Go Back   Maxima Forums > Track and Tune > 1/4 and 1/8 Mile Racing
1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Thread Tools Display Modes
Old 12-23-2004, 10:58 AM   #1
fwd gone rwd cr00
tavarish's Avatar
Send a message via AIM to tavarish Send a message via MSN to tavarish
possible for 14s with stock auto?
Hey, I just realized that without extreme modification, my automatic transmission will most likely die under added hp (nitrous, turbo/aupercharger). Is it at all possible to run 14s at the track with my stock auto tranny without having it blown to bits?
Would it be worth it to swap to 5spd?
Thanks.
tavarish is offline   Reply With Quote
Old 12-23-2004, 01:05 PM   #2
it could probably hold with a massive tranny cooler, but not for long... at all
__________________
98 SE/ Tokico Springs/ Illuminas/ ES front end bushings/ SS brake lines/ LLS Y & B/ DR WOT switch/ Smoke red clears/ AE headlights
Pimpmobile is offline   Reply With Quote
Old 12-25-2004, 10:53 PM   #3
Send a message via ICQ to Torgus Send a message via AIM to Torgus Send a message via MSN to Torgus Send a message via Yahoo to Torgus Send a message via Skype™ to Torgus
Quote:
What are you talking about?
jime's auto has done 3 seasons on a stock tranny iirc, it runs 12s with 150 shots....
i beat on mine and it's fine 160k+.
buy and upgraded VB and throw on a tranny cooler and you'll be fine for whatever you want to do...
if your tranny fails it's beacuse it was worn out and going to fail anyways...i wouldn't worry.
i'm very happy with my nissan tranny.
Torgus is offline   Reply With Quote
Old 12-27-2004, 09:04 AM   #4
fwd gone rwd cr00
tavarish's Avatar
wow, that made my day, my tranny won't die, at least I think it wont, and I dont beat on it much, just occasionaly......I'm thinking about getting a junkyard turbo kit goin....but for now, my first project is N20.
Old 12-28-2004, 11:53 AM   #5
NWP Engineering.com
Aaron92SE's Avatar
Send a message via AIM to Aaron92SE Send a message via MSN to Aaron92SE Send a message via Yahoo to Aaron92SE
Thanks.
I am doing 14s every time I step on the gas. I beat on my car pretty hard, but I keep it maintained flawlessly. I have a VB mod and always keep my tranny temps low and my fluid in new condition.
But I will build my tranny up before I go turbo.
Aaron92SE is online now   Reply With Quote
Old 01-06-2005, 02:59 PM   #6
RIP Cashj2002
Fluid changes are a must on a modded car....
Cutler is offline   Reply With Quote
Old 01-06-2005, 06:59 PM   #7
NWP Engineering.com
Aaron92SE's Avatar
Quote:
They are a must on any car. But they are even more important when you start pushing more HP.
Old 01-06-2005, 09:47 PM   #8
You will lose
TAPOUT's Avatar
My tranny is fine too...
__________________
Quote:
Originally Posted by Libra Monkee
The fact that you have "Honda Civic" written on the back of your car. And the fact that I have "Subaru Impreza WRX STi" written on the back of mine. Should precipitate your balls into shrinking, along with your presence. Now...Fook off!
TAPOUT is offline   Reply With Quote
Old 01-09-2005, 12:07 AM   #9
[quote=tavarish]
QUOTE]
i think it would personally... my friend has a stock 5 spd. 4th gen, and we lined my 95 auto against it and he absolutley killed me, of course i was turning over 18's and a system. but i would go for the swap.
hhsguy150 is offline   Reply With Quote
Old 02-08-2005, 07:14 PM   #10
Send a message via MSN to 5thgen2nr
Are 14's possible in a fed-spec auto maxima? Yes. Possible in a cali-spec auto maxima like mine? Not a snowball's chance in hell.
__________________
5th generation SE: Sterling Mist, Autotragic
custom-fabricated K&N WAI
custommaxima.com CA-spec Y-pipe
HKS dual-outlet rear exhaust section
Progress sport springs
crankcase ventilator
Next Level Performance stage 1 G-box
street scene grille and valence
Mobil-1 full synthetic motor oil
NGK iridium spark plugs
5thgen2nr is offline   Reply With Quote
Old 02-09-2005, 08:30 AM   #11
Quote:
im cali spec automatic also and besides throwing 02 codes every once in the while, i run a 12.9 so 14's is possible wihtout a doubt.
C MAX is offline   Reply With Quote
Old 02-13-2005, 12:44 AM   #12
Quote:
Yes, but we are talking STOCK here, and if you are running 12.9, you are obviously NOT stock lol.
Old 02-13-2005, 07:30 AM   #13
is stock auto the same as non modded automatic cause if it is i dont think its possible cause if its stock, the numbers are high 15's. but if your talking about any stock max 14's are obtainable thru high revving and good shifting.
maxboogie is offline   Reply With Quote
Old 02-13-2005, 10:13 PM   #14
My tranny blew at 65k when juiced and i had the valve body and a tranny cooler
__________________
2001 Red Z28 5.7 mmmmmm
waveridr85 is offline   Reply With Quote
Old 02-13-2005, 11:29 PM   #15
THT
Throbbing member
THT's Avatar
Send a message via AIM to THT
I think he means anything short of FI. With bolt-ons, your stock auto tranny will get you into the 14s. You'd probably be about as fast as a 5spd if not a tick quicker.
~THT
__________________
Some people call it an obsession; I call it my Maxima.
Daily driver: 2004 Obsidian Black Infiniti M45
Fun/project/track: 1996 Deep Evergreen Nissan Maxima w/ cammed VQ35, Quaife 5spd, and a whole bunch of other stuff
Bad weather/winter beater: 1998 Silver Toyota Rav4 (AWD w/ LSD)
STUFF FOR SALE!
FS: VQ35 cams
FS: 4th gen David L red/clear tails
THT is offline   Reply With Quote
Old 02-14-2005, 01:22 PM   #16
Yes, with all the bolt ons, your 3 liter can make it into the 14s...no way in hell if you keep it stock...just to give you an idea of how hard it is to make an auto 5th gen 3.0 quick, that's what I drive, and I have intake, y-pipe, no main cat, and an HKS axle-back exhaust...I took out my back seat for a run, and was only able to get a 15.2....A bone *** stock 5th gen 3.0 liter 5-speed GXE can beat that with a good driver...the cheapest way to get your car into the 14s is to take out all the trunk insulation, jack, spare donut, back seat bottom and seatbacks, passenger seat, bolt some 15 inch lighter GXE steelies in place of the heavier stock 17 inchers on your front wheels, and you may, just MAY squeak into the 14s with a bone-stock automatic.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
