1/4 and 1/8 Mile RacingTalk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
i read somewhere that 15" maxima steelies weigh 40lbs w/tires. are there nissan alloy wheels out there that would bring that weight down? if so, which kind? thanx in advance!
Well, the weight of your wheel tire combo will depend on the weight of your tire too, but 96 Infiniti I30t wheels, the bbs mesh wheels, weigh 14 lbs which are a bunch lighter than the stock steelies.
Thanx for your answers! Im looking for rims sometime in the future - just bought my Max yesterday and it came with steelies. Nealoc187 mentioned the Infiniti wheels being really light, so I might just go with that. Any other light wheels out there?
Kosei K1 Racing in 15x7" weigh like 13 pounds, and are relatively inexpensive as well. Good ones to run slicks on if you ask me (especially for my VQ35 powered car)...
There are tons of lighweight wheels you could go with. It depends on what your looking to spend. A quality sub 15lb 17"+ rim will cost at least $300 per wheel. In my situation I wanted light weight wheels but did not want to spend $2000 on new wheels and tires so I just went with my stock BBS mesh wheels at 14lbs. The only downside is that they are 15" which is not the best in the looks department. So if your on a budget and care more about go than show then some 15 or 16 inch lighweight wheels are a good option.
—SSR GT1 (pricey as hell)
—OZ Superleggera (no longer made in gunmetal but seem to be still on eBay)
I'm very picky about the wheels I'll put on my car. I'd get SSR Comps but I don't like their looks at all. In fact, I don't want any 6-spoke rim, I'd prefer a 5-spoke or (possibly a 7+ spoke) rim. Anybody know off the top of their head? I don't like Kosei and I'm willing to spend a fair amount for light (Ideally more like 15-16 pounds) 17x8s that look good.
I wish someone made a rim that looked similar to the Mille Miglia Evo 5 but was forged and light....
Check out TireRack, they give the wieght of most the wheels there. Sub 20lb 17's are pretty easy to come by for not too much money. It's when you get down to 12-13lbs is where it gets real pricey.
I can tell you that 3rd gen GXE wheels are heavy. Mazda millenia wheels, the 9 spoke?, 15" are light.
Any one know what tires are light weight?
__________________ -Jon
Daily driver: 98 Maxima SE ... Best E/T: 14.9, Best trap: 95
06 Drag car: 91 Sentra SE-R ... Best E/T: 13.1, Best trap: 110, 2.2 60' R.I.P.
09? Drag car: 94 Sentra E ... In the making
Motegi just came out with it's light weight wheel. It's called Trak-Lite. They are 5 spoke and come in black or gunmetal. The 15x6.5 weigh 10lbs. The 17x7 weigh 15lbs. and the 19x7.5 weigh 18lbs.
However, on the downside they cost from around $220 for the 15's up to $355 for the 19's per wheel, but if you are really serious about improving your track times I don't think it's a big deal. You could consider it as 2 mods in one. A cosmetice mod and a performance mod. Just thought I throw that out to everyone.
Here is a pic of what it looks like. I know this is a 4 lug rim but they come in 5 lug also.
Not bad, I like the gunmetal, but they don't appear to be made in 17x8. I won't even consider a rim that's less than 8" wide. You can tell a company makes good rims with an eye to performance when they make wider rims. If they make 19x7.5 etc, you can tell they're more into cosmetics.
What are you talking about, expensive? SSR GT1s are $359 each in 17x8 at Tirerack, so these Motegis seem pretty cheap ... good (forged) light wheels are expensive. If you buy a lightweight cast wheel, have fun buying new rims whenever you accidentally hit a big pothole or bump....
The TrakLites are forged. And I think the thinner wheel is probably for less weight. And they may not be 17x8 but those SSR GT1 weigh 18lbs. The TrakLites in 17x7.5 weigh 15lbs. so that's a 3lb. difference per wheel. Totaling 12lbs. lighter than the SSR GT1's. To some that may not matter but to others it does. So it really just depends on what you want. To each their own.
K, point taken. I don't like the Trak-Lites nearly as much as the GT1s aesthetically, however.
Good luck with that because 17X8 is very rare. 17X7.5 is fairly common and 17X7 is the norm. The Maxima is a light sedan with no need for a 8" wide rim. The foot print under a 7" wide rim is plenty big. My 225/50s on my 17X7 rims are 9.2" wide with a 8.5" wide contact patch.
Fragility depends largely on the brand cast lightweight wheel and overall design of the rim. My cast 17lb 17X7 ASA LS5s (made by BBS) were only $170 from the Tirerack and I've had them for over 1.5 years now and they've taken quite a beating from frost heaves, winter potholes, and the extreme road construction we have here in Kansas City. The rims are completely true and round. Keep in mind that even heavy and chunky cast rims can bend very easily.
__________________
2003 Black G35 sedan automatic
Best ET: 14.32, Best MPH: 99.87mph
Mods: MD spacer, HR y-pipe, RevUp airbox, Z-tube, 05 sedan midpipe, 350Z/Coupe springs, lots of other stuff
Sold -1996 Black SE 5-speed MEVI & JWT ECU equipped
14.31@99.34mph with a 2.18 60'
I'm using Kosei Penta RT's, 17x7.5, which weigh 16.1 lbs. Got them for $650 shipped from maxed up.
Not sure how available they are these days, but they are nice, affordable, light weight wheels.
__________________
Hotshot Headers, Cattman Catback and FastCat, Nissan Works Phenolic Spacers, Advanced Timing, Definitive Motorsports UDP, 2nd Gen Maximum Tuning VB, Maxspeed Springs, 9 inch K&N cone filter, Kosei Penta R/T (17x7.5, 16lbs)w/ Toyo T1-S 245/45/17, Odyssey PC 680 battery (14 lbs).
