Also, sometimes I had some real bad wheel hop on the 1-2 shift. Are guys riding the clutch on this shift? Finally, are guys shifting early on the 3-4 shift or is anybody else not shifting?
Next time I go I will have 93 octane in the tank and a tire pressure gauge.
Gears
Gears & Crosses is offline   Reply With Quote
Old 03-19-2005, 12:56 PM   #2
Maxima.org Sponsor
Those times seem right but the traps seem a little low. Excellent 60 fts for your first time at the track.
__________________
NEW RIDE
Black 06 AWD Trailblazer SS
13.006 @ 105.4(NA)
SOLD
Sterling Mist 02 SE (Auto)
Best ET - 13.77@98.47 (NA)
juice is offline   Reply With Quote
Old 03-19-2005, 12:57 PM   #3
8600RPM and Counting!!!!
Zack342's Avatar
Send a message via AIM to Zack342
yeah nice times but your traps seem really low
__________________
2003 Nissan Maxima SE - Majectic Blue 6MT HLSD Meridan Edition, Titanium Editon-Dynoed 206.61whp and 219.54wtq...Stock
17 Degree Timing Advance*Apexi/Berk Short Ram Intake*Cattspeed Y-pipe*Cattman 2.5 B-Pipe*HKS Sport Exhaust*Cattman Ti FSTB*Progress RSB*ES Poly Front Sway Bar Bushings*HKS Grounding kit*Axxtion STS
Zack342 is online now   Reply With Quote
Old 03-20-2005, 12:01 AM   #4
Pull your codes, that mph is simply too low. You should be trapping 95-96 mph. You seem to be a really good driver for the mph, though.
JClaw is offline   Reply With Quote
Old 03-20-2005, 12:38 AM   #5
Old Maxima Legend
Ceasars Chariot's Avatar
Send a message via AIM to Ceasars Chariot Send a message via MSN to Ceasars Chariot Send a message via Yahoo to Ceasars Chariot
i love those 5.5 gens !! 14.4 stock ! excellent night out !
__________________
N/A - 97 SE - VQ30DE - 93 octane
13.8 @ 98x - 2.06 60' - USIM
13.5 @ 101 - 2.10 60' - OOVI/EU
N/A - 97 SE - VQ30DE-K Swap
TBA
Ceasars Chariot is offline   Reply With Quote
Old 03-20-2005, 12:53 AM   #6
Need A Light?
steven88's Avatar
Send a message via AIM to steven88
gears and crosses...your times are very impressive if you ask me....2.1 60ft in a 6spd is so hard for me...haha i only managed a 2.45 at BEST my first time out.....
also your holding 3rd gear in yer 6spd? wow I heard that it was almost impossible to hold 3rd gear in the 6spd without bouncing off the rev limiter....I never tried 1/4th mile in my 6spd yet....but I think even if i shifted redline ever gear...I would stilll have to shift into 4th in 1/4th mile....just judging from how quick the tach needle swings up compared to my old 4th gen 5spd.....even my old 4th gen had to go into 4th gear for 1/4th mile racing...i had i/y/e and short shifted the 2-3 and 3-4 shifts at like 6200RPMs
steven88 is offline   Reply With Quote
Old 03-20-2005, 07:42 PM   #7
Thanks for all for the complements, but I really have to the credit to track however. They really sprayed down the track with VHT that night. I have also learned alot from this site, so I thank you.
JClaw, I might need to pull my codes. My car REALLY lays down above 80 mph. Any ideas/reasons???
Ceasar, you might want to try Hub City dragway one time before it gets hot. The track prep was awesome last Friday.
Any recomendations on the 1-2 shift?
Thanks again,
Gears
Old 03-20-2005, 08:09 PM   #8
Steven, remember to burn the clutch and not the tires. Try playing with the tire pressure too. I found out later that on my best pass I had 26 psi. You can try different tracks also, if they are available. If you can afford some Nittos, those would help alot.
I wanted to tell you that I definitely hit the rev limiter on that pass - then coasted. I just tried it just once (its an old 5.0 Mustang tip) and I'm really not sure if it helped. I shifted right before red line on all shifts give or take 200 rpm.
By the way Steven88, you have a sharp looking car,
Gears
Old 03-24-2005, 06:43 PM   #9
Any recommendations on the 1-2 shift?
Thanks again,
Gears
Old 03-25-2005, 12:57 AM   #10
Need A Light?
steven88's Avatar
I take my 1st gear all the way to 6900 (6600 rev limiter)...the stock tach is off that is why I take mine to 6900....then I do a speed shift...not power shift but speed shift....
a speed shift is when you shift as quickly as possible with the clutch, and letting go of the gas....a power shift is when you shift quickly as possible by using the clutch but not letting go of the gas....and a clutchless shifting is...you guessed it....mashing on the gas while shifting the gears without using your clutch
Old 03-25-2005, 07:28 AM   #11
Send a message via MSN to bgates1654
The deeper you can take the 1-2 shift the better.
bgates1654 is offline   Reply With Quote
Old 03-25-2005, 08:25 AM   #12
Send a message via ICQ to PlanoSER Send a message via AIM to PlanoSER Send a message via Yahoo to PlanoSER
dont let off the gas all the way when you shift to 2nd, also drag the clutch just a tad when ure shifting to 2nd, this should help the wheel hop a bit.
The 60ft is good but youre right, the trap seems extremely low. It should be 96-97mph if you ask me which would have been a 14.1-14.2 with the 60ft you got. Definitely run 93 octane next time and make sure your air filter's clean. Hell, even remove it for a run or 2 just to see.
PlanoSER is offline   Reply With Quote
Old 03-25-2005, 11:51 PM   #13
On ALL VQ-powered maximas, the Knock Sensor loves to take a dump on you for no reason. This retards timing and has been known to be able to rob you of 15-20 hp. 93 octane certainly helps. Always use 91-94 octane. With the same 60' and a normal ~96 mph trap, you would/should pull a low, low 14-second pass, I believe the current record is 14.09. No stock manual Maxima, or Altima, has been known to hit 13.99 stock. Feel free to be the first
There was a thread about the optimal shift points a while ago. I've never driven a 2k2 6-speed since I'm poor, but while 4th gen 5-speeds seem to benefit from shifting gradually lower as you go through the gears (I pulled a 15.003@91 mph in my stock 1995 while shifting 6600, 6400 and 6200), 6-speeds should supposedly redline every gear. Simply put, as far as you can f*cking go.
Old 03-28-2005, 02:45 PM   #14
Thanks for all the replies guys. Sorry for my late reply.
I will definitely shift as late as possible on the 1-2 shift. I always speed shift but never powershift because I like my tranny too much. My trans is feeling a little notch anyway. I need to change the tranny fluid bad. I am having a lot of trouble finding sythetic GL-4 fluid. I know I can order it but I want to do it ASAP, but thats another story.
Thanks for the advice Plano. Thats what I'll try next time. I need to drag that clutch just a hair. I'm used to driving my Mustang and hammering 2nd.
My air filter was brand new with fresh motor oil on that run btw. I do need to make a confession though. I think I had 89 octane in the car that night not 91 like I thought. I didn't have any pinging since it was so cool. Oh well, my bad.
Gears
Old 04-01-2005, 09:20 PM   #15
Send a message via MSN to vsamoylov
that preety fast # you got there for a bone stock 6 speed man. props to you.
vsamoylov is offline   Reply With Quote
Old 04-01-2005, 09:35 PM   #16
Yeah and I want to know what your car can do vasily. Same as a 5.5, but 250 lbs lighter.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
