Go Back   Maxima Forums > Track and Tune > 1/4 and 1/8 Mile Racing
1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Thread Tools Display Modes
Old 06-20-2004, 08:05 AM   #1
96 I30 only ran 16.6@82, WHY???
I have just bought a 1996 I30 automaic. I took it to the track expecting low 16's or real high 15's but only got 16.8-16.6. The 16.6 was with the air filter removed. Later I ran a 16.7 with the air filter. Is the I30 that much heaver than the Maxima's, or is there another reason? And yes I know how to drag race so that's not it, I raced my other cars over 200 times.
Jason92SE,96I
Jason92SE is offline   Reply With Quote
Old 06-20-2004, 10:06 AM   #2
Send a message via Yahoo to CullenJ76
Your trap speed is extremely low. That's what I trap in the 1/8mi. There are many different things that could be going on.
CullenJ76 is offline   Reply With Quote
Old 06-20-2004, 11:54 AM   #3
NWP Engineering.com
Aaron92SE's Avatar
Send a message via AIM to Aaron92SE Send a message via MSN to Aaron92SE Send a message via Yahoo to Aaron92SE
Can you please give us all the numbers on your timeslip? I only need the 60', 330', 1/8 and mph, 1000' and 1/4 and mph.
Also, can you please give me the exact date and time that you ran these times? And also, I will need the city and state that this track is located in. Also, what is the track's name? If you answer all these questions, I can answer yours. Thanks.
Aaron92SE is offline   Reply With Quote
Old 06-20-2004, 08:09 PM   #4
Here is the best time
60' 2.522
330' 7.063
1/8 10.770
mph 67.47
1000 13.924
1/4 16.609
mph 83.38
best 60' ever was 2.458
96 I30 leather edition,sunroof, automatic, 93 octane
Mods where: NGK IX plugs, and no filter or air box lid/ KGB AGX/tein S-tech.
Added weight: 18' ADR sport wheels Nitto 225/40 tires.
I hope this helps.
Old 06-20-2004, 08:19 PM   #5
SLOW
Nealoc187's Avatar
Send a message via AIM to Nealoc187
Have you checked for a knock sensor code. No bones about it your car is NOT making the power that it should be. No I30s are not much heavier than maximas, about 100lbs is all.
Nealoc187 is online now   Reply With Quote
Old 06-20-2004, 08:39 PM   #6
I30tMikeD's Avatar
Send a message via AIM to I30tMikeD Send a message via Yahoo to I30tMikeD
Quote:
60' 2.522
330' 7.063
1/8 10.770
mph 67.47
1000 13.924
1/4 16.609
mph 83.38
I hope this helps.
1. That 60' is terrible. Pull 2.2's and you be in the 15's at least.
2. I bet those 18's are heavy and sucking out .2 and 2 mph
3. Atlanta in June is probably hot, so that is not helping much either.
4. Make sure the car is running in tip top shape before going to the track. Plugs, fuel filter, CEL codes....
I30 are not really much heavier than maximas at all. Mine weighs 3200 with me in the car....so about 3030 w/o me in the car. That is full interior, no weight reduction.
__________________
2004 Silver G35 6spd Sedan
1996 Turbo 5spd I30 380whp...sold
I30tMikeD is online now   Reply With Quote
Old 06-20-2004, 09:17 PM   #7
NWP Engineering.com
Aaron92SE's Avatar
Ok, hear is the breakdown. From what I calculated, your car ran actually fast for a stock VQ Auto.
You ran in 85 degrees with 62% humidity and 30.12 on the barometer. That track is at 1100 feet elevation in Commerce, GA.
With those weather numbers, the air density when you raced was 3111 feet. So, since it was so hot, it was just like racing at a track at over 3000 feet elevation!! The general rule of thumb for actual elevation is "for every 500 feet, you get one tenth slower". I have found that true when jumping from track to track all over the nation. So, if you take that rule of thumb and apply it to 3111 feet air density elevation, then you will be about 6 tenths slower than stock numbers. But, in my personal experience with all the bracket racing I've done in different weather conditions, I have found that when you're talking about air density elevation equivalent, the rule of thumb is "for every 750 feet, you get one tenth slower in the 1/4 mile". So my guess is that you should be .47 slower in the 1/4 mile just due to the track and weather conditions you raced in.
Now, I agree with Mike when he said those wheels will slow you down about 2 tenths!!
Now, that's .67 that you are slower in the 1/4 mile.
That 60 foot is about normal for your car. I bet that 2.45 60' was only a "chirp chirp" off the line and not a loud long squeal. So you can't really improve in your 60 foot time of 2.45 unless you add on some power or gearing mods (small tires).
I bet on a good day with nice sea level air density elevation and stock wheels, you can run about 15.9s, which is a great stock time. That air filter removal might have shaved a half tenth at the most, so I didn't really add that into my calculating. BTW, at the Atlanta Dragway, it's going to take about 40-55 degrees for the air density to be zero feet, depending on the constant fluctuating of barometric pressure.
So in conclusion, you actually ran some great times considering you ran in crappy weather at a not so great track (1100' elevation). Be happy! Your car probably runs fine. You obviously know how to drive.
Old 06-21-2004, 07:36 AM   #8
wow your time slip looks identical to mine a few weeks ago. on the way home the tranny blew and the torque converter was shot. sorry. hope it doesnt happen to you.
__________________
2001 Red Z28 5.7 mmmmmm
waveridr85 is offline   Reply With Quote
Old 06-21-2004, 09:21 AM   #9
I knew that Atlanta's track was a little slow because, my friends EVO only runs 13.9@99 and 350Z' only run about mid 14's. I feel a little better about my times, I'll wait until the fall and run again, it will be much cooler. And I will have some more mods.
Old 06-21-2004, 12:08 PM   #10
NWP Engineering.com
Aaron92SE's Avatar
How's your 92 SE? VE power!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
