Go Back   Maxima Forums > Track and Tune > 1/4 and 1/8 Mile Racing
1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Thread Tools Display Modes
Old 01-15-2005, 05:13 PM   #1
Send a message via AIM to A'sMax Send a message via Yahoo to A'sMax
Anyone use g-tech ?
I used g-tech to check 1/4 mile. My best one were 14.55 @ 103 60mph , 0-60 6.03.
Isn't 103mph little too high ? How inaccurate can g-tech be ?
Can anyone post times from g-tech ?
A'sMax is offline   Reply With Quote
Old 01-17-2005, 05:32 PM   #2
Send a message via AIM to TheMax95
No way are you trapping 103 with a ypipe and clutch in a 00 5speed. 93mph would be believeable. From what I've read, those g tech things are not accurate for shyt.
Just take it to the track. 0-60 means nothing anyway. who races only 1st and 2nd gear?? lol
-Paul
TheMax95 is offline   Reply With Quote
Old 01-17-2005, 06:05 PM   #3
-Paul
That's what i thought. Thanks.
Old 01-17-2005, 06:48 PM   #4
Send a message via AIM to emmas97
the g-tech can be relatively accurate, as long as you have no wheel hop, no turning, etc. you pretty much have to have a perfect run on a perfect surface.... i have had anywhere from a 14.10 or something to a 15.2
emmas97 is offline   Reply With Quote
Old 02-04-2005, 10:26 PM   #5
Send a message via AIM to Big Tyme Send a message via Yahoo to Big Tyme
Ditto, perfect straight away, no incline or decline, center of windshield, and zero it out good before you launch. Thats how you get an accurate reading. If not, fawget about it.
Big Tyme is offline   Reply With Quote
Old 02-07-2005, 03:44 PM   #6
Two Faced Axhole...
DAVE Sz's Avatar
The new $200+ gtech is pretty close but I'm guessing you used the cheapo $50 one. Your 0-60 doesn't really matter but the gtech is off about half a second, same goes for the 1/4 mile ET, maybe even .6-.8 off.
__________________
DAVE Sz is offline   Reply With Quote
Old 02-07-2005, 09:42 PM   #7
drag racing is for wussies
BlackBIRDVQ's Avatar
Send a message via AIM to BlackBIRDVQ
G-TECH gives you the MPH at what speed you crossed the 1/4 mile marker. Track uses diff type of MPH readout. My Gtech was accuratte to .2 on the ET with my Sentra. Alot of friends of mine use it when bracket racing so they don't break out, basically at the end of the run they shut it down and end up runing times like 12.24@only 92MPH.
__________________
Mike Jez
2004 Volkswagen R32.
OZ wheels, tons of suspension mods, brakes, go fast & light goodies.
BlackBIRDVQ is offline   Reply With Quote
Old 02-08-2005, 11:46 AM   #8
ive noticed g-tech are pretty close to accurate my bro run a 12.69 with his Z28 and at the track he run a 12.63 so its pretty damn close. i use it on my maxima also it seems to be accurate
foitdaddy is offline   Reply With Quote
Old 02-08-2005, 07:09 PM   #9
Send a message via MSN to 5thgen2nr
Lol....wait a minute...this is sooooo not fair...I got raped up the *** on here for talking about what times I got with my G-tech like a month ago...why the preferential treatment for this guy? Seriously though, the trap speeds are 2-3 mph optimistic, and I'm not sure about the E/T...like everyone has said, the only sure way to see how accurate the thing really is, is to take your car to the track.
__________________
5th generation SE: Sterling Mist, Autotragic
custom-fabricated K&N WAI
custommaxima.com CA-spec Y-pipe
HKS dual-outlet rear exhaust section
Progress sport springs
crankcase ventilator
Next Level Performance stage 1 G-box
street scene grille and valence
Mobil-1 full synthetic motor oil
NGK iridium spark plugs
5thgen2nr is offline   Reply With Quote
Old 02-08-2005, 08:03 PM   #10
I made 9 passes at my local dragstrip with the G-tech in my Max...... I threw out the fastest and slowest and adveraged the others ..... I made 5 runs that were 15.0 to 15.1.... my car is auto and in full street trim (ie slow) I found that the G-tech was about 2/10 slow and about 2mph over on the traps.... so g-tech 15.2 at 91 mph time slip was 15.0 at 89mph .... I did the same test with my 300ZX and found that the results were about the same.... however it's hard to run the same # over and over in the 5spd Z
__________________
click here for more pictures
z32drifter is offline   Reply With Quote
Old 02-10-2005, 07:05 AM   #11
You will lose
TAPOUT's Avatar
The timer is probably right, and you just can't get a good launch on the street. No VHT, no burnout to heat the tires up, 60 ft times on the street suck. I love mine, and it has never been off by a full 1/10th at the track. And the MPH was right everytime too.
TAPOUT is offline   Reply With Quote
Old 02-10-2005, 09:57 PM   #12
Send a message via AIM to cefiro8701
-Paul
i killed a 17 psi tuned wrx today on 1-2 gear...i drive an auto..
cefiro8701 is offline   Reply With Quote
Old 02-11-2005, 12:50 PM   #13
WTF is Juice?????
deezo's Avatar
Send a message via AIM to deezo
Quote:
There's no preferential treatment here.
Time slips provide a more accurate reading of 1/4 times. Gtechs don't. Period (Yes, I've used them).
deezo is offline   Reply With Quote
Old 02-19-2005, 11:26 AM   #14
Send a message via AIM to Charcoal95GXE
Quote:
hahahahhahahahahahhaahhahahahahahahhaahhahahahahah ahahahahahahahahahahahahahahahahahahahahahahahahah ahahahahahahahahahahahahhahahahahahahahahahaahhaha hahahhahahahahahahahahahahahahhahahahhahahahahahha hahahahahahhahahahhahahahhahahahahhahahahahahahaha hahahahhahahahahahhahahahhahahhahhahahahhahahahahh ahahahahah..maybe he was new to pushing the "gas pedal"
Charcoal95GXE is offline   Reply With Quote
Old 02-19-2005, 11:50 AM   #15
Quote:
I would probably have to second this thought...
Old 02-19-2005, 12:09 PM   #16
Thats going off the fact that u say "tuned to 17PSI" the factory wrx turbo is only efficient up to 15 lbs. So, more than likely youd be tuning an after market turbo a.k.a. a VF-30, 34 , maybe a 22..with a decent tune your talking 270's ish to all four wheels, so traction is no issue..only problem u could possibly have is lag but after 15 MPH thats almost obsolete...so somehting here just is not adding up....
Old 02-22-2005, 08:40 AM   #17
WTF is Juice?????
deezo's Avatar
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
