1/4 and 1/8 Mile RacingTalk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
How to correct for Density Altitude (DA). Step inside.
Have you ever been to the track and heard a gearhead say, "Damn the DA is crappy today!" and you think to yourself what the hell is DA? DA stands for Density Altitude and it's the way drag racers correct thier times to compensate for weather conditions and altitude. Changes in weather and altitude can play a huge role in how your car performs. Keep in mind that some tracks are just plain faster/slower than others thanks to differences in timing equipment, the grade of the track, track surface, and the way MPH is calculated.
Here's how to start:
1) Find out the elevation of your track. Use a good search engine and you should be able to find it.
2) Go to www.wunderground.com and find the city where your track is. Once you've located your area, you can dig up historic weather conditions for any day in the past 10 years. You'll want to get the temp, baro pressure, and dew point of the time and date of your run.
3) Go to http://wahiduddin.net/calc/calc_hp_dp.htm and input your numbers. Hit the calculate button and locate the calculated Density Altitude. The DA number generated is the calculated theoretical altitude during you run.
5) Calculate your numbers and that is what your car should have run under ideal conditions. Sometimes your DA actually shows NEGATIVE altitude which means the car is performing far better than normal and there's nothing to correct and compensate for. Usually only coastal areas in the South, East Coast, and Northeast will experience these rare conditions thanks to low altitude and strong high pressure areas due to the proximity of the ocean (~400 miles). It's also a primary reason most of the "freak" cars reside in these regions.
Here's my favorite corrected DA:
August 20, 2003
96 degrees
32% humidity
29.89 baro
62 degree dew point
950 altitude
DA 3800'
Actual ET/MPH: 14.65@94 2.23 60'
Corrected ET/MPH: 13.98@98mph
On average, my DAs show my car should technically be in the 13.9-14.0@99mph+ range with 2.2 60 foots. However, until I run 13.9-14.0, my car will remain a 14.4 second car.
Calculating for DA is great in that it lets you gauge your cars performance during the season and between the tracks, but for the love of God do not use it was justification that your car is quicker than some other guys. You run what you run. If anything just state that the DA you ran in was really poor and people understand. Correcting your slips and putting it your sig is as bad as using G-tech numbers.
__________________
2003 Black G35 sedan automatic
Best ET: 14.32, Best MPH: 99.87mph
Mods: MD spacer, HR y-pipe, RevUp airbox, Z-tube, 05 sedan midpipe, 350Z/Coupe springs, lots of other stuff
Sold -1996 Black SE 5-speed MEVI & JWT ECU equipped
14.31@99.34mph with a 2.18 60'
I'm glad this was brought up. Angers me when there are people asking why they ran a 16.xx when they're 5000'+ above sea level and have a reasonable amount of mods.
__________________ 03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
The only other minor thing to consider is the situation in which a time with a positive DA is converted to the lower time at sea level. Would the driver have been a good enough driver to deal with the extra power (traction) if they actually were at sea level? Correcting times = fun
Corrected times are more useful in determining whether or not a car is making the power it should from the trapspeeds. Cars are much more consistent than drivers in most cases.
Dealing with the power shouldn't really be an issue I don't think as were only talking about fluctuations on the order of 5%, maybe 10% in very extreme cases.
wow...i inputed all my info and calculated the DA for my best time recently which was a paltry 10.128 at 71.63mph at Dunn-Benson Dragway, NC. I was shocked that i went up almost .7 from my last outing.
The DA was an astounding 8338ft!! Using the calculator from the nhra website, which by the way didn't measure that high, lol, i extrapolated the numbers for 8300 ft...times go down by .0013 per 100ft, traps go up .0014 per 100ft...
9.065 at 79.67mph...time seems a little low, but since i beat a rather rich supercharged 2000SE max, it seems decently close,
__________________
Pebble Beige Baby
'95 Autotragic Freak
19" Staggered Sportmaxx 962's | D2 Coilovers | V-AFC2 | FrankenCar Intake | Unorthodox UDP
Budget Y-Pipe | Custom Exhaust | David L's Red/Clears
00vi and nitrous soon
First 1/4 times from Maxus '09 : 15.93 @ 85.77 SHIFT_on-a-budget
I don't see how the track in NC can be that high of DA. Crunch the numbers again and see what you come up with. It has to be over 145 degrees for you to get those kind of numbers.
I just typed in dunn-benson dragway elevation in google and found what I think you were looking at... 5800 feet. But that was for Bandimere dragway in Colorado. It was just on the same page as dunn benson was (it was a page of grand prix 1/4 mile times.)
lol, i guess i should have clicked the link, at 200ft it's a DA of 1447ft...now time to recalculate....
9.96 at 72.85mph....that's seems better.
i was runing consisten 9.5-9.6 at 74-75mph at rockingham in the 1/8th with my 16's and 225/50 16 sumitomo htr+'s. now i have 18's with 245/40 18 BFG Geforce TA KDW's, which are over an inch in diameter taller than the 16" wheel tire combo.
__________________
Pebble Beige Baby
i hate numbers. my DA turned out to be 598 and that isn't even close to the numbers on the NHRA correction factors table. i dunno maybe its just becuase i'm tired? :dunno:
Good info Dave. Makes me feel better. My PB was a DA of 2367 plus a headwind of 20mph. Like Mike said, I need to get out again.
Headwinds are strange things. I've run in some pretty strong wind 10-25mph and you'll agree anything over 15mph is downright gusty. My timeslips show a very slight decrease in ET, but my MPH goes to crap. The day I ran in 20mph+ headwinds, my traps were down well over 3mph and my ETs were done just under .1. I guess on the last 1/8 mile is where the wind really robs your power.
I've seen it work the other way too. When I ran my 99.51mph trapspeed, I had a nice 15mph tailwind.
__________________
Did this for another day when I ran my PB 13.63 and it gave me a DA of 1146ft...
Using 1200ft
13.63@101.05 = 13.45@102.35 pretty accurate from my other day. 13.6 was on slicks and the 13.9 above was on street tires. I guess my car has its good days.
Intersting post. There are no correction factors close to the calculated 8150ft DA I calculated for my 14.858 @ 93.28 run at Bandimere. Heck, Bandimere's actual elevation is 5880 and the chart doesn't even go that high.
If I use the NHRA's factors for Bandimere on an ideal day, that calculates out to a 13.78 @ 100.4 mph.
My 10.99 @ 134.44 in my Mirage calculates out to a 10.19 @ 144.83 mph, though this was using the same calculations, boosted cars should use half calculations.
__________________
Robert Shoemaker
'02 Maxima SE 6spd (daily grind)
14.85 @ 93.28 mph - 5,880 ft elevation
